    PolygonMesh triangulation... ?
    23 Posts 6 Posters 4.0k Views 6 Watching
      @oajfh said:
      Hi.
      def self.incomplete_make_mesh faces puts "Mesh creation started" mesh = Geom::PolygonMesh.new faces.each_with_index do |face,index| if face.is_a? Sketchup::Face temp_mesh = face.mesh mesh.add_polygon(temp_mesh.points) end end puts 'Polygons : '+ mesh.polygons.to_s puts 'Points : '+ mesh.points.to_s return mesh end
      When you obtain a PolygonMesh from a Face it's just a copy of the triangulation data. It doesn't relate to the face any more. adding polygons won't add more faces.
      You can add individual faces using Entities.add_face - though it's generally slower, but an easier interface. What's best for you really depend on what the final product is.
      • Dan RathbunD
        Dan Rathbun
        @jim said:
        A PolygonMesh object is not geometry like Faces and Edges are. It is simply a convenient data container for points and "polygons."
        @oajfh: This is one aspect of the API that is confusing to new coders.
        All the classes wrapped in the Geom module, are actually NOT model geometry objects, ... they are virtual geometry helper objects.
        So the wrapping module name was really a bad choice.
        Only Sketchup::Enitity subclasses can be put in the model database, and only subclasses of it's child Sketchup::Drawingelement class, can be put into the model's Sketchup::Entities collection.
        As an example, Geom::Point3d class instances are virtual helper objects, and do not actually exist in the model. Their counterpart that does exist in the model, are instances of Sketchup::Vertex. (Edge and face objects have or share vertices, not 3D points.)
        So try to remember that the Geom module (and it's classes) are for helping to create model geometry, but are themselves virtual geometry helpers.
        I'm not here much anymore.
        • O
          oajfh
          Thanks for the replies everyone.
          What you said about Geom makes sense. However, the way I intend to use it is as a mesh exporter, so I would be constructing meshes from existing geometry, and wouldn't be adding the meshes to the model.
          With the way PolygonMesh works it seems that if I want a classic "points, face indexes and face point indexes" format I am going to have to reconstruct that format from the various PolygonMeshes I will have obtained.
          Won't that be slightly long in terms of number of calculations required ? Or is there a straightforward way to do it ?
            If you are using it for a mesh exporter you might want to create your own helper that is better suited for your specific need.
            • Dan RathbunD
              Dan Rathbun
              Here is an example that might give some idea(s):
              obj can be the model, a group or component definition. (Anything that has an entities method and returns a reference to it's collection of entities.)
              <span class="syntaxdefault">  obj </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">active_model<br />  eset </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> obj</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br /><br />  </span><span class="syntaxcomment"># Use hash for speed and<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#  because keys are unique.<br /></span><span class="syntaxdefault">  pset </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{}<br /></span><span class="syntaxdefault">  <br />  </span><span class="syntaxcomment"># Use for...in because it does not create a<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">#  new scope with each iteration, (ie, speed!)<br /></span><span class="syntaxdefault">  for f in eset</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    for v in f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices<br />      pset</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">]=</span><span class="syntaxdefault"> v </span><span class="syntaxcomment"># use pts as hash keys<br /></span><span class="syntaxdefault">    end<br />  end<br />  <br />  pts </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> pset</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">keys </span><span class="syntaxcomment"># array of unique pts<br /></span><span class="syntaxdefault">  <br />  mesh </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">PolygonMesh</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> pts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">size </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  <br />  for pt in pts<br />    idx </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> mesh</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_point</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> pt </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Use idx for subsequent calls<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># to set_uv() and add_polygon(). <br /></span><span class="syntaxdefault">  end<br /></span>
              But eset could also be the selection set, ie:
              Sketchup::active_model.selection
              • O
                oajfh
                Thanks for the tips (I didn't know about grep, seems like it'll save having to recurse through ComponentInstances and Groups).
                I think I'll try and keep the normals, so I might have to proceed a bit differently, but this should set me on the right track.
                The PolygonMesh doc is confusing though. I was interpreting it differently than what its philosophy suggests, and I'm probably not the first person to do so.
                • Dan RathbunD
                  Dan Rathbun
                  @oajfh said:
                  (I didn't know about grep, seems like it'll save having to ...).
                  OH, grep() comes from the API collection classes mixing in, via include(), the library module Enumerable. There are quite a number of nifty filter, query and iteration methods that get mixed in.
                  Also, remember that a class inherits all it's ancestors methods and constants all the way back to BasicObject, (or Object for the 1.8 branch of Ruby.)
                  You can see if the class [or module] has mixin modules included, and what it's ancestor classes are [if it's a class,] via:
                  Identifier.ancestors
                  (Note that the method returns an array of object references. They are not strings or symbols, but you can use to_s or inspect to get a string representation of the array, or the name() method for stringnames of individual ancestor members.
                  • Dan RathbunD
                    Dan Rathbun
                    @oajfh said:
                    (..., seems like it'll save having to recurse through ComponentInstances and Groups).
                    The fastest and easiest way to "walk" group and component instances, is via the model's singleton DefinitionList collection.
                    Group's are a special kind of Component, that also has a definition in the collection. You check each definition for a boolean result to group? or image?. Both false and it's a component definition. If of course group? is true than it is a definition for a group. Ignore any that are for images.
                    This is where those nifty Enumerable methods come in handy.
                    Getting the group definitions only:
                    dlist = Sketchup::active_model.definitions glist = dlist.find_all {|d| d.group? }
                    Getting the image definitions only:
                    ilist = dlist.find_all {|d| d.image? }
                    • NOTE: Modifying images via Ruby has caused SketchUp to crash, or become unstable. Team members recommend explode of an instance be the only manipulation via Ruby.
                    Getting the component definitions only:
                    dlist = Sketchup::active_model.definitions clist = dlist.find_all {|d| !d.group? && !d.image? }
                    The results are Array instances. The Array class also has Enumerable mixed in.
                    Let's say you are not interested in processing definitions that do not have any instances:
                    clist.reject! {|d| d.count_instances == 0 }
                    The count_instances method is nice (for speed,) because you need not get a reference to the definition's instances collection in order to call size.
                    For those that do have instances in the model, you can process all of them at once, by iterating it's instances collection. (To get the transformation of each one, for example.)
                    Since all instances share their definition's entities collection, ... you might as well process it once, as you go thru the DefinitionList.
                      Anton_S
                      I also have a method that returns PolygonMesh object of a group/component:
                      # Get group/component entities.
                      # @param [Sketchup;;Group, Sketchup;;ComponentInstance] entity
                      # @return [Sketchup;;Entities]
                      def get_entities(entity)
                        entity.is_a?(Sketchup;;ComponentInstance) ? entity.definition.entities ; entity.entities
                      # Get triangular mesh of the group.
                      # @param [Boolean] recursive Whether to include all the child groups and
                      #   components.
                      # @param [Boolean] transform Whether to give points in global coordinates.
                      # @yield A procedure to determine whether particular child group/component
                      #   should be considered a part of the collection.
                      # @yieldparam [Sketchup;;Group, Sketchup;;ComponentInstance] entity
                      # @yieldreturn [Boolean] Pass true to consider an entity as part of the
                      #   collection. Pass false to not consider an entity as part of the
                      #   collection.
                      # @return [Geom;;PolygonMesh]
                      def get_triangular_mesh(entity, recursive = true, transform = false, &entity_validation)
                        mesh = Geom;;PolygonMesh.new
                        get_entities(entity).each { |e|
                          if e.is_a?(;;Sketchup;;Face)
                            e.mesh.polygons.each_index{ |i|
                              pts = e.mesh.polygon_points_at(i+1)
                              mesh.add_polygon(pts)
                          elsif recursive && (e.is_a?(;;Sketchup;;Group) || e.is_a?(;;Sketchup;;ComponentInstance)) && entity_validation.call(e)
                            mesh2 = get_triangular_mesh(e, true, true, &entity_validation)
                            mesh2.polygons.each_index { |i|
                              mesh.add_polygon(mesh2.polygon_points_at(i+1))
                        mesh.transform!(entity.transformation) if transform
                        mesh
                      Same usage as using get_polygons_from_faces method, but instead of returning triplets it returns a PolygonMesh object containing information about all faces of group geometry. One can simply recreate a group through mesh:
                      group = Sketchup.active_model.entities[0] mesh = get_triangular_mesh(group, true, true){ |e| true } pt = Geom::Point3d.new(100,0,0) mesh.transform!(pt) # Move mesh 100 units on xaxis. Sketchup.active_model.entities.add_faces_from_mesh(mesh, 0)
                        Anton_S
                        It is easy to obtain face triangulation using PolygonMesh. Triangular data is how SketchyPhysics and MSPhysics gather their information about group geometry. Here is a way to gather triangular data from one face:
                        triplets = []
                        face.mesh.polygons.each_index{ |i|
                          triplets << e.mesh.polygon_points_at(i+1)
                        In this little snippet a triplets array contains triangles of the face. Each triangle represents an array of three Point3d objects.
                        Now, this snippet was to get triangular data from single face. But, what if you want to get triangular data from the whole group and what about its sub-groups? Well, it's not easy to write such method, but it's easy to paste it when you have it:
                        # Get triplets from all faces of a group/component.
                        #   components.
                        #   collection.
                        # @return [Array<Array<Geom;;Point3d>>] An array of polygons. Each polygon
                        #   represents an array of three points - a triplex.
                        def get_polygons_from_faces(entity, recursive = true, transform = false, &entity_validation)
                          triplets = []
                            if e.is_a?(Sketchup;;Face)
                            elsif recursive && (e.is_a?(Sketchup;;Group) || e.is_a?(Sketchup;;ComponentInstance)) && entity_validation.call(e)
                              triplets.concat get_polygons_from_faces(e, true, true, &entity_validation)
                          if transform
                            tra = entity.transformation
                            for i in 0...triplets.size
                              triplets[i].each { |pt| pt.transform!(tra) }
                          triplets
                        Read the Yardoc generation comments above the method for parameters info. Here is an example:
                        recursive = true # Have geometry gathered from sub group too.
                        transform = false # We want our coordinates to be relative to group transformation.
                        triplets = get_polygons_from_faces(group, recursive, transform) { |e|
                          true # Have every sub-group/sub-component be considered
                        • Dan RathbunD
                          Dan Rathbun
                          This: for i in 0...triplets.size
                          will cause a "fence post error" (attempt to read past the last member.)
                          Use instead:
                              for trip in triplets
                                trip.each { |pt| pt.transform!(tra) }
                          There is no sense in using a index when you want the members of the enumerable collection.
                            Anton_S
                            Nope, it wont. I'm using 3 dots (...), not 2 (..). 3 dots mean n minus 1.
                            • Dan RathbunD
                              Dan Rathbun
                              OK, but it's still a bit obscure styling. .. and each iteration you're calling the [] method when you don't need to. Just sayin'
                              • O
                                oajfh
                                Thanks again for the replies !
                                Anton, your piece of code that constructs a mesh is exactly what I was looking for. I'd tried a couple of things that weren't too different in their approach, but your code handles Transformations really cleanly.
                                On a side note, you do need to add an extra check at the beginning of your get_triangular_mesh, otherwise it will fail as Edge objects do not have an 'entities' method.
                                On another side note, in another approach I'd had, I used Sketchup::Set instances to store points and make sure I wasn't getting multiple objects which actually referred to the same point. Strangely enough, the Sketchup::Set does manage to get unique points, but the Object::Set does not - I guess the Sketchup::Set used something other than hashes and eql? to compare points. Yet the Sketchup API directs users to the Object::Set class since Sketchup::Set is now deprecated. Aren't there going to be compatibility issues if users create Sets of points ?
                                Anyway, thanks again for the answers. Dan, the tips you gave me will also definitely come in handy when I start optimizing my bad Ruby code.
                                  Anton_S
                                  I think that each loop is slower than for loop. That's why I used for loop.
                                  I had these in checkers. I just removed them because these checkers were from other functions, which I did not wan't to paste because they would have probably made the code a bit confusing:
                                  # Validate object type.
                                  # @param [Object] object
                                  # @param [Object, Array<Object>] types An object or an array of objects to
                                  #   check against.
                                  # @return [void]
                                  # @raise [TypeError] if object class doesn't match with any of the specified
                                  #   types.
                                  def validate_type(object, *types)
                                    types = types.flatten
                                    return if types.empty?
                                    types.each { |type| return if object.is_a?(type) }
                                    string = case types.size
                                    when 1
                                      types[0]
                                    when 2
                                      "#{types[0]} or #{types[1]}"
                                    else
                                      "#{types[0...-1].join(', ')}, or #{types[-1]}"
                                    raise TypeError, "Expected #{string}, but got #{object.class}.", caller
                                    validate_type(entity, ;;Sketchup;;Group, ;;Sketchup;;ComponentInstance)
                                    mesh
                                  On another side, I know nothing about Sketchup::Set or Object::Set, although I do recall reading a thread mentioning them. I'm pretty sure other developers have good knowledge of them.
                                  • fredo6F
                                    Not so sure in Ruby 2.x. See this interesting benchmark.
                                    It is also said that the fastest is the while loop, when this is appropriate.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      BUT.. that is not the point I was making. You do not need to mess with an index, in order to iterate the members of an Enumerable collection.
                                      Restated and simplified, as this:
                                          for t in triplets
                                            t.each { |pt| pt.transform!(tra) }
                                      is faster and more readable (better practice) than:
                                      Why faster?
                                      • No calling the size method at the beginning.
                                      • No instantiation of a Range object via the ... operator
                                      • No need to call the [] method during each iteration.
                                      Because, the for loop can directly serve up each enumerable member in turn, without the need to maintain an index variable on the Ruby side.
                                      (Of course the C-side implementation using for over there does use an iterator, but the C-side does not need to expose the iterator to the Ruby side.)
                                      The for construct is not a method it's built into Ruby. And it does not create a new scope during each iteration. I image that other built-in looping constructs ( while, until) can also be fast.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Well that is interesting. Seems they optimized while and each, but not for.
                                        So now we have a quandary if we publish for older SketchUps, with older Ruby.
                                          IN Ruby 1.8 for loops used to be faster - at least in the tests I performed on my extensions. But Ruby 2.0 swapped that around.
                                          In any case - you don't really know until you profile your specific case.
