    Reset axis of a component without changing its Position
    Scheduled Pinned Locked Moved Dynamic Components
    9 Posts 5 Posters 3.1k Views 5 Watching
      rnpatel9789
      I want to change the axis of the ComponentInstance. how I can change the axis of the component without changing the position of the component by code.
        pcmoor
        open the component, then right click on the axis (easier to pick outside the geometry) from the context menu pick an option. Say place, then place and orientate as required
        • ely862meE Offline
          ely862me
          Right click on the component, choose Change axes and proceed as desired.
          Elisei (sketchupper)
          Come and See EliseiDesign
            rnpatel9789
            I am doing this by using Sketchup Ruby API. Please if any one have any idea how to do this by code.
            • sdmitchS Offline
              sdmitch
              It seems that TIG and/or ThomThom had such a plugin. I have one also,Reset Component Origin. You can find it on my blog.
              http://sdmitch.blogspot.com/
                rnpatel9789
                Hello "sdmitch"
                I use your Plugin. its very good and useful plugin. I am doing same but I resetting the component and all it's entities Origin to global Origin. Please If you have any idea then guide.This is exactly I want to do.
                  driven
                  model.export ifc, renames each component to make it unique, and assigns the global origin...
                  model.import ifc, will bring them all back in but without materials...
                  if you collected the materials first, export all geometry to ifc, delete all geometry, import that 'new' ifc and reapply the materials...
                  just a thought...
                  • sdmitchS Offline
                    sdmitch
                    @rnpatel9789 said:
                    Hello "sdmitch"
                    I use your Plugin. its very good and useful plugin. I am doing same but I resetting the component and all it's entities Origin to global Origin. Please If you have any idea then guide.[attachment=0:4x9y18yz]<!-- ia0 -->axis.png<!-- ia0 -->[/attachment:4x9y18yz]
                    I think you will find the answer hear
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=43582%26amp;hilit=originate
                      rnpatel9789
                      @sdmitch said:
                      @rnpatel9789 said:
                      Hello "sdmitch"
                      I use your Plugin. its very good and useful plugin. I am doing same but I resetting the component and all it's entities Origin to global Origin. Please If you have any idea then guide.[attachment=0:2cxiw7c5]<!-- ia0 -->axis.png<!-- ia0 -->[/attachment:2cxiw7c5]
                      Thanks "sdmitch"
                      This is exactly what I am looking for. Thanks for the help. U really Doing great job.
