    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • studio43S
      studio43
      Very cool truss modeler. I guess my next request would be to do an attic truss
      • pbacotP
        I bet most mono-trusses I've seen are in the firs four πŸ˜„ so I can't help you there.
        • medeekM
          medeek
          Monopitch and Attic trusses are the next items I will tackle.
          I've had a good bit of experience dealing with attic trusses in my own designs. The big difference in configuration is the use of a piggyback where the truss height gets too tall for shipping. I think it it would be cool to allow a user variable that enforces a max height and then draws a piggy back truss or the simpler configuration based on span, pitch and this max. truss height specified by the user:
          http://design.medeek.com/resources/truss/images/28-12-AP-TRUSS.jpg
          http://design.medeek.com/resources/truss/images/24-12-A-TRUSS.jpg
          Also with this type of truss I've noticed that the top chord section where no triangulation is present (diagonal ceiling) the truss depth is often inadequate for insulation. Hence the need to split the top chord as shown in the first drawing with the overhanging portion 2x4 or 2x6 and the upper top chord 2x8 or deeper.
          The piggyback is usually a small king post truss composed of 2x4 members all around. The ceiling web of a piggyback is often 2x6 but I've seen 2x4 as well.
          With more elaborate and longer spanning attic trusses I've even seen the bottom chord turned into an integrated floor truss where more depth is needed.
          The simplest attic truss only involves six members:
          http://img.archiexpo.com/images_ae/photo-g/drawing-software-drawing-architecture-2d-55617-3849475.jpg
          Then to further increase the complications added a raised heel, typically not needed though since this type of truss is generally 8/12 pitch or higher.
          If anyone has any other features or additional options that they would want to see included in an attic truss design please chime in. This one really intrigues me, much more challenging than the common truss types.
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
          • medeekM
            medeek
            The left and right overhangs can now be set independently, however the right overhang defaults to match the left overhang to help speed user input:
            http://design.medeek.com/images/MISC/TRUSS_SKETCHUP8.jpg
            I've also created a new page for the plugin with some basic documentation:
            404 - File or directory not found.
            (design.medeek.com)
            Just an FYI, the energy heels are enabled fully for the fink truss but not for any other truss type and the TRIAL version is actually not limited in any way. I will probably keep it that way until the plugin is significant enough to actually warrant charging for it.
            design.medeek.com
            • medeekM
              medeek
              I'm testing the attic truss. At the moment I've only got one configuration which is probably about right for an attic truss that spans about 24-28 feet. You can see below that pushing it out to span 36 feet is a bit of a stretch:
              http://design.medeek.com/images/MISC/TRUSS_SKETCHUP9.jpg
              The piggyback option is enabled by enforcing a max. height in the inputs.
              design.medeek.com
              • medeekM
                medeek
                This is the same truss I used in my 28'x48' garage:
                http://design.medeek.com/images/MISC/TRUSS_SKETCHUP10.jpg
                Now I need to work on the energy heel option for this truss type.
                design.medeek.com
                • medeekM
                  medeek
                  24' truss without a piggyback (Max. Height set to "NONE"). 2x6 TC, 2x10 BC, 2x4 overhangs. 12' attic width, 8'-1 3/4" attic height.
                  http://design.medeek.com/images/MISC/TRUSS_SKETCHUP11.jpg
                  design.medeek.com
                  • pbacotP
                    Nice work!
                    • medeekM
                      medeek
                      22' truss, notice the change in the web configurations as compared to the 24' truss.
                      http://design.medeek.com/images/MISC/TRUSS_SKETCHUP12.jpg
                      There still may be a few kinks to work out in the algorithm that determines how many webs to place but overall I'm pretty pleased with what I have so far.
                      I've officially added the attic truss updates to the plugin so they are now live.
                      design.medeek.com
                      • jujuJ
                        juju
                        Good work! Can you do it so the truss created is a grouped as a component (obviously other trusses generated are copies of the component).
                        • jujuJ
                          juju
                          @medeek said:
                          I think I get what you are asking here. Create the geometry of the first truss in the array as a component and then simply copy the original truss to make the others that way each truss can be manipulated as an entity. Let me look into this.
                          most trusses end up looking the same, if the need arises to modify one, it can be made unique and modified; this way it's faster to change things and also results in smaller file sizes
                          • medeekM
                            medeek
                            I think I get what you are asking here. Create the geometry of the first truss in the array as a component and then simply copy the original truss to make the others that way each truss can be manipulated as an entity yet if one truss is modified (the component) they will all be modified. Let me look into this.
                            design.medeek.com
                            • medeekM
                              medeek
                              Thank-you for bringing me up to speed. I'm still wrapping my head around SketchUp, as most of my experience is with AutoCAD. I didn't even realize that SketchUp had the ability for "blocks", very cool.
                              design.medeek.com
                              • studio43S
                                studio43
                                I purchased the plugin How do I download the most current version?
                                • medeekM
                                  medeek
                                  You can always grab the latest version in the Medeek Account Manager, Login and navigate to the plugin page, the download button will have the latest version.
                                  I'm working on the group/component issue and hopefully should have that up later today.
                                  SketchUp is actually pretty full featured, I'm pleasantly surprised.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Trusses are now created as components with each individual member of the truss a group. Arrays of trusses are multiple instances of the same component.
                                    I think this plugin may actually have some potential now.
                                    A couple more screenshots for fun. A well designed truss is a beautiful thing to behold:
                                    http://design.medeek.com/resources/images/truss_su5_800.jpg
                                    http://design.medeek.com/resources/images/truss_su6_800.jpg
                                    I really appreciate everyone's feedback, this has helped guide me in the right direction on all of this and improved my understanding of SketchUp immensely.
                                    design.medeek.com
                                    • jemagnussenJ
                                      jemagnussen
                                      Hi Medeek,
                                      Super plugin, just bought it... πŸ˜„
                                      Would you consider a metric version in the near future? It would be very helpfull to the "metric world" of designers.
                                      Best regards
                                      Jesper
                                      HP ZBook 15, Windows 10 64 bit
                                      Intel Core i7-6820HQ @ 2.70GHz
                                      32 GB Ram
                                      NVIDIA Quadro M2000M
                                      • jujuJ
                                        juju
                                        Jesper
                                        yes please! also the pitch of the truss in degrees instead of the x-in-12 system.
                                        • medeekM
                                          medeek
                                          @jemagnussen said:
                                          Hi Medeek,
                                          Best regards
                                          Jesper
                                          I don't think a metric version would be too hard to create. It would be cool if I could somehow have a configuration file of sorts so that imperial or metric could be semi-permanent setting that can be switched within SketchUp. Not really sure how to do this within the API but I will add that to the todo list.
                                          I'm assuming the units of interest would be millimeters, correct me if I'm wrong. I think I will also open up the pitch variable so any pitch can be chosen instead of limiting it. I would also like have it in the settings where someone can manage the default values and choose between degrees or x/12 for the pitch.
                                          I'm not really familiar with the metric lumber sizes. Would you want the variable completely open or limited to certain metric standard sizes?
                                          design.medeek.com
                                          • jujuJ
                                            juju
                                            can it not reference the sketchup session to see which units are being used and then use that?
                                            • 76
                                            • 77
                                            • 2 / 77
