    Installation of Proper Animation plugin
    4 Posts 3 Posters 1.3k Views 3 Watching
      medicanic7
      Hello forum. I downloaded and moved the file proper_animation_v1.10.rbz to the plugin folder in SketchUp 2014 (C:/Users/MyName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/plugins). After I closed SketchUp and opened it, the plugin wasn't installed; it was not displayed in the Plugin menu.
      The plugins section of the forum is locked so I decided to post here.
      Please assist me in properly installing the plugin. Thank you.
        Why not use the classical automatic loading ?
        Menu Window/ Preferences/ Extentions / Install extension (this call the rbz file)
        That's all! πŸ˜„
        If you want the hard way
        rename XXX.rbz in XXX.zip
        Unzip
        Move the result (file(s).rb and /or folder(s)) inside the Plugins folder
        but this has absolutly no interest and you can make some errors!
          medicanic7
          Thank you for responding with a solution so quickly, pilou. The method you mentioned for installing plugins is much easier and quicker than the one I have been trying. 😳
          I am eager to start creating my animation.
          • BoxB Offline
            The plugins section isn't locked, the padlock icon can be misleading, the parent forum is locked so that you post to the relevant subforum.
            So if you want to go to the Plugin sub-forum click this link.
            http://sketchucation.com/forums/viewforum.php?f=323
