    Best way to create traffic ramp, edges to faces?
    6 Posts 2 Posters 744 Views 2 Watching
      peebo22
      What is the best way to create faces/triangulate from edges.
      What plugins can you use? Fredoshear?
      If you check out the SKP file, you can see that there are many little edges...
      Thank you.
      check out
        Curviloft! then PushPull Interactive by Fredo6;)
        But in your case, as complex ramps are yet existing make some cuts before to use it!
          peebo22
          Ok! And which plugin can make slopes on both sides of the road? Ground elevation I mean.
            Maybe this ? πŸ˜‰
            or Flowify ?
              peebo22
              Hmm, maybe I didn't say it correctly..
              I've attached the picture, the arrow shows what I'm trying to say πŸ˜›
              I remember that some plugin did this but I just can't remember the name.
                So if you don't want make your own ramp with Shape Bender, you have this specialized one! πŸ˜‰
                Instant Road 😎
                http://www.valiarchitects.com/sites/default/files/u4/roadGif3small.gif
