    WARM MODERN
    11 Posts 5 Posters 1.1k Views 5 Watching
      serrot
      In reference to the tittle, I wanted to do a modern dwelling but in warmer tones rather than the usual stark white.
      Comments welcome.
      upper level master suite/den
      middle level living/kitchen/sleeping
      lower level guest/movie theatre/gym
      front view
      front view 2
      back view
      living room from entry stairs
      dinning room
      kitchen
      family room
      upper hallway leading to den
      master bedroom
      master bath
      ground level bar/home theatre
      ground level gym
      • DanielD
        Daniel
        Very nicely done, Hector!
        My avatar is an anachronism.
          serrot
          Thank you Daniel, this one was a quickie but not challenging enough when square footage is not an issue.
          • hellnbakH
            hellnbak
            Nicely laid out.
            My only criticism would be the extremely steep entrance to the garage
            • RichardR
              Richard
              Another nice looking project mate! My 2 cents from a design side without too much detail:
              1. I like the material breaks to the exterior, but I'm almost wanting a greater contrast in colour or lighter weights to break the masses.
              2. The entry for the scale and grandeur of the home seems somewhat understated and exposed.
              3. The ensuite to the main looks to be out of position in regard to the stacking of services.
              4. The bedrooms (2,3 and study) seem out of scale with the overall opulence of the home and in particular with that afforded the guest bedrooms.
              5. The lower level storeroom door can be rearranged to increase space.
              BUILTBRAND.COM.AU
                serrot
                thanks for the imput...I did try lighter hews of gray but settled on the warm tones of this one.
                the simple entry is designed that way so you enter through a narrow low ceiling area, them move up the stairs to finally come into the double height glazed living space ( drama )
                I thought about placing the master ensuite where the master closet is located but this would mean the master bath window would face the neighbors.
                • RichardR
                  Richard
                  Another suggestion - pull the master suite door up to the elevator so that hall light penetrates into the bedroom. This would also allow you to pull the door of the ensuite around into that hall so getting up to piss in the night doesn't throw light into the bedroom and bog booms aren't so audible. you could also open the robe into that hall for more light sharing.
                  BUILTBRAND.COM.AU
                    serrot
                    What are "Bog booms" ???
                    • tademaT
                      tadema
                      "What are "Bog booms" ???" πŸ˜† Think I've just cracked a rib laughing so much.
                      I'm sure Richard will answer in a way only Richard can 😐
                      John
                      • RichardR
                        Richard
                        lol! I reckon the "bog booms aren't so audible" is a dead give away! Picture the explosive power of methane!
                        I guess there are two types, one from the delivery end, and one from the receiving end! The latter, that moment that feels like you're on the bidet only to recall that you never installed one, ewww!
                        BUILTBRAND.COM.AU
                          serrot
                          LOL...Got it, never heard it called that before at least not in California or in Saint Petersburg Fl.
