    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 573.1k Views 71 Watching
      Garry K
      Version 1.0.17 is now ready for download.
      Documentation is finished - 83 pages
      Fixed a couple of bugs
      • FrederikF Offline
        Frederik
        Thanks, Garry...! šŸ‘
        I wonder why there's almost no-one posting replies in this thread...?!
        Your cabinet maker is a great plugin with lots of options...
        Perhaps it's because other users are having their own standards...??
        Cheers
        Kim Frederik
          Garry K
          Kim
          I am getting private replies which I keep private. Perhaps some cabinet makers etc. want to keep their techniques private !!
          That's ok with me and I respect it.
            ktkoh
            Gary here is video of the kitchen I designed for my grandson. On the last wall shown the end cabinet was made by using the Angle cabinet then replacing the blank front with a door and drawer from a base cabinet the width of the blank face.
            I have noticed that selecting save for rules and materials seems to make nothing happen. When starting a cabinet the save as results in window to name or select the file but not at the materials or rules tab.
            I like the help pictures shown now when working in the forms. Very Helpful.
            Keith
              Garry K
              Looks good.
              You can set Materials to "Save" and then go to Rules and set "Save" and then go to Cabinets tab - make some changes and create cabinet.
              I'm pretty sure you will find that the rules and materials were saved.
                Garry K
                I've added handless doors and an optional Overlay Counter.
                • utilerU Offline
                  utiler
                  Garry, probably a silly question at this stage but what is the difference CabMakerPro and CabMaker32?
                  Just Curious...
                    Garry K
                    CabMaker32 is C++ executable that currently only runs on Windows. It communicates with Sketchup by passing it a file. A small plugin reads the file and renders the complete kitchen. The executable works for shops that are producing a lot of cabinets and don't always need to see them.
                    CabMaker is a sketchup plugin.
                      ktkoh
                      One other thing once I saved rules and material then used sav as an named the file I could retreive those settings. However after updating the plugin the materials and rules reverted to the default. The cabinet sizes retained my settings.
                      Also it would seem to me that when editing a cabinet the materials used should show up on the form. The program must know these to make the proper changes. I would not want to change the design by just editing the width or depth etc.
                      Keith
                        Garry K
                        Keith,
                        Really - thank you - I do appreciate feedback.
                        I think I've got a solution. I simply need to store the default settings in the model.
                        Load the model and read the default setting from the model instead of from the file system.
                        Then each and every project / skp file would have your desired defaults !!
                        • FrederikF Offline
                          Frederik
                          Looks really great, Garry... šŸ‘
                          One small thing, though...
                          The way drawers are made in modern kitchen the handless drawer hides the top of the drawer underneath...
                          I've made a very rough model of a cabinet with drawers and another cabinet with doors, using your plugin to show what I mean...
                          I've coloured the changes I've made in a red colour so you know what to look for...
                          Below is an image of my own kitchen...
                          Hope you can use this...!?
                          Cabinet-w-drawers.skp
                          Cheers
                          Kim Frederik
                            Garry K
                            1. I've added Inset doors. Set the door protrusion to -19 for a door thickness of 19 and cab maker builds a cabinet with inset doors and drawers. Stretchers can be optionally used between drawers and doors. Vertical Dividers and pullouts are set back by the proper amount.
                            2. Added the ability to place the cabinet at any height by using the shift key in combination with the left mouse button.
                              Garry K
                              I really would like to know if there are any Mac users running version 1.0.17
                              I don't have a Mac so debugging a Mac is just a bit tougher.
                              • FrederikF Offline
                                Frederik
                                Are you able to use what I wrote...?
                                Cheers
                                Kim Frederik
                                  Garry K
                                  Kim,
                                  I'm still getting my head around all the different styles and approaches. I've also been asked to do C and J channel styles of handles.
                                  I'd like to handle some of the off the shelf hardware. I've put this on the back burner for a week or so while I gather more information.
                                  • utilerU Offline
                                    utiler
                                    šŸ‘
                                    Just Curious...
                                      Garry K
                                      I currently have 5 translation files
                                      English: en.lang
                                      French: fr.lang
                                      Russian: ru.lang
                                      German: de.lang
                                      English with UK woodworking terms: uk.lang
                                      If anyone is interested in having other translation files please get a hold of me. I will extend the trial by a couple of months for those interested in helping. This applies to the first person that contacts me for a given language.
                                        Garry K
                                        version 1.0.18 ready for download
                                        I've been looking at a number of handless door systems.
                                        This one is interesting. They have an LED track that illuminates the channel.
                                        They also have clips to simplify construction.
                                        Database Error
                                        (www.zobal-usa.com)
                                          Garry K
                                          Version 1.0.18 - Nov 2015
                                          1. Added Overlay Top for Standard Base units. Top sits on sides. Slip in back ignored. Honors Skin Upper "Top" or "Both"
                                          2. Added Handleless cabinet doors. Texture part not yet working
                                          3. Hold Shift key down with left mouse button for absolute height placement
                                          4. Added inset doors for all cabinet styles
                                          5. Sped up the load time for the Web Dialog
                                          6. Added a check for Mac OSX. Trying to clear a nil object. Fixed.
                                            Garry K
                                            1. fixed kicks. They weren't extending when using right and or left fillers.
                                            2. With Integrated kicks if the side notch is greater than the front kick by the thickness of the kick then the kick extends to the full width of the cabinet including fillers.
                                            3. I am now hiding the fron side edge of the kick. Kicks appear very smooth when cabinets are butted together.
                                            With your input, this post could be even better šŸ’—
                                            • 31
                                            • 32
                                            • 5 / 32
