    [REQ] Split Polygone
    9 Posts 4 Posters 904 Views 4 Watching
    • deaneauD Offline
      deaneau
      hello i search a plugin that split me faces in meter etc.
      when i try to render objects in lightup4sketchup and than export this to fbx. the result is more than bad.
      for example
      https://3dwarehouse.sketchup.com/model.html?id=5392a3ae2086324fda8f37ae9baf97
      this building i would have to split.
      faces vertical and horizontal
      V in Meter H in Meter.
      all selected faces
      Thank you
      • cottyC Offline
        cotty
        A splitting of all faces shouldn't be the solution to be able to render the model. Can you show us an image of the problem?
        my SketchUp gallery
        • deaneauD Offline
          deaneau
          hello cotty look here
          is an other model however the same problem
          https://www.light-up.co.uk/forum/viewtopic.php?f=2%26amp;t=1628
          the models you can find here
          3D Warehouse
          (3dwarehouse.sketchup.com)
          the texture resolution is the main problem..i would safe this in a game.
          here the sketchup result
          reimported
          https://drive.google.com/file/d/0B-Mb8dXCJwrRdEdidThvcmxYOGc/view?usp=sharing
          • sdmitchS Offline
            sdmitch
            for example
            all selected faces
            Thank you
            I think my old Divide by Material was created for this situation.
            http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=37598
            http://sdmitch.blogspot.com/
            • deaneauD Offline
              deaneau
              yes sometimes
              look here
              the lines going sometimes not to the end.
              • deaneauD Offline
                deaneau
                i would love to have pullman in the game engin.
                i have try this a long time with lightup for sketchup
                Adam (developer) have told me, i must split the buldings, to have better resolution.
                when i save this as player version the resolution is like i want...however when i save this as collada or fbx the reimport is very bad.
                i dont know the best solution..or i will misunderstand the workflow in lightup.
                i dont want switch to 3dsmax, blender and other progs.
                why an reimport.
                now i have a special export plugin for Trainz (new name T:ANE Trainz a new era)
                when i export to this game..all shadows will be lost
                • JQLJ Offline
                  JQL
                  deaneau
                  I don't use lightup but you have a very interesting topic here! Title is interesting, theme is interesting, the actual discussion is innovative and AdamB response at lightup was to the point.
                  However I think you are missing the real point here.
                  I think you don't need to split the buiding by material but rather by "building sections".
                  If you split the roof from the rest that will probably help, but what you should do is split the main building body from the smaller bodies, the left wing from the right wing, etc...
                  The idea is to have several BIG textures that cover BIG parts of the building, instead of one REALLY BIG texture that covers ALL building.
                  However there is no actual problem with that REALLY BIG texture. Ligthup seems to be capable of generating any texture of any size (I'm assuming from what I know from it, rather than from actually experimenting with it).
                  The problem is that Sketchup won't be able to display this REALLY BIG texture as for it to have nice detail it must be bigger than 4K and 4k (4096px X 4096px) is the maximum that sketchup can handle in a single texture.
                  www.casca.pt
                  Visit us on facebook!
                  • deaneauD Offline
                    deaneau
                    yes i agree
                    what i have try.
                    i have try to seperate all parts in this building.
                    [Brick_Antique] in one group
                    roof in a secound group etc.
                    the problem is.. when i reimport the fbx or collada [Brick_Antique] and [Brick_Antique] copy
                    have different resolutions.
                    in a game i need a little bit shadows in the corners . the render engine doesnt provide shadows.
                    my fear is i must buy 3dmax and the flatiron plugin..to do this.
                    for freeware parts its to expansive ๐Ÿ˜ž
                    • JQLJ Offline
                      JQL
                      Try blender
                      www.casca.pt
