    Repeating last action
    21 Posts 6 Posters 7.4k Views 6 Watching
      I never said a repeat function wouldn't be useful but for trying to accurately place a joist hanger, repeating a move operation in steps is a pretty lousy way to do it when it can easily be place accurately the first time it is moved.
      • KrisidiousK
        Krisidious
        Oh of course. I always use arrays when I can. More dependable than setting manually each anyway.
        By: Kristoff Rand
        • C
          Chessnut2
          I think I didn't use a very good example by talking about the joist hangers. I was talking about the initial placement of the first hanger after downloading it from 3D warehouse. But I got it done. I'm more interested in the general principle of "Repeat last action", no matter what that action was. I found a previous thread that explains what I'm getting at a little better than I did. http://sketchucation.com/forums/viewtopic.php?f=10%26amp;t=8427
            Even the placement of the initial component shouldn't require that you move it in tiny increments to place it.
            Unfortunately, often authors of components you find in the 3D Warehouse haven't bothered to make them easy to insert with precision. But you can modify the component to make it easily inserted.
            This is a joist hanger I drew some time ago. I adjusted the location of the component origin and axes so it could be dropped easily where it is needed without screwing around adjusting its location.
            It's also worth learning how to use the Move tool correctly. Although you can grab an entity anywhere with the Move tool, it is best to grab it by a point that will correspond to a point at the destination. That will beat trying to nudge the component into place.
            • C
              Chessnut2
              Great idea, Dave. How would I go about adjusting the location of the component origin and axes if I have a component that needs it? Thanks.
              • cottyC
                cotty
                You can have a look at Daves blog post about this topic here:
                http://www.finewoodworking.com/item/41609/component-insertion
                my SketchUp gallery
                  Take a look at this thing I did a few years ago. It should give you some ideas. The key thing is to position the component origin at the same point you'd use as a reference in placing the real object.
                  For the joist hanger I placed the origin so the inside of the hanger, where the joist would sit, is level with the bottom of the rim joist or beam and at its center. It would correspond to a pencil mark on your real rim joist or beam for centering the joist.
                  Edit to add: Cotty, you're quick! πŸ˜†
                  • BoxB
                    Right click on the component and select Change Axes then click the relevant location and directions.
                    • cottyC
                      cotty
                      Because the question was for you, I thought I can answer with your answer πŸ˜‰
                      my SketchUp gallery
                      • KrisidiousK
                        Krisidious
                        before you ask... Turning on component axis will help know where the axis is one comps you didn't make or forgot where you put it.
                        By: Kristoff Rand
                        • pbacotP
                          Another note that doesn't really address "repeating last action" request. There IS a "nudge" plugin at sMustard. I believe that's the one I've used, though I don't have it loaded now and don't recall paying for it... I think some people doing more intricate or free form models use it more. Since I do more rectilinear work there always seems to be good points to snap or align to.
                          • C
                            Chessnut2
                            Thanks to all for the helpful suggestions. I have saved all of them and am looking forward to trying them out (if I can ever catch up with my yard work). This has been a very positive first experience in this forum, and I appreciate the patience and helpfulness you've shown to a Newbie at sketchup. Thanks. Jim
                            • KrisidiousK
                              Krisidious
                              No problem... You'll find this community eager to help and very generous. I've seen a lot of forums in my life, this one stands out as a very active and helpful place.
                              By: Kristoff Rand
