    Procedural Wood Texture
    24 Posts 6 Posters 6.1k Views 6 Watching
      Jeff,
      Although you can do perspective correction in Photoshop and other editors, it is best to get the camera set up as square to the surface as possible. Also set the focal length to something longer to get away from the distortion that occurs naturally with wide angle lenses. Get the lighting as even as possible. Use a lightmeter and gray card to check illumination. I have a hand held spotmeter for that. I work with unfinished boards because I then have the option to add the "finish" in an image editor. For the finish I create a new layer in the editor and paint it with a transparent color. That color can be adjusted until I'm happy with the appearance. Sometimes I'll make three or more different stains to try out. It's easy to readjust the color and opacity of the layer after saving the image.
      I made this image a while back to show some variations in stain colors.
      [url=https://flic.kr/p/d9FK2d]
      https://farm9.staticflickr.com/8436/7974567274_bdf1469cf9.jpg
      I've thought it would be cool to make a scanner that would scan an entire board. Seems like a project for Matthias Wandel. πŸ˜„
      • JQLJ
        JQL
        I think there are hand held scanners that could do the job. I don't know if they're limited to standard paper sizes.
        www.casca.pt
        Visit us on facebook!
          Yes. I was thinking about those handheld scanners. I was also thinking this would be another way I could justify a 48 x 96" CNC machine. Replace the router with a scanner head. You could scan up to a full sheet or plywood. πŸ˜„
          It wouldn't be limited to wood, either.
          Three little problems. I'm not sure if normal scanner software would handle that much image area, not enough space in my shop for a machine that big (especially since I also want to build another boat in it) and there's the problem of not enough shekels in my pocket. 😞
          • bazB
            baz
            Kickstarter campaign maybe?
              jtri
              We are planning on getting a new plotter/scanner for large prints at work and it will scan in color. Do you think I will get fired if I try scanning sheets of veneer?
                You might be able to get away with it once. πŸ˜„
                  Maybe that would fly.
                    I volunteer to start kicking Dave πŸ‘
                    • PixeroP
                      Pixero
                      I made this texture plugin for Thea render some time ago.
                      It is a three dimensional procedural wood texture so it won't require UV mapping.
                      Sadly procedural textures are not supported by Presto (yet).
                      No website is present on this hostname
                      The website you are trying to reach could be suspended, deleted or DNS could be incorrect
                      (pixero.com)
                      http://pixero.com/wp/wp-content/uploads/edd/2013/08/dragon02.jpg
                      • JQLJ
                        JQL
                        That is very interesting Pixero! No need for UV map too?
                        Would it be able to be pushed so it would loose a bit the CG look it has?
                        www.casca.pt
                        • bazB
                          baz
                          Bump. To remind dave:)
                          • 2 / 2
