    Trouble w/ dynamic stair
    2 Posts 2 Posters 245 Views 2 Watching
      stephenn
      I am VERY new to creating dynamic components and I am having trouble w/ a dynamic staircase. When I go to scale it and drag it down to increase number of stairs, I want the top step to stay in place. However, after re-sizing, the entire stair moves either up or down. If anyone can take a look and let me know what I am doing wrong, I would appreciate it. I am sure it is something simple.
      When opening the file alone, the stair always snaps back to origin but when you import into existing drawing, that's when it moves around as you change size of stair.
      Thanks in advance for help.
      Stair - Dynamic Rise.skp
        pcmoor
        use for lenz attribute
        LenZ =current("lenz")
        it will adjust first then become stable
        make X,y adjust to position, you have them set at a value, delete the =
        with Z, you could create a option to change its value or use =current("z")
