    Viewports not lining up from different scenes (same scale)
    layout
    18 Posts 6 Posters 4.7k Views 6 Watching
    • vaprossV
      vapross
      You can test the alignment issue by simply clicking through the scenes in SU. If the model jumps around, it will do the same thing in LO.
      I talk about it here at the 4:00 mark:
      https://www.youtube.com/watch?v=jK8lusVdHTQ
      Sonder, thank you for the answer
      Here is the video where I perform the entire process - https://www.dropbox.com/s/h05n6f0bzv53dlb/SU-LO%20jumping%20issue%202015-07-14%2008-04-09-240.avi?dl=0
      I do think this is the bug, maybe caused by photomatched scenes. Although I tried a stacking (actually it was yours) method for the first time - before it I have being considering it as mauvais ton.
      By the way, thank you for your techniques, they are inspiring!
      SketchUp 2015 Pro
      • vaprossV
        vapross
        I tested other models without photomatch scenes - the same issue. Switching from raster to vector leads to kinda "zoomed" view. So "jumping" is not a correct word - it's certainly "zoomed"
        It's like something went "broken" - never noticed this bug
        SketchUp 2015 Pro
        • pbacotP
          I know in SU the photomatch scene is special and you can't really replicate it. The perspective you set up has it's own special camera settings. No clue why vector views in LO would be the cause of this. I bet this is a rare operation. The testers probably never even tried this use of Photomatch.
          That said, this discussion started with problems using scaled scenes in LO with parallel projection, which is not a setting photomatch uses.
          • JQLJ
            JQL
            Use thomthom camera tools to update cameras. Match photo introduces a frame ratio that reads differently in some scenarios.
            Yu can replicate a camera from a photomatch scene in another scene by using advanced scene settings in window>scenes:
            1-untick "camera position" in the incorrect scene;
            2-double click the ,atch photo scene;
            3-click once in the incorrect scene name;
            4-tick "camera position" back on and te incorrect scene inherits the match photo "scene position"
            hope this helps
            www.casca.pt
            Visit us on facebook!
            • vaprossV
              vapross
              This kind of wireframe mass-models is typical for visual analysis - I use SU for this purpose
              SketchUp 2015 Pro
              • vaprossV
                vapross
                Thank you for this tip. However there are no issues with raster view with Photomatch scenes and only vector one becomes zoomed.
                Actually, I tested other models without Photomatch scenes at all - the same issue, vector becomes zoomed
                Maybe I should report a bug
                SketchUp 2015 Pro
                • vaprossV
                  vapross
                  When I switch to ortho scenes, vector viewports perform normally, and here we have the composing approach.
                  Guys, can you try the same operation with generic perspective scenes?
                  SketchUp 2015 Pro
                  • pbacotP
                    I just mean the photomatch and LO overlay use. I think the usual use is to create a model from the photo. What it has to do with wireframe and needing to overlay scenes IDK, but I still think this would be a scenario they didn't think of testing, all the way into the overlay in LO. So they wouldn't find this deficiency (can't say if it's a bug-- probably just something the program doesn't do).
                    I wanted to try it out, but I can't follow what the steps you use are.
                    • JQLJ
                      JQL
                      I get no zoom factor when changing a perspective viewport from Raster to Vector or Hybrid.
                      Why don't you share a model here?
                      www.casca.pt
                      • vaprossV
                        vapross
                        Oops, missed your answers here.
                        I tested once again with generic perspectives and vector view, and now it's ok. However, the photomatch scenes keep on zooming with vectorview in LO - i think it depends on the distortion of axis when photomatching (some scenes have wide FOV). Well, got to test it further, because it would be a really time saving method (even now).
                        Here is the model (SU 😎 - https://www.dropbox.com/s/joxh1d9y97qqb92/3047-site_2015-07-11-v3.skp?dl=0 (soon will be removed)
                        SketchUp 2015 Pro
