    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 170.4k Views 13 Watching
      Nuts & Bolts By Max Smirnov
      Image of the French version! πŸ˜‰
      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3509568_orig.jpg
        Dimension by Max Smirnov!
        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1660405_orig.jpg
        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/154532840.php
          Dimensions more and more effective! πŸ˜‰
          http://s6.postimg.org/778mmpsb5/dimdim2.gif
          http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=aceeaa3c3928686d25b9d3b0759d5ff6&filename=Arrow type 5_2.gif
          http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=6870661cdba89c3ad15275dec23120cc&filename=Arrow type 5.gif
            By Chri
            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=f72e2676526b216daf05a5a0b5161405&filename=1.gif
            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=33bd570392acb81860f07fb4ba879a44&filename=2.gif
              Angles arrived! πŸ˜‰
              and arc circles lenght !
              http://s6.postimg.org/n6qvafjwx/circle_no.jpg
              http://s6.postimg.org/gdqie5t3l/tricky.gif
                Dimension of curves! πŸ‘
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/752243595.php
                  Dimensions
                  Release candidate πŸ˜‰ v.99
                  Added:
                  Feet/Inches format
                  Angles > 180
                  Type names
                  Type 6 activates circular mode automatically
                    Exotic! πŸ˜„
                      HeightMap by Max Smirnov!
                      Transform image in volume! 😎
                      French version πŸ˜‰
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/2900845_orig.png
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/6593904_orig.jpg
                      By Max Smirnov
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/5387760_orig.png
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9473716_orig.jpg
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3966776_orig.jpg
                      • olisheaO Offline
                        olishea
                        Pilou, I just bought MOI3D! Time to get sculpting!
                        oli
                          @ Olishea
                          Bienvenue to the club! πŸ˜„
                          Have fun modeling with it! πŸ˜„
                          Sure a little less powerful than Rhino but... 😎
                          Don't hesitate for any questions!
                          Here or on the Moi forum where you have direct access with the creator Michael Gibson with very detailed answers!
                          And this is priceless! πŸ‘
                          Chipp Walters is fan of it! πŸ˜„
                          • olisheaO Offline
                            olishea
                            @pilou said:
                            @ Olishea
                            Thanks Pilou! And thanks for updating this thread, I keep watching the videos.
                            I am only using MOI for 3D printing projects, so I don't need Rhino....I got tired of trying to make SU do what I wanted. Even just simple intersections/booleans were sending me crazy.
                            I will surely be frequenting the forum with LOTS of questions haha!
                            oli
                              It's perfect for that and others materials! πŸ˜„
                              By Samuel Zeller from this creepy original image!
                              http://i.imgur.com/uY9Nuwf.png
                              Redrawing in Moi
                              http://i.imgur.com/jO3taec.jpg
                              Result! 😎
                              http://i.imgur.com/XEh3lLh.jpg
                              No Problem we are on the same Greenwich Time Zone! πŸ’š
                                Array3D by Max Smirnov
                                • olisheaO Offline
                                  olishea
                                  this guy is firing out some impressive plugins isnt he!
                                  oli
                                  • olisheaO Offline
                                    olishea
                                    the subdivide plugin is exactly what i needed!
                                    oli
                                      SUbdivision
                                      Will work fine with Bridge, Split πŸ˜‰
                                      New version of Array 3D : Random, Base/ target
                                      • olisheaO Offline
                                        olishea
                                        OK I got all the scripts installed, time to have some fun!
                                        I put the scripts in the command folder but I can't see them anywhere when I open MOI? There are no buttons/icons?
                                        I feel like a newb again! πŸ˜„
                                        oli
                                          You can make 2 things! πŸ˜„ (if you have a PC ? )
                                          Press Tab and write the name of the plugin!
                                          Here the subdiv's name script is _Subdiv_6 (no sensitive case)
                                          Or make a shortcut ! Menu Options (bottom screen) / ShortCuts
                                          Put in the left column any combinaison of keys
                                          and on the right column _Subdiv_6 πŸ€“
                                          Have fun modeling !
                                          • olisheaO Offline
                                            olishea
                                            OK I will have another go. I am using both PC and Mac...just to confuse you! πŸ˜„
                                            oli
                                            • 11
                                            • 5 / 11
