    Change Axes in Sketchup.
    Scheduled Pinned Locked Moved Dynamic Components
    2 Posts 2 Posters 1.6k Views 2 Watching
    • V
      vimleshpatel
      How to change the axes of any component in sketchup using code.
      -We can changes axes of any component by right click and select "change axes" menu.
      -I want to change this axes using ruby code.
      Is there any option to do this using ruby code?
      • G
        Garry K
        This is what I use
          # Let 'point' be the new insertion point of the component.
          # Let vector=ORIGIN.point.vector_to(point)
          # Let tr=Geom;;Transformation.translation(vector)
          vector = component.transformation.origin.vector_to(new_origin)
          tr = Geom;;Transformation.translation(vector)
          component.definition.entities.transform_entities(tr.inverse, component.definition.entities.to_a)
          # All of the component's innards jump to suit, so the instance is now in the wrong place relative to its container's contents...
          # To fix any instances so the contents are placed back as they were, inside their individual container...
          component.definition.instances.each{ |inst| inst.transform!(tr) }
          component.definition.invalidate_bounds
