    Building roads from dwg.
    2 Posts 2 Posters 441 Views 2 Watching
    • P
      Poot
      I need to build new roads from a dwg that i imported in sketch up.
      I already welded the parts from the dwg to get 1 curved line.
      My idea was to build it with them whit the follow me tool but i get a strange result.
      Then i searched for other plugins and i found this (https://www.valiarchitects.com/sketchup_scripts/instant-road
      Is this the most simple solution for these problems ore are there other ways to work true this?
      Thanks in advance,
      Sam
      • pbacotP
        All depends on what you got and what you want.
        If you are just trying to make flat surface that looks like a road, just make a face and push pull it up. Use one edge and an outline to use follow-me and add curb and gutter.
        If you want a crown in the road you can use follow me on a curve for the road ss well, but that road will have all one width, and intersections will require other work.
        Extrude edges by rails can help if your road needs a crown and is variable width, but intersections will still require a lot of work.
        If you want a realistically made road with proper grading these methods won't make it. You might try skinning progressive profile curves with extrusion tools or curviloft.
