[REQ] Select Vs Edit Change in a fundamental way.
@pbacot said:
Richard, Do you use LayOut to design your houses and things. Then you put it in SU?
Just for your interest mate, here is a rough sketch design for 8 x 2 storey units, done this morning with layout in around 4-5 hrs from scratch.
[attachment=0:29lrnd0w]<!-- ia0 -->1600_2.jpg<!-- ia0 -->[/attachment:29lrnd0w]
Well, that could be drawn inside sketchup even faster... And then you could convert that into a 3D model and render in Thea in an IBL background in the same day.
Using LO like you would use Acad or Illustrator surely is a nice topic!
Though Sketchup is a 3D modeler I use it for all my 2D drawings and studies too and then send them to layout with a click of a button. This might be the reverse of what you do and that is also an interesting discussion in itsel.
However, the topic here is about SU+LO and how they are not following same principles in UI when they should. It has to do with how fluid is our connection between both apps, not how fast you model or draw on each of them when you're used to them.
This topic is obviously for people wich work with both and consider them important at the fullest scope possible.
Mate, you may have missed the key words "design sketch". Creating a design from scratch to support 8 units against planning controls and good internal space planning and testing half dozen layout and unit variations on route to this workable, but maybe not final solution.
And yes for sure mate, if given a preconceived design, it would be possible to work it up in 3d, test the exterior and run a draft render out of SU. But the shear amount of testing on reconfigurations - I would honestly suggest I could not hope to resolve a solution in such a short time. SU just doesn't like to play so fluently.
Just the adsence of a nudge tool would add so much time, probably an hour alone in this exercise was spent nudging spaces around to get that 100mm here and there (given the accumulative result) to get it to work.
Strangely I see the possible option to one day be able to export a 3d model (of sorts) from LayOut, maybe through the assignment of "extrude by layer", or by assignment of xref attributes that substitute LO objects for SU components on export. Sure the result would be crude but would give good starting point from which to edit the result.
I have several times trialed the design of concepts in SU as a 2D tool, for me it's just a few things that break its fluidity. That said, several functions (layers maintained in groups, offset tool etc). I do admit that my way of working in reverse does mean double work (design in LO, model in SU) but the total time I save in design is significant (well for me at least).
Totally agree with you mate on matching the functionalities, so long as one isn't broken in the effort. And that a study of where the common point lies might not just be a review of LO's functionality.
BTW I hope I haven't hijacked the thread, was just making the case that not all work in the same way! And that a study of a different way might spark the developers to look deeper into the possibilities offered in these BRILLIANT tools.
I didn't miss them!
My design sketches are done on site, on meetings and on paper. I don't know how much time I take to develop them.
Then, what you do call design sketches I do not have. I replace that by designing a model as my first plans are also related with space studies, not floor plans alone alone. My space studies quickly evolve to models and my models are quickly rendered.
I might still be talking about design sketches but inside Sketchup. They're not a morning's work, but a day's work.
From there a quick presentation emerges. A 3D one with LO plans and some renders. The main idea is there but also the main model.
As the idea evolves, the model evolves. There's also optimization there's also quick work, but there is not a 2D frame of mind. There's always a 3D take on things and a quick 2D LO output.
On some stages, not even the 2D output is needed as we are talking on space changes, nor floor plan, LO changes. At least not in a fundamental way.
