    Project Video Scanner
    28 Posts 4 Posters 14.5k Views 4 Watching
    • KrisidiousK Offline
      Krisidious
      Ahhb you meant the Go Pro... Pretty sure you would only need the one Hero unit to use this program.
      By: Kristoff Rand
      • jujuJ Offline
        juju
        aaaargh! the PVS download just isn't happening for me, has anybody downloaded the 359MB ZIP file and is able to host it on a reliable/fast service or send me a dropbox (or similar) link?
          Krisidious
          (www.aboveallhouseplans.com)
          don't forget small exe updates on that page and the Xvid codec.
          By: Kristoff Rand
          • jujuJ Offline
            juju
            Thanks Kris, appreciated. Looks like the download was finally successful from the google+ source.
            Yep, got the codecs (Xvid and HuffyUV) already, looks like the HuffyUV (v2.1.1 - don't get 2.2 as it seems to be problematic) codec has 64-bit and multi-threaded variants, got those as well to test.
            I have a number of questions on this system, hopefully I can figure it out along the way. I'm hoping the product is good enough to offer this as a service.
            Remember to download the programs referred to in the blog post from 2 April 2014.
            I wonder when the version 2 will see the light of day, in the blog post of 20 July 2015 there is a reference to it.
            • jujuJ Offline
              juju
              for information, PLY files can be read with Blender and Meshlab (amongst others) as well
              FYI new blogpost, seems like PVS version 2 actively being worked on, seems like some of the requests are things I'd like to see as well...
                kaas
                I realized there might be one 'small' problem.. these kind of applications create meshes with a very high polycount. Something like 100k to several millions of triangles for single scan objects. Importing those meshes into Sketchup will at least slow Sketchup down bigtime or will even fail.
                Too bad Trimble Scan Explorer only reads their own file format and no commonly used point cloud file types.
                edit: I see JuJu already said the same in the top post.
                • JQLJ Offline
                  JQL
                  How did I miss this post!
                  Do you think a polygon reducing app like Simplygon could be used with this or is it simply too much polygons for that to handle?
                  www.casca.pt
                  Visit us on facebook!
                    Krisidious
                    You'll work in sections to either rebuild using it as a base or if you have the right tools to perhaps reduce and rebuild the mesh automatically. I would be happy just to get the rough model.
                    By: Kristoff Rand
                      kaas
                      Excited about these techniques, I did some tests with VisualSFM & CMPMVS.
                      You don't need a stereo camera and a normal camera will do just fine. Just need a lot of overlapping pictures. Take a video and export every 10th frame as a picture worked fine as well.
                      Tried it on the exterior of a nearby mill. Calculation of the 3d model using these programs took several hours - 123D created the 3d model in several minutes but it had less detail (64k vertices vs 1.1M vertices) and the textures looked blurry.
                      The end result resembles the building but it's not really useful to me (yet):
                      • Nothing is flat in the 3d model - even if the real thing has flat surfaces. That will make rebuilding a low poly object in SketchUp difficult - how to decide which bump/point of the model to snap to??
                      • It's hard to get the (textured) model into SketchUp. Meshlab opens the model in seconds. Blender in a minute, SketchUp's ply importer is already busy for 3 hours and I'm not sure if it will ever finish. Maybe have to split up the large model in Blender into smaller ones and rebuild it in SketchUp?!
                      Also:
                      • reflective surfaces don't work well (found that one out 'scanning' a table with some objects on it)
                      • the software needs 'anchors' to match the individual frames. For more large uniform planes (ceiling, white walls etc) the software can't find matches so that results in large gaps.
                      Still, it's fun to see the software build something 3d out of pictures.
                        Krisidious
                        You're blowing my doors off...
                        By: Kristoff Rand
                          kaas
                          I don't think thats a good thing or...? Kristoff, I'm sorry if I hijacked your thread. I just thought, these programs and their results were related and thus relevant.
                          • jujuJ Offline
                            juju
                            Also:
                            can you share some details?
                            • which cameras used (also, FOV lense specs)
                            • what resolution
                            • size of *.ply files
                            • how long did these take to process
                            • what is you system specification
                            • anything else relevant that you have not previously mentioned...
                              kaas
                              Hi Juju, here's some answers:
                              • which cameras used (also, FOV lense specs) -> I tried a Olympus SP600UZ and that worked fine. For the mill I used a 1080p video, made with a Samsung Galaxy S3 - used Blender to convert every 10th frame of the video to a single image.
                              • what resolution -> 1920x1080
                              • size of *.ply files -> high quality file was 95MB, low quality was 8.9 MB
                              • how long did these take to process -> I think it was four hours for both programs
                              • what is you system specification -> Win 7 X64 - 3.4Ghz (I5 3570) - 8GB - GTX560TI
                              • anything else relevant that you have not previously mentioned -> its fun. Just try shooting some pictures and feed it into those programs and off you go.
                              to get you going, maybe have a look at some youtube videos. I don't have the link at the moment but there are some showing these two programs after another.
                                Krisidious
                                Oh it's a good thing... You're doing just fine. add all you want. It's not my thread... It's community property. I'm loving that you're testing.
                                By: Kristoff Rand
                                • JQLJ Offline
                                  JQL
                                  What software did you use to do that?
                                  www.casca.pt
                                    kaas
                                    I think I used Blender
                                    • jujuJ Offline
                                      juju
                                      Progress Update!
                                      http://projectvideoscanner.blogspot.co.za/
                                      • 2 / 2
