    Voronoi Pattern Tutorial
    20 Posts 7 Posters 11.5k Views 7 Watching
    • olisheaO
      olishea
      chipp: You may want to look at this tutorial....you can "voronoi" any model in meshlab. Start off with the SU model and then drape the voronoi over your model! It's awesome and you can do very complex models.
      The problem with shape bender in SU is that you can only ever achieve a 180 degree model....in meshlab you can achieve a full voronoi pattern all round your model.
      Some models I made starting off with a simple SU model:
      http://i654.photobucket.com/albums/uu269/olishea/ScreenShot2014-05-29at004625_zpsbd970506.png
      http://i654.photobucket.com/albums/uu269/olishea/ScreenShot2014-05-29at013657_zps6d1fe97f.png
      http://i654.photobucket.com/albums/uu269/olishea/ScreenShot2014-05-29at014032_zps9b601b61.png
      oli
      • chippwaltersC
        chippwalters
        Thanks! GMTA. I literally was just watching that tutorial when your post notification came through! Crazy!
        Is there any other workflow tutes on Meshlab and Voronoi? Thanks for sharing!
        Currently working with Cross-Reality technologies
        • olisheaO
          olishea
          Yes....
          Error 404 (Not Found)!!1
          (meshlabstuff.blogspot.de)
          Same process pretty much. I have tried and tried and tried to do all this in SU but it's impossible. Of course you can do a flat surface but rarely is that required unless for a facade.
          The topology isn't amazing using the meshlab technique.....but it depends on the model. You can 3D print the meshlab model no problems though and tiny defects in the topology don't even show up.
          oli
          • cottyC
            cotty
            Another fast way to delete the unwanted edges (merge faces, erase stray edges)...
            Again a very nice tutorial, thank you.
            my SketchUp gallery
            • chippwaltersC
              chippwalters
              Thanks for sharing. Much easier!
              • cottyC
                cotty
                Combination of Voronoi and Flowify tutorials...
                Edit: added rendered version
                my SketchUp gallery
                  driven
                  @chippwalters said:
                  ... Meshlab and Voronoi?
                  it could be possible, to auto generate from SU using meshlabserver
                  I've had some success in the past, I'll have a play...
                  • pbacotP
                    Though I might be unlikely to use voronoi patterns like this, the tuts are engaging and include some great tips in general. Nice work! I might use the stepping stones method.
                    How about use of "remove lonely vertices" and Vertex tools "merge close vertices" (with distance input) to help prepare the pattern?
                      I have made this in the long past! 😉
                      Projections (Points) by Didier Bur)
                      Voronoï XY By Mattc
                      Delauney3.rb by Tig
                      Lattice Maker by Tig
                      Selection Toys by Thomthom
                      Random Painter by Chris Fullmer
                      http://www.3dsaloon.fr/phpbb3/download/file.php?id=3741&mode=view
                      http://www.3dsaloon.fr/phpbb3/download/file.php?id=3743
                      http://www.3dsaloon.fr/phpbb3/download/file.php?id=3738
                      http://www.3dsaloon.fr/phpbb3/download/file.php?id=3667
                        @Chipp
                        What is the hidden advantage to use the cross lines help cursor ?
                        • chippwaltersC
                          chippwalters
                          @pilou said:
                          @Chipp
                          I was introduced to this technique as I watched ixlrxli's videos, and so I tried it and liked it. It's especially helpful when using the move tool, as it's easier to snap to an axis. It also helps me eyeball proportions and line up drawings. I tried it and liked it.
                            Thx for the info! 😄
                            @Olishea
                            About Meshlab : does it possible to make a "macro" for avoid to make numerous clics on the different menus shown on the video ?
                            • chippwaltersC
                              chippwalters
                              @pilou said:
                              @Olishea
                              If I'm not mistaking, that's exactly what meshserver is.
                                driven
                                meshlabserver allows you to save a series of filters [that you select in Meslab] as a file and then apply that resulting .mlx on an input file from a command line script...
                                I have run these from ruby inside SU...
                                the PC version is better supported then on mac...
                                • chippwaltersC
                                  chippwalters
                                  [attachment=1:bb4e9vi0]<!-- ia1 -->voroflow.jpg<!-- ia1 -->[/attachment:bb4e9vi0]
                                  [attachment=0:bb4e9vi0]<!-- ia0 -->voroflow_render.jpg<!-- ia0 -->[/attachment:bb4e9vi0]
                                  I was trying to think of a way to use flowify for this tutorial, but didn't come up with a 'product.' Yours is great!
