    Dynamic components - help
    Scheduled Pinned Locked Moved Dynamic Components
    7 Posts 2 Posters 2.2k Views 2 Watching
      Kevinengelbrecht
      New to DC and would like to do compound animation in one "on click".Attached pics show what i want to do. On one click, lower the arm but keep the BJoint and monitor on O degrees on the Y axis. Right now the BJoint and monitor are separate components. I can group them into one component and rotate -25 degrees, but it takes 2 clicks.
      Any help would BE APPRECIATED.Thanks
      lowered
      Bjoint and monitor
        pcmoor
        You can use ; semicolon to place multiple events on one onclick line
        onclick may contain animate("RotZ",0,-90) ; set("a". 4,5,8,6) ; animateslow("X" 20,200) and so on. onclick must be triggered at the same nested level, otherwise its parent or container will always precede and stop the lower onclicks
        you can get more than one attribute to be effected by a single onclick event by using a common variable
        steps...........0
        onclick .........aminateslow("steps", 0,100)
        rotz...........=if(steps>50, 90,0)
        X..............=steps/2
        Y............=steps*steps
        examples attached
        the plumb line remains true
        return.skp
        conditional movement.skp
          pcmoor
          combined movement with click on arm. however its likely you would want to rotate screen and whole arm, plus other ideas. As the trigger points need to be on one level whereas movement operations can involve combining components for ease of operation it is suggested you create a control pad.
          see attached files
          articulating-arm-8.skp
          articulating-arm with remote-8.skp
            Kevinengelbrecht
            pc, thanks, your explanation with the semicolon worked. Added the following
            ;animate("bjointmon!RotY"0,-15,-25)
            I had done this before but didnt have the ! after the component. Plus added an extra step. Uploaded the new model to the warehouse.
            Thanks again !!! <didnt forget the exclamation point)
            Now, need to swivel/rotate just the monitor. Will work on that another day...
              Kevinengelbrecht
              Nice set up with the remote pad, you're a step ahead of me wanting to rotate the monitor.
              I only get an hour or so a day to work on this, so its slow going. Will take your idea of a control pad and fine tune it. Forgot about rotating the whole arm around the room, I was using the SU rotate tool to do that, but it even better if i can do in DC.
                Kevinengelbrecht
                By the way, if anyone want to mess with it, its in the 3D warehouse. heres the link
                3D Warehouse
                (3dwarehouse.sketchup.com)
                I have searched other help forums and found that there is an IF(animate_me)...
                command in there but i just cant get it to work.
                  Kevinengelbrecht
                  Thanks pcmoor, i will download the samples and try at work later today. BTW i posted a link to the 3Dwarehouse where my model is, but it didnt show up. Ill try it again,
                  3D Warehouse
                  Thanks again
