    Module-class
    7 Posts 4 Posters 837 Views 4 Watching
    • mariochaM Offline
      mariocha
      HI, guys,
      I need HELP!
      I have written my first method (±70 lines) that works very well.
      Now I want to wrap it in a module and a class.
      (And later a start-operation & commit. And finally a begin-rescue...I guess)
      But adding a - class Name -before everything and -end- as last line breaks it all.
      I'm trying to find good readings about all this.
      Meanwhile here are a few simple lines of it. They give me an "undefined method" error.
      After all that work and studying for weeks, I am so disappointed that these few lines give me a headache !
      Module.rb
      %(#008000)[Mario C.
      • TIGT Online
        You need to call the whole 'path' to the method:
        McF3D::McF3DTools.new()
        AND also add into the initialize() method [which is called by 'new']
        [at the end]
        perceOuv()
        • mariochaM Offline
          mariocha
          [at the end]
          perceOuv()
          Many thanks for your answer,
          Heu... but very sorry. Still too abstract for me. 😳
          Tried many ways to implement McF3D::McF3DTools.new(), but cannot figure out where it goes.
          Every scripts I open for reference has a different way of about class.
          very tired.
          %(#008000)[Mario C.
            driven
            I found and still find it confusing, so it good to create a really simple example...
            try each separately or run all at once...
            puts 'hi'
            def my_hi
              puts 'hi'
            my_hi # call
            class My_Hi
            	def my_hi3
            		puts 'hi'
            My_Hi.new.my_hi3 # call
            module JcB
            	class My_Hi
            		def my_hi4
            			puts 'hi'
            		end # my_hi
            	end # My_Hi
            end # JcB
            JcB;;My_Hi.new.my_hi4 # call
            module JcB
              def self.my_hi5
                puts 'hi'
              end # my_hi
            end # JcB
            JcB;;my_hi5 # call  or  JcB.my_hi5
            and there are other variations on the theme...
              MSP_Greg
              Mario,
              Glad that helped.
              @mariocha said:
              is the def Initialize a must ?
              Technically, no. But, if there's no need for it, one might ask the question 'should this be a module?' The answer would vary amongst programmers, and isn't dependent on that single criteria.
              [EDIT] I should add that when you create a class, it is a Ruby Class object, which has a :new method, which calls initialize if it exists. Just in case you were wondering...
              Greg
              SUMD SketchUp Misc Docs
              • mariochaM Offline
                mariocha
                Hey, great ! Now I get it. (slapping my forehead) 😄
                Thanks a lot.
                On to start_operation - commit now. update: that was an easy one.
                Oh btw, is the def Initialize a must ?
                %(#008000)[Mario C.
                  MSP_Greg
                  Mario,
                  This might help (I reformatted your code a bit), see the last couple of lines --
                  # require 'sketchup.rb'   # why?  not needed for this code
                  module McF3D
                    class McF3DTools
                      def initialize
                        @mod = Sketchup.active_model  # Open model
                        @ent = @mod.entities          # All entities in model
                        @sel = @mod.selection         # Current selection
                      def perceOuv
                        unless @sel[0].is_a?(Sketchup;;ComponentInstance) &&
                            @sel[0].definition.behavior.cuts_opening?
                          UI.messagebox "Sélectionnez un composant F3D !"
                    end # class McF3DTools
                  end # module McF3D
                  obj = McF3D;;McF3DTools.new()
                  obj.perceOuv()
                  The topic of modules & classes in programming is very complex. Conversely, what most people writing a SketchUp extension need to do is a very small subset of that topic.
                  HTH,
                  Greg
