    Problem with Profile Builder in SU2016.
    3 Posts 3 Posters 442 Views 3 Watching
    • C
      CalypsoArt
      Since moving to SU2016, I'm having a problem saving Profile Builder 2 profiles to the
      libraries. Not sure why I'm locked out. I assume it's something I need to
      configure.
      I have an extensive library that I copied over from SU2015 to the
      equivalent folder in SU2016. I can access all the profiles in the
      libraries, but I can't add new ones. See Error pic. both SU2015 and SU2016 are on the same Window 7 machine.
      Suggestions?
      The email address I had for the PB2 coder, is no longer valid. The only communication avenue I found was the FaceBook page. Anyone know if there is a better way?
      http://calypsotheatrical.com/link_images/PB2.JPG
        driven
        did you try another location folder?
        and if you look at the PB2 thread you'll see 'Whaat' [the author] was here on Monday...
        • jujuJ
          juju
          are you logged in and running as administrator?
