PDF SIZE FOR LO 2016
If Trimble overhauled the pdf code to greatly reduce their size, why is my 2016 version creating PDF’s TWICE the size of 2015? I have output quality set to high on both versions.
Do you have the settings on High? Select a lower JPEG compression. All of my PDF's have been drastically reduced in size
LOWERING JPG COMPRESSION is applicable only to LO files containing stuff other than vector linework?
