Sketchup 2015 Texture replacement misalignment
Changing/replacing textures causes the correct alignment of the texture to be lost. I need to replace textures in order to handle import/exports but replacing them in program causes the following to happen: (Please see the following gif animation of screen capture)
The only workaround to avoid this misalignment when replacing textures that I've worked out is to export to collada .dae, open the file in a text editor and manually editing the path to the new image file.
Hopefully you can fix this
Best Regards
Nicklas
http://nirklars.wordpress.com -
I think this migt be fixed if you triangulate faces
@JQL
In my case I would prefer to minimize the amount of edges as I'm importing the model into some other software that displays funny when theres many edges.Also wouldn't triangulation require some sort of plugin? If this is built into Sketchup were would I find it?
