    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 263.6k Views 37 Watching
    • U
      unclex
      0.12.4 work fine
      but 13.0 cannot work like 12.4 @su2015x64pro
      such as several box could be converted to wall&floor by just one click using 12.4
      but 13.0, some faces cannot be converted
      • brewskyB
        brewsky
        @unclex said:
        0.12.4 work fine
        Can you send me an example model (PM?), then I'll check it out.
        In my own tests the new 0.13.0 worked on more faces than 0.12.4, so I'm curious... 😄
        Thanks for posting the issue!
        Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
        • U
          unclex
          Now I Know What Happened
          12.4 can work under customized catalogue, 13.0 not
          and 13.0, if you have cleaned bim information, you must run SU again, Using File→New could not worked, isn't ?
          BimToolBoxTest.7z
          • brewskyB
            brewsky
            Thanks! You're probably right, I also had some trouble changing between models without restarting SU a couple of weeks ago, I thought I fixed that. I will check it out!
            • brewskyB
              brewsky
              Okay, I completely uprooted the observers that keep track of the active entities, and it seems much more solid now 😄
              Can you give it a try before I upload it into the PluginStore?
              • brewskyB
                brewsky
                New version 0.13.2 online!
                Feels much more solid due to improved observers 😄
                • T
                  twillm
                  Is bim-tools compatible with mac version of sketchup 2015.
                  I attempted to install using sketchucation plugin store v2.6.1
                  Received error messageError Loading File /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb
                  Error: #<NoMethodError: undefined method strip' for nil:NilClass> /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:40:in block in parse_config'
                  /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:34:in each_line' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:34:in parse_config'
                  /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:23:in initialize' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/clsBtProject.rb:43:in new'
                  /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/clsBtProject.rb:43:in initialize' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:44:in new'
                  /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:44:in <module:BimTools>' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:19:in module:Brewsky'
                  /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:18:in <top (required)>' /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
                  /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:48:in register_extension'
                  /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:48:in <module:BimTools>' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:35:in module:Brewsky'
                  /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:31:in `<top (required)>'
                  Any suggestions would be most welcome
                  • brewskyB
                    brewsky
                    Thanks for posting this issue!
                    I believe it used to work on Mac, but have never been able to test it myself.
                    I will try to borrow a Mac and check it out 😉
                    The error is related to reading the config file, did you by any chance modify that file?
                    • T
                      twillm
                      Thank you for the response.
                      I didn't make any changes to files.
                      Deleted plugin this morning and reinstalled through sketchucation plugin with similar error message.
                        steve69
                        Unpacked files in plugins folder..
                        bim-tools.rb
                        bim-tools folder
                        @ Sku 7.1 startup
                        Error Loading File C:/Program Files/Google/Google SketchUp 7/Plugins/bim-tools/bim-tools_loader.rb
                        No such file to load -- pathnameError Loading File bim-tools.rb
                        No such file to load -- pathnameError Loading File bim-tools_loader.rb
                        undefined method `strip' for nil:NilClass
                        • Dan RathbunD
                          Dan Rathbun
                          @steve69 said:
                          @ Sku 7.1 startup
                          Really? 6 year old version and 15 releases behind ? (Trimble has long stopped supporting v7.x.)
                          Does BIM-Tools even support v7.1 ?
                          I'm not here much anymore.
                          • Dan RathbunD
                            Dan Rathbun
                            @Jan:
                            Single argument String subscripts are one of the breaking changes from Ruby 1.8 to 2.0.
                            The workaround is line[0,1], ie., [position, length] or give a range [0..0]
                            The single argument will definitely not work in SU2013 and earlier, as Ruby 1.8 returns an integer for the character's position in the ASCII character set.
                            • brewskyB
                              brewsky
                              @steve69 said:
                              @ Sku 7.1 startup
                              Hmmm I have not been testing on old versions, I'll check it out, maybe it's easily fixed... 😉
                              • brewskyB
                                brewsky
                                Hi Dan, thanks for helping out! 😄 That fixes one error! 😉
                                SketchUp even seems to drops out here before the strip-string, on requiring the "pathname" module.
                                I guess that's one of the modules that was missing in the old 1.8 stripped ruby environment.
                                still some more warnings to wade through I see ...
                                • Dan RathbunD
                                  Dan Rathbun
                                  Yes well it is a Standard Library class (derived from String, I believe.) And the Standard Ruby Library was not included until SketchUp 2014 (when it was released with Ruby 2.0.0.)
                                  Before that, SketchUp was released with only the Core interpreter.
                                  SketchUp 7.1 for Windows users can copy the Ruby 1.8.6-p287 DLL from v8 or v2013, back to the v7 program folder, or get it here at SketchUcation:
                                  ruby-1.8.6-p287-i386-mswin32-dll.zip
                                  (SketchUp 6 & 7 for Windows was released with the ancient Ruby v1.8.0 [initial release] of the Ruby interpreter.)
                                  I have packaged the Ruby 1.8.6-p287 Standard Library up for Windows ONLY, as a normal RBZ SketchUp Extension archive. (It installs into a sub-folder as a plugin would.)
                                  It only loads for SketchUp version 8..13 (or 7.x if the DLL is manually upgraded.)
                                  https://github.com/DanRathbun/sketchup-ruby186-stdlib-extension/releases/tag/1
                                  • brewskyB
                                    brewsky
                                    I've been able to remove the dependency on pathname and it's running now on SU7 and SU8.
                                    Although one (probably showstopper) problem remains. Auto-updating of modified objects does not work on SU7 because the "EntitiesObserver.onElementModified" method was added in SU8.
                                    That means updating geometry must be done manually by disabling and re-enabling the observers (red/green button).
                                    New version added to this post, I will add it to the plugin store when I also fixed the MAC issue, but that has to wait a little until I get my hands on a MAC 😉
                                    bim-tools-0.13.3.rbz
                                    • brewskyB
                                      brewsky
                                      Hi Dan,
                                      I also removed a "tap"-call because it was added in ruby 1.9.
                                      Would you consider this a good substitute? Or would it be much slower?
                                      hash = {}.tap{ |r| bt_entities.each{ |ent| ent.properties_editable.each{ |k,v| (r[k]||=[]) << v } } }
                                      hash = bt_entities.inject({}) {|h,ent| ent.properties_editable.each{ |k,v| (h[k]||=[]) << v}; h}
                                      something I borrowed from:
                                      http://stackoverflow.com/questions/5490952/merge-array-of-hashes-to-get-hash-of-arrays-of-values
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Well the 1st thing I had to do is proper indentation:
                                        hash = {}.tap {|r|
                                          bt_entities.each {|ent|
                                            ent.properties_editable.each {|k,v|
                                              (r[k]||=[]) << v
                                        and
                                            (h[k]||=[]) << v
                                          h
                                        Then the 2nd thing, is that Ruby is designed for easily read and understood code. (Why I like it so much.)
                                        I do not understand why some coders go out of their way, to write minimalist hard to read and understand code. Come back 3 years from now and see if the coder remembers what the code is supposed to do, without spending a half hour consulting method documentation, etc.
                                        3. Re., inject(), in the past in pre-YARV Ruby, it was notoriously slow. But things have gotten better.
                                        4. My opinion of tap() is that it might be nifty, but it will serve mostly to contribute to ugly code.
                                        5. I'd just do it simple like this:
                                        hash = Hash;;new {|h,key| h[key]=[] }
                                          ent.properties_editable.each {|k,v| hash[k] << v }
                                        • brewskyB
                                          brewsky
                                          LOL Thank you very much! I totally agree with you. It indeed seemed a nifty piece of code I found on stackoverflow, but every time I needed to edit it, it took me half an hour to re-interpret it(and I'm still not 100% sure how the tap works).
                                          Now you write it out it does not seem so difficult anymore 😄
                                          I should have added the indentation myself the moment I tried to understand what it did 😕
                                          • Dan RathbunD
                                            Dan Rathbun
                                            @brewsky said:
                                            ... and I'm still not 100% sure how the tap works 😕
                                            It is very similar to the map! / collect! methods for Enumerable objects. So you could use map! in place of tap for arrays.
                                            But, in Ruby 2.0, tap is defined in Object, not just enumerable classes, so every object can "tap" into a block of code that can change and then return itself.
                                            So tap is kind of like a general purpose "bang" method, but designed for especially for chaining so it always returns it's receiver object, whether it made changes or not. ("Bang" methods usually return nil when they do not make changes to the receiver, making them unsuitable for method chaining.)
                                            • 11
                                            • 10 / 11
