    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Checking Template Units
    3 Posts 2 Posters 584 Views 2 Watching
    • medeekM Offline
      medeek
      I'm sure this has been asked before but I'm not seeming to find it so I will ask again. I want to be able to detect whether the user is using a metric or imperial template so I can customize my plugin user interface to the correct units. What is the suggested way to check for metric vs. imperial units of the template being used?
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        Btw, I wrote a general article on how to deal with units in SketchUp: http://www.thomthom.net/thoughts/2012/08/dealing-with-units-in-sketchup/
          You don't really check the templates - you just ask the current model the user is using. The current model might be of a different unit than their selected template.
          At my previous job we switched a lot between mm and m in our project files.
          You use model.options to inspect the current model's options:
          options_manager = Sketchup.active_model.options
          options_manager.keys.each { |options_provider_name|
            puts options_provider_name
            options_provider = options_manager[options_provider_name]
            options_provider.each { |key, value|
              puts "> #{key} - #{value}"
          Output from that snippet:
          PageOptions
          > ShowTransition - false
          > TransitionTime - 2.0
          UnitsOptions
          > LengthPrecision - 0
          > LengthFormat - 0
          > LengthUnit - 2
          > LengthSnapEnabled - false
          > LengthSnapLength - 0.03937007874015748
          > AnglePrecision - 1
          > AngleSnapEnabled - true
          > SnapAngle - 15.0
          > SuppressUnitsDisplay - false
          > ForceInchDisplay - false
          SlideshowOptions
          > LoopSlideshow - true
          > SlideTime - 1.0
          NamedOptions
          PrintOptions
          > PrintWidth - 8.5
          > PrintHeight - 11.0
          > ComputeSizeFromScale - false
          > SizeInPrint - 1.0
          > SizeInModel - 1.0
          > VectorMode - false
          > FitToPage - true
          > NumberOfPages - 1
          > LineWeight - 0.5
          > PixelsPerInch - 150.0
          > SectionSlice - false
          > ModelExtents - true
          > PrintQuality - 0
          > ScaleAdjustment - 1.0
          > QualityAdjustment - 1.0
          So in this case you want to inspect UnitOptions:
          model = Sketchup.active_model
          model.options["UnitsOptions"]["LengthUnit"]
          Note that you want to use the constants in the class Length against the values returned here.
          Length;;Decimal
          Length;;Architectural
          Length;;Engineering
          Length;;Fractional
          Length;;Inches
          Length;;Feet
          Length;;Millimeter
          Length;;Centimeter
          Length;;Meter
          So something like this:
          unit_type = model.options["UnitsOptions"]["LengthUnit"]
          metric = case unit_type
          when Length;;Millimeter, Length;;Centimeter, Length;;Meter
            true
          else
            false
          I'm doing this check because LengthFormat got options that can be used with both imperial and metric units.
