    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 199.0k Views 13 Watching
      Max Smirnov + Dinos has made a Volume/Mass Calculator! πŸ˜„
        Nuts & Bolts By Max Smirnov
        Image of the French version! πŸ˜‰
        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3509568_orig.jpg
          Dimension by Max Smirnov!
          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1660405_orig.jpg
          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/154532840.php
            Dimensions more and more effective! πŸ˜‰
            http://s6.postimg.org/778mmpsb5/dimdim2.gif
            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=aceeaa3c3928686d25b9d3b0759d5ff6&filename=Arrow type 5_2.gif
            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=6870661cdba89c3ad15275dec23120cc&filename=Arrow type 5.gif
              By Chri
              http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=f72e2676526b216daf05a5a0b5161405&filename=1.gif
              http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=33bd570392acb81860f07fb4ba879a44&filename=2.gif
                Angles arrived! πŸ˜‰
                and arc circles lenght !
                http://s6.postimg.org/n6qvafjwx/circle_no.jpg
                http://s6.postimg.org/gdqie5t3l/tricky.gif
                  Dimension of curves! πŸ‘
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/752243595.php
                    Dimensions
                    Release candidate πŸ˜‰ v.99
                    Added:
                    Feet/Inches format
                    Angles > 180
                    Type names
                    Type 6 activates circular mode automatically
                      Exotic! πŸ˜„
                        HeightMap by Max Smirnov!
                        Transform image in volume! 😎
                        French version πŸ˜‰
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/2900845_orig.png
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/6593904_orig.jpg
                        By Max Smirnov
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/5387760_orig.png
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9473716_orig.jpg
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3966776_orig.jpg
                        • olisheaO
                          olishea
                          Pilou, I just bought MOI3D! Time to get sculpting!
                          oli
                            @ Olishea
                            Bienvenue to the club! πŸ˜„
                            Have fun modeling with it! πŸ˜„
                            Sure a little less powerful than Rhino but... 😎
                            Don't hesitate for any questions!
                            Here or on the Moi forum where you have direct access with the creator Michael Gibson with very detailed answers!
                            And this is priceless! πŸ‘
                            Chipp Walters is fan of it! πŸ˜„
                            • olisheaO
                              olishea
                              @pilou said:
                              @ Olishea
                              Thanks Pilou! And thanks for updating this thread, I keep watching the videos.
                              I am only using MOI for 3D printing projects, so I don't need Rhino....I got tired of trying to make SU do what I wanted. Even just simple intersections/booleans were sending me crazy.
                              I will surely be frequenting the forum with LOTS of questions haha!
                              oli
                                It's perfect for that and others materials! πŸ˜„
                                By Samuel Zeller from this creepy original image!
                                http://i.imgur.com/uY9Nuwf.png
                                Redrawing in Moi
                                http://i.imgur.com/jO3taec.jpg
                                Result! 😎
                                http://i.imgur.com/XEh3lLh.jpg
                                No Problem we are on the same Greenwich Time Zone! πŸ’š
                                  Array3D by Max Smirnov
                                  • olisheaO
                                    olishea
                                    this guy is firing out some impressive plugins isnt he!
                                    oli
                                    • olisheaO
                                      olishea
                                      the subdivide plugin is exactly what i needed!
                                      oli
                                        SUbdivision
                                        Will work fine with Bridge, Split πŸ˜‰
                                        New version of Array 3D : Random, Base/ target
                                        • olisheaO
                                          olishea
                                          OK I got all the scripts installed, time to have some fun!
                                          I put the scripts in the command folder but I can't see them anywhere when I open MOI? There are no buttons/icons?
                                          I feel like a newb again! πŸ˜„
                                          oli
                                            You can make 2 things! πŸ˜„ (if you have a PC ? )
                                            Press Tab and write the name of the plugin!
                                            Here the subdiv's name script is _Subdiv_6 (no sensitive case)
                                            Or make a shortcut ! Menu Options (bottom screen) / ShortCuts
                                            Put in the left column any combinaison of keys
                                            and on the right column _Subdiv_6 πŸ€“
                                            Have fun modeling !
                                            • 11
                                            • 5 / 11
