    GoMicro - Prefabricated Modular Microhome Concept
    21 Posts 12 Posters 3.4k Views 12 Watching
      Wow, brilliant, you deserve a raise mate.
      • DanielD Offline
        Daniel
        Impressive project, Jacob.
        My avatar is an anachronism.
        • pbacotP Offline
          Great ideas, really well worked-out and presented.
          • majidM Offline
            majid
            very smart and well done -presented. gluck!
              liam887
              Great work
              VISIT MY ONLINE GALLERY
              • pbacotP Offline
                Do you have any problem with the model being slowed or complicated by elaborate (high poly) multi layered components as for plumbing fixtures and appliances?
                • GubermenschG Offline
                  Gubermensch
                  Thanks everyone!
                  Not so much. The file size never surpassed 80mb. Lots of repeated geometry. The piping/electrical is low poly for the most part, 12 segments a line, and there isn't much of it given the small scale. The warehouse render was pretty heavy - I made an empty warehouse a couple years ago and didn't yet understand how to optimize model performance with components, low-poly imperceptible detail and what not.
                  http://www.jacobgubler.com/
                  • RichardR Offline
                    Richard
                    I really like the concept in general mate! I do have some questions and comments though.
                    What do you see the modules clad in and constructed of? By the images with rolled corners, one would assume aluminium? Cost here ($'s and environmental) would worry me!
                    What are you proposing as the structural framing, could this even be eliminated if sandwich panel construction was utilised? Ie: SIP type - Skin / EPS / Skin.
                    The installation direct to the ground is also an issue that would call for some serious ground works prior to installation, and then give rise to thermal transfer issues.
                    The beauty of all of this, you are thinking about new models for housing and that's always good!
                    BUILTBRAND.COM.AU
                      Gubermensch
                      Thanks for the feedback Richard. Your modules were an inspiration and catalyst.
                      I imagined them clad in formed fiber cement paneling over waterproofed ply. The rounded nature would require special order, increasing costs for the FCP, underlaying formboard and carpentry. The sole motivation to keep them was a differeniating aesthetic that might be appealing to the Apple generation.
                      My intention was timber framing, a 2x6 exterior with a 2x10 subfloor and roof. For the 4X and 3X modules, 6x6 columns connected by 6x10's, with 2x10 subfloor and roof spans.
                      The main motivation to keep the subfloor was to create a module that can be shipped and transported at 95% completion. The subfloor framing not only allows for the means of connecting utilities between modules, but also for a factory-made finished floor, interior framing, cabinetry, etc., in addition to a simplified, more feasible means of relocating. Could the thermal transfer issues be remedied via an insulated subfloor? I imagine there need be some vapor barrier between the exterior bottom subfloor and slab (Aside from some goop around the base perimeter, which is a given).
                      What kind of groundworks do you forsee? I envisioned the modules fitted onto indentically dimensioned slabs with identical anchor bolt locations, plumbing waste penetrations (where necessary), and post-intallation waterproofing. Water supply can enter the exterior walls, intergrate with the water heater and inter-module piping. Electrical can do the same, all post initial installation.
                      • RichardR Offline
                        Richard
                        Wow, thanks mate! It was certainly a lot less complex than the project you've set yourself! šŸ¤“
                        I'd then imagine Aluminium might prove to be an alternative even on costs. I'd also look at if this could be false work so as to not require an added depth of engineering in the frame out.
                        Consider to that your aesthetic direction is giving rise to lots of further consideration of water and waterproofing.
                        Mate I'd think about the option of SIPS or something your creative mind might come up with! Here is a link to a product I've been helping to develop the system for. Simply your FRC sheet glued to a Polystyrene insulative core. Given your module size, pretty much everything could be done with that and the result be RIGID!!!
                        Modular Building System | SipFormā„¢ Structural Insulated Panels
                        Structural Insulated Panels | The SipFormā„¢ Modular Building System offers builders an affordable, more efficient, high performance method of construction.
                        (www.sipform.com.au)
                        Here is another cool system using steel sandwich panel.
                        Mate here is then, what I'd suggest the weak point. That your site needs to be prepared well in advance of installation, with several additional transports to the site of everything from excavation, reinforcement and formwork, labour and concrete. Given the choice to go prefab is often remoteness, this double dealing of the floor will kill the costs.
                        I think you have those covered mate! Though again the issue about the slab!
                        Mate I'd be lifting the floor off the ground so to be located on posts that can be installed in less than a day, or on installation of the pods.
                        Here is a link to the structural flooring product we've been using in combination with the SipForm panels - this can be engineered to create a chassis for transportables.
                        http://www.spantec.com.au/
                        With this flooring system, we've been using these footings. These are installed in about 10 minutes each, so could potentially be installed on the day of delivery of the modules, and their capacity is enormous! The guy who developed these will be a rich man.
                        http://surefootfootings.com.au/
                        The beauty is the site conditions and slopes you can install to is greatly increased and the effort / costs MUCH less. Suddenly your logistics are halved.
                        BUILTBRAND.COM.AU
                          Gubermensch
                          I didn't know the cost of an FCP system, even considering the extra engineering, carpentry and special order materials, would be comparable to aluminum. Thanks for the insight! I think waterproofing would be manageable, but I'm open to alternatives. I went with FCP for aesthetic again, something that has been around a while, but breaks the mold in this kind of presentation:
                          (www.uiwell.com)
                          Wow, there are some brilliant building materials out there. The simplicity and ease of installation is impressive. How does the sipform system handle in-wall utilities? Or is there exposed piping/conduit?
                          Right, I saw two mobilizations. Your typical sitework and slab pour, then the module delivery and installation. You're right, one mobilization would be ideal. The two systems you suggested here would remedy that perfectly and make it easier to transport in the future, a feature I was trying to maintain. In what I suggested, the module owner looking to move and sell their current property would have to deal with the slab and pour a new one at a new site; with what you suggested, the structural base and footings move with them. Brilliant!
                          Thanks for the insight and exposure to these systems.
                          • RichardR Offline
                            Richard
                            I think the problem with FRC is the cost for such a custom curve, where with Aluminium it's easy! FRC is I think generally made by pouring a slurry in a flat bed mould. You can imagine then the tooling required for a curve!
                            Mate, we try to put the plumbing to an internal (one off framed out wall) if not we just run a rod with big hot tip down the panel to create a pathway for pipes or conduits.
                            Yeah it will solve a LOT of issues, any reduce thermal loss to the ground. Here in Australia we wouldn't get away with timber on to the slab without some major nightmares with termite treatments.
                            BUILTBRAND.COM.AU
                            • RichardR Offline
                              Richard
                              Yeah it will solve a LOT of issues, and reduce thermal loss to the ground. Here in Australia we wouldn't get away with timber on to the slab without some major nightmares with termite treatments.
                              BUILTBRAND.COM.AU
                              • cheddaC Offline
                                chedda
                                Great communication in the images reminds me of loft cube:
                                (www.loftcube.net)
                                Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                • Bryan KB Offline
                                  Great concept, modeling and presentation.
                                  • Mike LuceyM Offline
                                    Mike Lucey
                                    Well done Jacob, great concept and excellently presented. I'm glad to see you getting great feedback from Richard. Maybe you could team up with him and get the concept to prototype and to the market!
                                    • ken28875K Offline
                                      ken28875
                                      Awesome, Jacob! šŸ‘ šŸ‘
                                      Have a great day!
                                      _KN
                                      Follow Your Dreams.
                                      With your input, this post could be even better šŸ’—
