Strange Pumpkin-Things
Autumn is coming
slowly but surely - these pumpkin-things reappear.
(as I was too late for Halloween last year, I post these two images now, which is
probably too early)The rendering was done with Shaderlight. As Shaderlight is not able to add different
properties to one material at the same time, I rendered 3 different material versions,
which I combined in Photoshop later...
Love it......why not try the free version of Twilight? I think you would prefer it to making several renders.
thank you Oli
meanwhile I own Twilight Pro (exactly for this reason) but still can not work well with it... -
You could upload your settings and maybe people could help you get this right? Twilight forum or here would be a good place to start.
I have found Twilight to be very easy after you get the hang of it. Takes some time to learn but definitely worth it IMO. I believe you will get much better results in much less time.
Love your model it's great!!
looks nice.
how did you extract the fineline wire layer? It looks nice and clear.
Thanks Jo-Ke
"...how did you extract the fineline wire layer?..."
The pumpkin is a smoothed group. I have set "Show Hidden Geometry". That´s basically all.
In the example above, I've used a high 2d-export resolution, which enhances that "fineline" effect.
I hope that's what you asked me?I add in a little mini tutorial how to model such a thing ...
Ah OK. Thank you. I did it the same way.
... Halloween again! so just a for fun re-render of my old orange and vicious vegetables above from 2015 [SkUp 2017 Make / Enscape]
Spooky !
