    SketchyPhysics 3.7.4
    48 Posts 16 Posters 95.5k Views 16 Watching
    • F
      faust07
      Works great. The rendering of animations of regular physics models with TwilightRenderer works very well. The problem of rendering of emitters and programmed objects as in Anton's youngest car AI model remains. These temporary objects are unfortunately invisible when rendering from Replay. Anton's intelligently programmed cars and SketchyPhysics could be the basis for a visualized traffic simulation. Many thanks to both - Anton and Pitu! Please continue this way.
      • F
        faust07
        I recently found an old model with this motor-joint. It works under SPh3.6 but the joint can not be modified, for example, combine it with another kind of joint. Is something like this possible in current SP-versions?
        • NigeCN
          NigeC
          I'm looking for advice on world scale.. typically I work in cm and I just can't get the gravity and world scale right..
          I'm been messing about with chains and they seem to snap depending on were the camera is, if the chain is entirely in view it'll be fine, but if its out of the camera frame or at a distance it'll snap, altering the world scale improves it but then things start running very slow
          this is a bike chain and after a bit of trial and error it will record fine without breaking,, but its running at 2 fps recording lol
          “It’s only impossible if you stop and think about it!”
          • P
            PituPhysics
            Care must be taken to have a very small gap between the "collisions". The chain is can be loose, so to speak. Just like in the video, however also laterally, between the chain links. This "chain-physics" really put a strain on SketchyPhysics. For this reason, too slow, animation and recording.
            But this video looks really good. 👍
            • NigeCN
              NigeC
              The gap between the rollers and gear are pretty huge, I could of got away with them a lot closer, but its a "suck it n see" past time lol
              Here's the render 😄
              • JQLJ
                JQL
                Nice one Nige!
                www.casca.pt
                Visit us on facebook!
                • ntxdaveN
                  ntxdave
                  Are there any plans for a 64-bit version of this tool?
                  I have SU 64-bit so I cannot use this extension 😞
                  Press F1...thank me later
                  • cottyC
                    cotty
                    A lot of people keep an older 32-bit version installed in parallel (e.g. SU 2014) to the currrent one. You can model in 2015 and save as 2014 to animate it with SketchyPhysics there.
                    my SketchUp gallery
                    • ntxdaveN
                      ntxdave
                      Good idea. I still have 2014 installed. Kind of a DUH moment for me 😮
                      • NigeCN
                        NigeC
                        I have 2013,2014 and 2015 lol.. 2014 seems better to play with SP, I don't have the 32bit 2015 but I found 2013 started to really struggle
                        Its great fun JQL and a welcome distraction for me 😄
                        • P
                          PituPhysics
                          Calmly to use the SU 32-bit, in 64-bit Win. It is as if the previous versions using it. Just did not become the icon of thumbnails. Probably there will be no 64-bit edition.
                          Anton Synytsia created a new plugin. The name is MSPhysics, it is now compatible with 64-bit SketchUp, however, is still under development. Link: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56852
                          • ntxdaveN
                            ntxdave
                            Is there a user guide in English?
                            Do I have to code actions? Can I apply the physics to my existing model? How does this compare to using a tool like Keyframe Animation or Simfonia?
                            • P
                              PituPhysics
                              If you click on the toolbar / settings button, there you will find 3 link: SketchUp API, Ruby core and Sketchy Wiki. You can learn from these as well.
                              The blue fields, onTouch, onclick, Script box to write the code. I recommend the latter.
                              Well, there is not a lot of description. I'm going to make more another intro videos on my YouTube channel:
                              https://www.youtube.com/channel/UCgkpyypPCP_ibNues2ypnGw
                              You can watch it around Warehouse: https://3dwarehouse.sketchup.com/search.html?q=sketchyphysics+3%26amp;rsi=sbis%26amp;backendClass=entity
                              My warehouse: https://3dwarehouse.sketchup.com/user.html?id=1103716790123296929922921
                              Anton Synytsia: https://3dwarehouse.sketchup.com/user.html?id=1378794811912915769114661
                              Mr.K. : https://3dwarehouse.sketchup.com/user.html?id=1200553748731081340515705
                              John: https://3dwarehouse.sketchup.com/user.html?id=1664833144786437775321088
                              November92: https://3dwarehouse.sketchup.com/user.html?id=1341212916375552782606464
                              Although there is enough old models SP 3.2, it is not certain that all of them will work but worth a try.
                                Anton_S
                                Nice work with this, Pitu! I really like how you implemented the ACE editor and did a well job with styling.
                                • P
                                  PituPhysics
                                  Thank you, Anton. Just a pity that does not work with Ctrl+C function in editor. The SU 13 comes up a window with a javascript error.
                                  These tried:
                                  • src-min-noconflict
                                  • src-min
                                  • src
                                  • <div editor
                                  • <textarea editor
                                  But even trying. 😄
                                    Anton_S
                                    To fix that message, in settings_ui.html, replace
                                    <meta http-equiv="X-UA-Compatible" content="IE=edge, chrome=1" />
                                    with
                                    <meta http-equiv="X-UA-Compatible" content="IE=10" />
                                    Here is an optional command to add. I don't recall what it does, but you can read about it on web.
                                    <meta http-equiv="MSThemeCompatible" content="Yes" />
                                    • P
                                      PituPhysics
                                      with
                                      Wow... really, I rewrite the "IE=edge, chrome=1" to "IE=10" and now work perfectly. 😄 I thought it was much more serious the error.
                                      The MSThemeCompatible not necessary: http://www.metatags.info/meta_http_equiv_msthemecompatible
                                      Thanks Anton, coming soon the next version.
                                      • F
                                        faust07
                                        A small question or idea to improve the handling of Physics Simulations after crash and bug splat. Would it be feasible to incorporate a function to start the simulation with a freely selected physics frame number, so how one can do it with Twilight Renderer in the animation presets?
                                        • P
                                          PituPhysics
                                          Hi faust07. Try this: http://twilightrender.com/phpBB3/viewtopic.php?t=215
                                          • F
                                            faust07
                                            Oh sorry, I have my question not properly formulated. It relates to the direct animation output in SketchUp. My thought is, like in the animation editor of Twilight, to start the Physics simulation from a specific frame or time and stop after a specified margin. That would be very helpful for complex simulations, large models ore extravagant stiles do not have to be fully passed through to a required point or frame. Similar to Twilight renderer, the routine could internal count through, for example, to the frame 1200 and then begins with the complete image output for the Physics model situation at that point.
                                            • 2 / 3
