    Airbox Problems
    15 Posts 3 Posters 1.3k Views 3 Watching
    • TeigT
      Teig
      One of these days i might get the hang of this program πŸ˜›
      Thanks very much pbacot! What was wrong? Live and learn and all that.
      • TeigT
        Teig
        The other problem: I need to expand the internal volume: on the whole, more is better in airboxes. I have plenty of room behind the carburettor so the plan is to expand in this direction:
        I wouldn't be on here asking for help if I hadn't struggled for a week with this, how do I move the external faces of the wall as well as the internal faces so keeping it solid and wall thickness of 4mm? (The carburettor goes in the gap between the two 'extrusions'.)
        I tell you, it's got me stumped! I thought I could draw the lines on the internal walls and push them out to meet the externals but it's not an elegant way of doing things, I thought someone here would have a better way?
        • BoxB
          Do you mean like this?
          • TeigT
            Teig
            Kerching! Yes, well, no, but I can maybe do what I want that way. I need to leave room for the carb to go in the gap. I'll have a quick go at that. Back in a minute or ten.
            • TeigT
              Teig
              You made selecting that wall look so easy! After faffing about unselecting a lot of walls and edges I managed to expand that wall but am left with the problem of pushing that carb section of the wall back 100mm.
              Airbox v6.skp
              • TeigT
                Teig
                When you selected the front edge, how did you make it snap to just the front edge? Or is that the magic of the GIFF and you used the same technique as me? πŸ˜›
                • BoxB
                  No it wasn't just the front edge, it was the complete top down to the edge at the back. By using the solid selection fence it only selects what's inside the box, whereas the dotted fence selects everything it touches.
                  I've adjusted your model, too tired to try and gif it.
                  Airbox v6box.skp
                  • TeigT
                    Teig
                    "solid selection fence" something else to Google...
                    Thanks again Box, you're a star. Off to bed now young man!
                    If you ever feel the urge though, I'd love to know how you did it.
                    • BoxB
                      By Solid selection fence I mean the difference between selecting from left to right and right to left.
                      Have a look at this gif and notice the dotted selection fence and the solid selection fence and what they select. Left to right creates a solid framed box which selects everything entirely within that box. Right to left is a dotted line box that selects everything it touches.
                      So in the earlier selection I when left to right and stayed above the back edge line so it selected the whole top.
                      I'm afraid it's not off to bed yet, there is pub time to deal with.
                      • pbacotP
                        What was wrong? The "flap" you mentioned yourself on the inside wall surface. Really just needed erasing all the back inside--the short surface, and creating a a vertical surface, erase what doesn't belong.
                        • TeigT
                          Teig
                          In all the time playing with SU I've never realised the selection 'fence' does that! 😳 Very useful to know thanks.
