    New 3d Machines Unveilings & Pens, Scanners, Elements Idems
    993 Posts 6 Posters 304.5k Views 6 Watching
    • dukejazzD Offline
      dukejazz
      New 3D Printer Machines unveiling, Pens, Scanners, elements and other 3D Machines Items
      ( Highlight WEB title. line right click the mouse, click on search provider and go to the WEB page )
      Kovac adds laser cutting to his creative lineup. Press & Sun-Bulletin|
      "My art is basically cut sheet materials made into assemblage-type pieces"
      Additive manufacturing material capabilities. Industrial Laser Solutions Magazine|
      "transition between the hard and ductile properties without subsequent heat treatment"
      ColiDo Makes News With New Composite Filaments. Castle Ink|
      "3D filament available as both PLA and ABS composite which contains real wood particles"
      Recycled plastic filament is here. Picayune Leader|
      "consumers' every desire. It has emerged that the business has filed a patent"
      Perceptron Launches Smart3D(TM) Laser Scanning System Revolution in Automatic. CNNMoney|
      "represents a productivity breakthrough for the reverse engineering and modeling sectors"
      TETRA 3D Printer Earns Title as World's Smallest Nano-Printing Technolog. Inside 3D Printing|
      "SLS and SLA 3D printers, but at a much, much smaller scale"
      BoXZY Rapid-Change FabLab: Mill, Laser engraver, 3D Printer. Kickstarter|
      "laser engrave into objects made of wood, leather or plastic"
      ELA 3D Printer. 3D Printing Forum - 3D Print Board| Jose Luis Luna says his ELA 2.0 3D printer was
      "happen to be a professional, you’ll find it a useful tool as well"
      3D Printers. Becoming 3D| RoBo 3D R1 3D Printer. $799.99 Read More · Sale!
      "Sale! Juniper_2_Transparent. Objet24"
      Pirx 3D releases design files for PIRX 3D printer, enables you build your own. 3Ders.org|
      "the design and source files are free and downloadable for non-commercial use"
      http://www.3ders.org/images2014/pirx-3d-releases-design-files-for-pirx-3d-printer-enables-you-build-your-own-for-free-2.png
      3d Printing Filaments to Romania HS code 8443.99.9000. DutyCalculator|
      "3d printing filaments was classified as Computers & Office ? Computer Peripherals"
      ABS Resin Pellets. IC3D Printers|
      "recommend some method of drying the pellets before using to get the best results"
      Would this be a nice 3d printer?. RepRap Forums|
      "discussions. For specific printers / electronics / fabrication methods / softwares"
      How many people here are 3Dprinting molds for casting?. Yahoo Answers|
      "of tin. I have dealt with large companies locally with sand"
      Low-Cost Metal 3D Printing for $2K on Indiegogo. 3D Printing Industry|
      "the Mini Metal Maker to go into production and you can give its inventors"
      What to consider when buying a 3D printer. Inside3DP|
      "printer is reliable, represents quality and is well built. Is that enough"
      RS creates own brand 3D printer for $1230 ex-GST. iTWire|
      "BeeVeryCreative and RepRapPro, has RS Components found a way to print money"
      Cladding Machine-Printer Hybrid Wins World's Largest 3D Printing Prize. PDesign & Development|
      "so that metal parts can be made through additive manufacturing on the spo"
      Test your 3D printer's limits with this hard-to-print test object. 3Ders.org|
      "are capable of? Can they truly do what it says on the tin"
      Turtle 3D Lora & Lora S 3D Printers. 3D Printing Forum - 3D Print Board|
      "storage. Below are the general specifications shared by each of the machines"
      • dukejazzD Offline
        dukejazz
        3D printer for large variety of filaments?. 3D Printing Forum - 3D Print Board|
        "wood fill and Nylon in addition to abs and pla. Perhaps even polycarbonate"
        claw game 3d printer. 3D Printing Forum| Has anybody else
        "machines to build a 3d printer? The x and y axis is already"
        Miscellaneous. 3D Printing for Beginners| How to make DIY Filament for your 3D Printer ·
        "the materials for 3D printing are becoming more and more varied and readily available"
        Easy Cleaning - Clogged 3D Printer Nozzle. Instructables| Picture of Easy Cleaning - Clogged 3DP
        "at times. This is an easy and cheap method to clean clogged nozzle"
        Don't buy CTC high resolution 3d printer. B9Creator|
        "It's simply a pice of junk they try to imitate the 3d concept"
        Futurology. Reddit| Tldr; Buying filament is the correct choice for 99.9% of
        "need the chip to be able to use the filament produced from this machine"
        3D Printer Price. authorSTREAM| Check this link right here filamenta.com for more information on
        "for ... Get the best and most consistent filament for your MakerBot Replicator 2"
        BoXZY, The Desktop MakerSpace — All-in-one 3D Printer, Mill & Laser. 3DPrint.com|
        "Compatibility: PLA, PVA, Ninja-flex, ABS, and Nylon"
        ELA 2.0 3D Printer, a Solid Device for Just Over $300. 3DPrint.com|
        Check Out This Affordable 3D Printer on Kickstarter. Apartment Therapy|
        "those who want their own setup. The printer is currently active on Kickstarter"
        RenderBot 3D Printer Launches On Kickstarter For $299 (video). Geeky Gadgets|
        "the new 3D printing solution which has been created by RenderBot"
        http://www.geeky-gadgets.com/wp-content/uploads/2015/03/RenderBot-3D-Printer.jpg
        World's largest 3D printer may be at ORNL. WRCB-TV|
        "to make 3D printing a viable alternative for large-scale, mainstream manufacturing"
        3D Printed Scale accessories RC enthusiasts radio controlled. Kickstarter|
        "scale items, like milk crates, diorama items, and other 3D items"
        Fluid-Based Gating Mechanism for Controlling Passage of Materials through . AZoNano.com|
        "fouling, and are also not energy efficient over long periods of use"
        Sardauscan, the Sub-$30 DIY 3D Scanner — Open Source 3D Printable Files. 3DPrint.com|
        "them free, there still is something missing from the overall 3D printing ecosystem"
        ORNL's new 3D printer may be world's largest. Knoxville News Sentinel|
        "the next few years to emphasize working with metals such as steel and aluminum"
        Who buys consumer-level 3D printers?. 3D Printing Progress|
        "grown substantially. Around 100,000 of these printers were sold last year"
        Pirx 3D Offers the Design for Their 3D Printer as Open Source Material. 3DPrint.com|
        "would be as easy as using a TV. But without a remote control"
        Pirx 3D Printer Plans Now Open Source, Allowing You To Build Your Own F. Geeky Gadgets|
        "Piotr Lipert, CEO of Pirx 3D explains a little more about the announcement"
        • dukejazzD Offline
          dukejazz
          PhillyDeals: Penn grads' firm builds desktop 3-D printers. Philly.com|
          "Philadelphia for a 3-D printer to test her ideas on living cells"
          The EKOCYCLE 3D Printer Project. Kickstarter|
          "in our generation involved with the ever expanding possibilities of 3D printing"
          All-In-One 3D Printer, CNC Mill, Laser Engraver BoXZY Launches on Kickstart. Inside 3D Printing|
          "to ship sometime in July, the FLUX machine will likely have decent competition"
          Cubify CubeX 3D Printer. Becoming 3D| Triple Head Print - 7.28 x 9.45 x 10.43 Build
          "An Easy to Use 3D Idea Builder by Dremel Will Unlock Your Creativity"
          3D Printing. CDW.com| VERBATIM 3D FILAMENT 1.75MM BLACK. Mfg. #: 55250 | CDW
          "ders placed today will ship within 9 days. 7-9 days"
          Replicator 2 gear upgrade. 3D Printing Blog|
          "it unmaintained and has never applied some grease to help it run smoother"
          FastBot's BBP Controller Board Allows You to Upgrade Your 3D Printer & Print . 3DPrint.com|
          "how long it might take you to print, say, a plastic fork"
          Young visionaries build life-improving creations with 3D printers. Brandeis University|
          "using the technology to develop novel solutions to a wide range of societal issues"
          BBP Control Board Unveiled To Make Your 3D Printer Faster (video). Geeky Gadgets|
          "has been created by Paul Fontanez to help make your 3D printer even faster"
          BBP. Kickstarter|
          "CNC Mills, Pick and place and other small-sized CNC machines"
          BBP: making your 3d printer faster. Kicklytics|
          "place and other small-sized CNC machines. It is powered by"
          The Shutterfly of 3D Printing, Scandy, Launches Today in New Orleans. Silicon Bayou News|
          "based backgrounds and shared enthusiasm led to their eventual launch of the unique startup"
          Supercharge your 3D printer with the Fastbot BBP controller board. 3Ders.org|
          "solution to many current problems with 3D printers, with speed being among them"
          Atom 2.0 delta printer from taiwa. Reddit|
          "volume, at least when compared to printers with a comparable hardware component cost"
          http://3dprint.com/wp-content/uploads/2015/02/Image-43.jpg
          Filamento – Next Generation in Premium 3D Printing Material. Kickstarter|
          "printing, these new materials will bring greater choice to this expanding market"
          Autodesk releases ingredients of 3D printing resin under Creative Common. Start 3D Printing|
          "Prototyping Resin (PR48) may be just want the industry needs to grow"
          Blue Masking Tape for 3D Printing Plate. Adafruit|
          "print directly onto the tape, and then remove your project with ease"
          i.materialise Is Now Offering a New Color Option for Rubber-Like Materia. 3DPrint.com|
          "you got was a part which is strong, highly-flexible and durable"
          X-Carve machines custom 3D pieces from wood, metal or plastic. Gizmag|
          "with a twist that is borderline brilliant: the X-Carve is scalable"
          Creadition's Filamento 3D Printing Filament to Provide Premium Quality Due. 3DPrint.com|
          "an epic fail due to a poor filament choice is just really not acceptable"
          • dukejazzD Offline
            dukejazz
            Autodesk Open Sources Their 3D Printer Resin – Providing Recipe to All & Open. 3DPrint|
            "a massive amount of iteration on behalf of those ideas and creations"
            Kitprinter3d Unveils Affordable SolidRay SLA-DLP 3D Printer Kit. 3DPrint.com|
            "apart from the currently popular FDM/FFF 3D printers on the market today"
            3D printer Bitcoin. 3D Printing Blog|
            "a network of more than 13,000 machines listed on its database"
            Airwolf 3D Unveils Wolfbite Nano, Industry-Changing Adhesive Solution for Optic. Magazine|
            "enables a smooth release of parts after 3D printing. Airwolf 3D today announced"
            3D Printing Titanium, the Bin of Broken Dreams (Part 3). 3D Printing Industry|
            "of Broken Dreams”, and into it went an endless stream of failed parts"
            Dim3printing's 3DFormer 3D printing pen is coming to Kickstarter, starting. 3Ders|
            "one step further, providing this latest 3D printed transmission to complement the engine"
            Autodesk Releases Ember's 3D Printing Resin as Open Source. Between the Lines|
            "hardware for our vision for a common 3D printing using the Spark platform"
            Featured. re:3D| It's seems like it was only yesterday since we launched
            "both our Austin and Houston teammates have returned to reflect on the past"
            3D Printed Screen Printing Kit. Thingiverse|
            "frame and squeegee and learn to screen print with this complete kit"
            Autodesk open sources Ember 3D Printer's Standard Clear resin. 3Ders.org|
            "files, and encourage makers to remix and remake their own resin at home"
            NES remote for 3DPrinter 3DThursday 3DPrinting. Blog - Adafruit|
            "Entertainment System accessory created by Nintendo, and was released in 1989"
            McMaster-CARR 3DPrinting access within Fusion 360 3DThursday. Blog - Adafruit|
            "Check out how Autodesk Fusion 360 users are turning their vision into reality"
            3D Printed Molds and Silicone Caulking. Hackaday|
            "the manufacturing process, and after the product is used, ease of recycling"
            Safe, Simple, Affordable: Cold Casting Turns 3D Prints into Metal. 3DPrint.com|
            "affordable way to create metal works that are shiny and magnetic to boot"
            3D Printing Designer Creates Flexible Meso-Material Out of Rigid Filament. 3DPrint.com|
            "the designer is also looking to create a product that is also very strong"
            http://3dprint.com/wp-content/uploads/2015/03/3D_Printed_logo.jpg
            How 3-D Printing Helps SMBs Beat the Competition. BizTech Magazine|
            "for every level of interest from hackerspace to aerospace, according to the organizer"
            Grupo Sicnova Introduces its First 3D Printer. ENGINEERING.com|
            "research labs and any professional who needs large build volumes with great accuracy levels"
            Redstack Offers Ultimaker 2 3D Printer. Ten Links|
            "painful assembly processes, there is little standing between you and your first print"
            Stratasys Announces New Objet260 3D Printer. Desktop Engineering|
            "offers unprecedented dental model realism to improve accuracy of digital dentistry"
            UK's Cooksongold to Unveil M 080 3D Printer at Baselworld. Ten Links|
            "intricate one-off 3D designs can be manufactured within a few hours"
            • dukejazzD Offline
              dukejazz
              MTA Brings Its New 3D Printer Online. Jewish Link of Bronx, Westchester and Connecticut|
              "—who helped procure the 3D printer through a grant from First Tech Challenge"
              3D printing. Scout| Tangent Master
              "RPM 24 pole motor, and a dual Scout chassis with a steel center"
              NEW: BEGO Varseo 3D printing system. BEGO|
              "surgical guides, CAD/Cast partial dentures, splints, and individual impression"
              New Machine Is Like Molecular 3D Printer. Pioneer News|
              "enable discovery and bring the substantial power of making molecules to nonspecialists"
              WO-FI: New Wood Filament on Indiegogo is Unique in Purity, Affordability, Versatility. 3DPrint.com|
              "the creation of two young Slovenian engineers, Rok Rudolf and Jure Hictaler"
              Ed Tyson of rigid.ink Challenges You to Find a Better 3D Printing Filament. 3DPrint.com|
              "low +/-0.03mm – we’d be surprised if you found better"
              Pint-sized printer delivers pro-quality 3D performance at entry-level price point. EDN.com|
              "growing number of regular consumers who are considering buying their first 3D printer"
              http://www.edn.com/ContentEETimes/Images/LeeG LEDs/LG-DIY-1502-16-PR-LulzbotMini/LG-DIY-1502-16-PR-LulzbotMiniFig1a-LulzMini.jpg
              LEGO Based 3Doodler Uses Regular Filament. Hackaday|
              "manufacturing process, and after the product is used, ease of recycling"
              Castable 3D Printing Materials. EnvisionTEC|
              "on complete burnout which makes it cast as easily as any injection wax pattern"
              3d Printing. daystarmachining.com| Our Stratasys 3d-printer allows us to produce scale
              "With this capability we can evaluate form, fit and function before beginning production"
              Open Gigabot. Kickstarter| Open Gigabot is a 2015 concept 3D Printer which is
              "to get a fully-loaded kit to construct this behemoth of a machine"
              Ember 3D Printer – 3D Hangouts. Blog - Adafruit|
              MakerBot Replicator 2X Nozzle Alignment Jig. Fargo 3D Printing|
              "piece silicone insulation, two 0.4mm nozzles and one alignment jig"
              The World's First Desktop 3D Printer for Metal Is Market Ready. Motley Fool|
              "production version, and Hartkop is now looking to bring the printer to market"
              re:3D Turns to Kickstarter to Help Crowdfund & CrowdSource Their Open Gigabot . 3DPrint.com|
              Breakthrough Molecular 3D Printer Can Print Billions of Possible Compounds. Free Republic|
              "the University of Illinois may have already taken a major step in that direction"
              NanoSteel Expands Material Capabilities for Additive Manufacturing. Product Design & Development|
              "design. ... metal powders that enable affordable, robust industrial components produced"
              Molding Material. EnvisionTEC| High temperature molding material for non-metal masters dramatically
              "It is easily paintable for visual aids or also available in an ivory colo"
              The SolidRay DLP 3D Printer. Fabbaloo|
              "vat of UV-curable resin to gradually produce solid layers of each print"
              Activate. Cubify| 3D printer innovating green technology | Shop recycled materials in
              "deep design principles from nature are collectively known as the practice of biomimicry"
              • dukejazzD Offline
                dukejazz
                Formlabs opens office in Berlin, partners with iGo3D. 3Ders.org|
                "retail locations in Frankfurt, Stuttgart, Oldenburg, Hamburg, and soon, Hannover"
                Here's how you make a 3D printing gun using Lego. Daily Tech Whip|
                "printing gun, so it shouldn’t be too hard to replicate the invention at home"
                Here's how you make a 3D printing gun using Lego. Engadget|
                "hard to replicate the invention at home"
                China XD Plastics Announces Fourth Quarter and Fiscal Year 2014 Financial Results. CNNMoney|
                "its financial results for the fourth quarter and fiscal year ended December 31, 2014"
                Bears of the Day - Motorola Solutions (MSI), Great Plains Energy (GXP), 3D Systems . Techsonian|
                "as the record date for determining stockholders eligible to vote at the Annual Stockholders Meeting"
                Filamento Next Generation 3D Printing Filaments Unveiled (video). Geeky Gadgets|
                "build process; so we invented the FILAMENTO line of high quality 3D printing filaments"
                New Liquid 3D Printing System Is 25 Times Faster Than Its Competitors . Gizmodo|
                "method that claims to be 25-100 times faster than other resin printing techniques"
                Watch: This new type of 3D printing was inspired by Terminator 2. Vox|
                "in a new paper published today in Science call it "continuous liquid interface production"
                https://cdn1.vox-cdn.com/thumbor/MxYW5rEQT0B_tssamr76ob4hykw=/800x0/filters;no_upscale()/cdn0.vox-cdn.com/uploads/chorus_asset/file/3509822/How_CLIP_Works.0.png
                ZMorph Adds New 3D Scanner Toolhead To Their ZMorph 2.0 S Personal Fabricator . 3DPrint.com|
                "the resulting files can be used to print objects with other 3D printers as well"
                3D printing at 7x speed. Washington Post|
                "that's no mistake: Its creators were inspired by that very scene"
                Conductive Graphene Filament for 3D Printing. ENGINEERING.com|
                "keep in mind that the resistivity will change depending upon the print or circuit design"
                3D Printing industry. Spark - Autodesk|
                "which will bring lots of positive change for many industries surrounding additive manufacturing"
                The All-New HDR. Airwolf 3D|
                "slicing and printing via an 8” tablet interface, and a rigid aluminum backbone"
                Graphene 3D Lab Launches BlackMagic3D Filament Brand & New Graphene . 3DPrint.com|
                "quite rapidly with an approach which could transform several major industries in the long run"
                GGG Announces Commercial Sale of Conductive Graphene Filament. Canada NewsWire|
                "(similar to as used in circuit boards) within 3D printed parts for electronics"
                3DSHOES Launches Free Mobile Application for Scanning and then Storing Customers. 3DPrint.com|
                "as some pretty impressive new designs coming about from some of today’s most talented designers"
                Create Flexible 3D Prints by Embedding Steel Rods for Modular 3D Models. 3DP Materials Conference|
                "extruder that prints materials, from PLA and ABS to PBA, Nylon and polycarbonate"
                3D printing at 10x speed. Washington Post|
                "emerging from a resin pool. The model was created using the Continuous Liquid Interface"
                3D Printer uses recycled, post-consumer plastics. ThomasNet News(blog)|
                "the methods, deliver improved results and empower its customers to manufacture the future now"
                • dukejazzD Offline
                  dukejazz
                  DLP Castable Ring 3D Print Sample Set. Full Spectrum Laser Full Spectrum Laser|
                  "best results as FSL casting resin is similar but not the same as wax procedures"
                  (GRAP1037 RMIT) [Project A: 3D Scanning]. 3D Printer Cafe|
                  "s3381279 About: 3D scanning using Momento Music: Halo Combat Evolved theme song Enjoy"
                  3DFormer: New 3D printing pen from Dim3printing. 3D Printing Pin|
                  "the plastic filament using the printing nozzle to build the shape in the 3D spac"
                  This Lego-Modded Glue Gun is A Handheld 3D Printer. Gizmodo|
                  "glue gun which he modded with a custom Lego extruder. You know, obviously"
                  Crowdfunding a game changer for entrepreneurs: Prakash Somosundram. DEALSTREETASIA|
                  "about financing but can focus on developing a good idea and building a good team"
                  Bernis simple Mk 7 3d printing bowden extruder. Thingiverse|
                  "I have not tested it yet but it seems to grip the filament good enough"
                  Cebit 2015: Inno3D prepares to launch affordable 3D printing. KitGuru|
                  "launched before, it was what KitGuru learned about Inno3D’s strategy that was most interesting"
                  This Lego-Modded Glue Gun is A Handheld 3D Printer. The Echo|
                  "labyrinth of gray towers and walls, hidden chambers, a busy port and marketplace"
                  Alloys launches MakerBot into growing 3D print market. Stationery News|
                  "compact 3D printer, MarkerBot Replicator desktop 3D printer and MakerBot Replicator Z18 3D printe"
                  Carbon3D Unveils Breakthrough CLIP 3D Printing Technology, 25-100X Faster. 3DPrint.com|
                  "anywhere between 25 and 100 times faster than what’s available on the market today"
                  http://3dprint.com/wp-content/uploads/2015/03/clip6.jpg
                  3D printing materials. Pinterest| Pins about 3D printing materials hand-picked by Pinner
                  "printer has arrived! building off of past p read full product description"
                  Edge 3D Printer - an affordable open source 3D printer!. Instructables|
                  "$175 Canadian dollars, if you buy from the links provided in this project"
                  BUYING A 3D PRINTER?. 3D Prototypes and Models|
                  "range of precious metals including Solid Gold and Sterling Silver are perfect for fine jewelry"
                  Rising from the ooze. The Economist|
                  "needed to carry the technology beyond specialist and low-volume manufacturing"
                  CoKreeate Teams with Adult Film Star Christy Mack to 3D Print a Miniature Mack . 3DPrint.com|
                  "into a 3D print shop or simply send your designs to online 3D printing services"
                  3DPrint Broadens Portfolio by Moving into 3D Printing Marketplace with 3DShare. 3DPrint.com|
                  "in the same way other industries reward musicians, film-makers and fashion designers"
                  Answers to Some of the Biggest 3D Printing Skeptics. 3DPrint.com|
                  "the better, and the quicker this happens the better off we all will be"
                  Answers to Some of the Biggest 3D Printing Skeptics. Free Republic|
                  "Because we truly believe that 3D printing will change the world we all live in"
                  Electrically Conductive Filaments for 3D Printing Now Available from Graphene . 3DPrintingStocks|
                  "you combine the benefits of 3D printing with the amazing properties of graphene"
                  New device turns plastic into 3D-printing material. Bharat Press|
                  "combines the 2 and is quicker and simpler to make use of, researchers stated"
                  • dukejazzD Offline
                    dukejazz
                    Carbon3D Unveils Breakthrough 3D Printing Technology. [H]ard|Forum|
                    " 100x faster than conventional 3D printing? Whoa, that is pretty damn impressive"
                    This new type of 3D printing was inspired by Terminator 2. Reddit|
                    "be used to mass produce things? Do they even know what that means"
                    New Terminator-inspired liquid resin 3D printing technique. Reddit|
                    "we invented 3d printing. It's a step forward. Which I find exciting"
                    How Terminator 2 Inspired a Breakthrough in 3D Printing. Maxim|
                    "a new favorite pastime, watching as objects emerge fully formed from pools of resin"
                    Terminator II Inspires Carbon3D To Speed Up 3D Printing Process To Minutes. Beasts of War|
                    New Terminator-inspired liquid resin 3D printing technique. Imgur|
                    "No one is trying to say we invented 3d printing. It's a step forward. Which I find exciting"
                    XYZprinting Unveils New da Vinci 1.1 Plus 3D Printer. 3DPrint.com|
                    "says they’re the manufacturer of “the world’s most affordable consumer-grade 3D printers"
                    New Gaja 3D Multitool Printer — Multi-Functionality with Dual Extruders & Ten Printing . 3DPrint|
                    "if you have been 3D printing and need to wipe away clay or milling waste"
                    http://3dprint.com/wp-content/uploads/2015/03/gaja-one.jpg
                    Super-fast 3D printing takes its cue from 'Terminator 2'. Engadget|
                    "1000 robot in Terminator 2 -- solid objects emerge out of an amorphous goo"
                    3DPrinterOS Launches — Offers Accessibility for 3D Design Collaboration & 3D . 3DPrint.com|
                    "relying on, a great deal of technology and equipment that often defies traditional standards"
                    Terminator-style 3D printing grows objects from a pool of liquid. CNET|
                    "a pool of liquid as a machine draws them upwards"
                    25-100 times faster. GuerillaMediaNetwork.com| Up to now, 3D printing has involved many mechanical
                    "photosensitive resin to cure. This allows the printing to occur in three dimensions at once"
                    Awesome New 3D Printing System Inspired By T1000. Break.com|
                    "the printing to occur in three dimensions at once"
                    Hot glue gun becomes handheld 3D printer with some help from Lego. Gizmag|
                    "along a path in multiple axes looked complicated, so he simplified the process"
                    Chemical trick speeds up 3D printing. Nature.com|
                    "three-dimensional (3D) printing, producing objects in minutes instead of hours"
                    Chemical Technique Dramatically Speeds Up 3D Printing. Scientific American|
                    "robot in the 1991 science-fiction film Terminator 2 formed out of liquid metal"
                    Watch: 3D printing gets speedy. Science AAAS|
                    "the resin where desired, making intricate, 3D shapes"
                    A new 3D printing technology unveiled yesterday lets you grow, not print, just. Reddit|
                    "up print times. Other than that it's virtually the same as what's out there"
                    New Super Fast 3D Printing Process Turns A Pile Of Goo Into An Eiffel Tower. Digg|
                    "this new process alleges to print 25 to 100x faster than current technology"
                    new technology by carbon3d, called CLIP (Continuous Liquid Interface Production). Linus Tech Tips|
                    "an oxygenized layer is present at the bottom, creating a dead zone"
                    • dukejazzD Offline
                      dukejazz
                      Awesome liquid 3D printer oozes out things from goo. Sploid - Gizmodo|
                      "it looks like things are just magically rising from the gooey liquid, fully formed"
                      ZMorph Announces 3D Scanner. 3D Printer World|
                      "heads, is demonstrating a new 3D scanner attachment at CeBit in Hannover, Germany"
                      3 desktop 3D printers for clutter-free designers. Creative Bloq|
                      "then the good news is, you don't have have to compromise on quality"
                      The Thinkery: 3D Printer Demo & Play-. SXSW Schedule|
                      "of innovators and creative problem solvers. And it’s a heck of a good time"
                      LEGO Based 3Doodler Uses Regular Filament (VIDEO). 3D Printing Materials Conference|
                      "more curious about free form deposition modeling — extruding material along multiple axes at once"
                      da Vinci 1.1 Plus. XYZprinting| 3D printing has never been this broadly apply to. Anything
                      "of about two days on the floor of the International Manufacturing Trade Show in Chicago"
                      Tiko Is 2015's Most Unusual 3D Printer—And It's Cheap, Too. ReadWrite|
                      "rectangle. It has a sleek, unibody design. And it will cost $179"
                      Tiko3D Unveils Sleek $179 Delta 3D Printer. 3DPrint.com|
                      "would grow substantially and mainstream adoption within the consumer space would pick up steam"
                      New delta-style TIKO desktop 3d printer revealed at SXSW for just $179. 3Ders.org|
                      "Texas, 3D printing looks like it’s about to get a whole lot cheaper"
                      http://www.3ders.org/images2014/new-delta-style-tiko-desktop-3d-printer-revealed-sxsw-179-1.png
                      Speedy 3D Printer Takes Cues from 'Terminator'. PC Magazine|
                      "the California-based company introduced game-changingpolymer-based 3D printing"
                      Terminator-inspired tech could give traditional 3D printing a run for its money. Gizmag|
                      "which inhibits it, allowing for the projected object to literally grow out of the resin pool"
                      Carbon3D Unveils Breakthrough 3D Printing Tech. Top Tech News|
                      "the technology has primarily been applied to basic prototyping, rather than full-scale manufacturing"
                      3D Printing Technology Is 100 Times Faster, Claims Startup. NDTV|
                      "years, representing a fundamentally new approach to 3D printing"
                      World's First Commercial Conductive Graphene Filaments for 3D Printing. 3D Printing|
                      "established as the trade name for the company’s current and future Graphene 3D filaments"
                      Polish company unveils Gaja 3D printer version 2. 3Ders.org|
                      "3D printers and the Gaja 3D – a 3D printer dedicated to 3D printing clay and ceramics"
                      Sigma Labs to Launch Metal 3D Printer, a Stepping Stone to Opening. Inside 3D Printing|
                      "firms and establishing a manufacturing center in New Mexico that capitalizes on the technology"
                      The ShaperJet 3D Printer is Announced — Being Released by Month's End. 3DPrint.com|
                      "other large buildings, India seems to really be catching on in the desktop 3D printing space"
                      other large buildings, India seems to really be catching on in the desktop. zismile.com|
                      "laser light and oxygen to print out things up to 25-100 times faster than traditional 3D printers"
                      New Super Fast 3D Printing Process Turns A Pile Of Goo Into An Eiffel Tower. LiveLeak.com|
                      "You need to be registered in order to add comments! Register HERE"
                      IC3D 3mm ABS 3D Printer Filament 2lb Orange – MADE IN USA. IC3D Printers|
                      %(#008000)["from IC3DÂź. IC3DÂź extrudes 3D printer filament in-house in Ohio, USA"]
                      • dukejazzD Offline
                        dukejazz
                        3D Printing Becomes a Lot of Faster with Carbon 3D. iGyaan.in|
                        "the technology revolution that will revolutionize the manufacturing process in the near future"
                        This mesmerizing 3D printer"grows"Facebook|
                        "3D printer up to 10 hours. The CLIP process churned out the design in a little under 7 minutes"
                        Check Out This Crazy New 3D Printer. Gamebreaker|
                        "the creator of the game. As a result, the video has been pulled"
                        RepRap Prusa i3 as a 3D Printer benchmark. Prusa Printers|
                        "over the time designs have been perfected and it makes a wonderful workhorse 3D printer"
                        Introducing Tinkerplay: anyone can make 3D printed creatures and characters. Autodesk 123D|
                        "necessary. The resulting creations are durable and flexible, and above all, fun to play with"
                        3D Printing Filaments Advance With Eastman Amphoraℱ 3D Polymer. Eastman Chemical Company|
                        "features strength, workability, processing, aesthetics and low odor for 3D printed products"
                        BAAM 3D Printer Gets Major Upgrade — Prints 100 lbs of Material Per Hour & More. 3DPrint.com|
                        "of Energy, because they wanted to transform the way manufacturers look at 3D printers"
                        +Mfg Unveils New +1000k 3D Printer — Prints With Multiple Metals In a Single Run. 3DPrint.com|
                        "machines take up as much space, if not more, than a typical refrigerato^"
                        http://3dprint.com/wp-content/uploads/2015/03/m15.png
                        BoXZY crams a mill, laser, and 3D-printer into one desktop maker. SlashGear|
                        "barriers like cost, location, and space that individual makers encounter in the industry"
                        Lego And Glue Gun Transformed Into 3D Printing Pen (video). Geeky Gadgets|
                        "mechanism. Watch the video below to learn more about this unique DIY project"
                        Try It Before You Buy It: 3Doodler 3D Printing Pen. WZZM|
                        "so it comes out soft and pliable, but it hardens quickly for various creations"
                        3DFormer 3D Printing Pen Launches On Kickstarter (video). Geeky Gadgets|
                        "to 2 hours with no painful gripping problems or filament clogging say its creators"
                        3D printing just got affordable, ÂŁ299 XYZPrinting wants to help your home. Pocket-lint.com|
                        "will be selling its super affordable 3D printers for the home from 20 April"
                        Graphene Filament Could Breathe Life into 3D Printing. 3D Printing Industry|
                        "allowing multiple 3D printers to be managed through a single, cloud-based system"
                        3D Printing Made Easy with Tinkerplay. PCMag Australia|
                        "designed for kids of all ages who want to play, create, and tinker"
                        Are Induction-Heated Nozzles the Wave of the Future for Greater Speed in 3D . 3DPrint.com|
                        "only to use 3D printing, but to purchase one for the hospital as well"
                        New Terminator-Inspired 3D Printer 'Grows' Objects From A Bowl Of Resin. IBusiness Times|
                        "it also creates objects that are mechanically weak because of the presence of multiple layer"
                        Terminator-Inspired 3D Printer Prints Objects 100 Times Faster. ValueWalk|
                        "objects like shoes, medical devices and car components"
                        Terminator 2 Inspired This New 3-D Printing Process. IGN|
                        "than current tech on the market, according to a study published in Science"
                        • dukejazzD Offline
                          dukejazz
                          The Economist on Twitter: Get on board with 3D printing: a tech once for toys. twitter.com|
                          "a lump of metal and removing what is not needed. There is also far less waste"
                          Digital Bangladesh: Dreams and reality. The Daily Star|
                          "global perspective, and suggests steps to be taken in light of the recent advancements in ICT"
                          taulman 3D's Alloy 910: New Polymer with 8100 PSI Tensile Strength, Makes. 3DPrint.com|
                          "the best tools and materials to see your project through to the end with success"
                          Take a Spin on this Voice-Controlled 3D Scanning Rig. Hackaday|
                          "when the object is no longer detected. A typical scan takes about 60 seconds"
                          SHAREHOLDER ALERT: Pomerantz Law Firm Reminds Shareholders With Losses. CNNMoney|
                          "for alleged violations of the federal securities laws under the Securities Exchange Act of 1934"
                          Free 3D Printing Database of Industrial Machines & Materials. DesignNews|
                          "two different sections: one for materials and one for machines"
                          OMB 201 FDM 3D Printer. Taiwan San Yi Technology Co., Ltd.|
                          "we believe good after-sale service and good quality is your best choice"
                          Mesmorizing 3D Printer Forms Objects Out of Ooze—and Fast. Gartner Blog Network|
                          "great ideas, awareness of critical social and environmental ills, knowledge of potential cures"
                          3D Printed Carbon Fiber /Kevlar Smartphone Cases by Reid Larson. Kickstarter|
                          "composite cases offer extreme customisation and light weight protection. Join the revolution"
                          Gradient Color 3D Printing. Fabbaloo| Color 3D printing has long been a challenge and few
                          "taken a step towards full color 3D printing by demonstrating a 3D printed color gradient"
                          http://static1.squarespace.com/static/509c281de4b0cd18c7335aab/t/550b2512e4b0a9387b5bcd8d/1426793760826/?format=750w
                          INDMATEC's revolutionary PEEK filament now compatible with FDM 3D printers. 3Ders.org|
                          "good to be true, that material exists, and is commonly known as PEEK"
                          Why Would You Need Tungsten 3D Printer Filament?. Fabbaloo|
                          "such as bronze, copper, steel and more, what’s so special about tungsten"
                          Researchers develop 3D Printing Technology to create Terminator-Like Robot. Uncover California|
                          "liquid in a way the robot in the movie 'Terminator 2' rose from liquid silver"
                          Carbon3D Can Grow Seamless Structures 100x Faster than 3D Printing. ArchDaily|
                          "medical industry, one can only imagine its affect on manufacturing as a whole"
                          Carbon 3D has True game changing 3D printing and not just 2D repeated. 100. Next Big Future|
                          "quality parts at game-changing speeds, creating a clear path to 3D manufacturing"
                          New liquid 3D printing technique inspired by Terminator 2. Chicago Daily Herald|
                          "inspired by that very scen"
                          New liquid 3D printing method inspired by Terminator two. Chronicle Bulletin|
                          "teacher Antonio Ianni tells Ellie O'Byrne it is the future but Ireland is lagging behind"
                          Revolutionary 3D printing with liquid media. Geek Snack|
                          "but it enables the objects that are being printed to rise from liquid media continuously"
                          HP brings 3D to your desktop. IT World Canada|
                          "and make technology more tangible by allowing us to grab, mash and manipulate things"
                          Stratasys' Bold Machines Quietly Working on a 3D Printable Modular Creature Known. 3DPrint.com|
                          "lmost felt as if Bold Machines, well
wasn’t so ‘Bold’ any longer"
                          USF, Tampa library building on once-exotic 3-D printing technology. Tampabay.com|
                          "printers to mass produce such items as medical devices, military equipment and prototypes"
                          Technology allows Wallkill students to explore Chinese culture. Times Herald-Record|
                          "with some of their counterparts at Ningbo Yinzhou High School in China"
                          Carl Stoye, Fruita Monument High School senior. Grand Junction Daily Sentinel|
                          "because less oil is needed for fuel, which helps prevent pollution and global warming"
                          Looking for member to review brand-new 3D printing software.... 3D Printing Forum|
                          "If you are interested, please send me a PM or an Email"
                          Australian students 3D print a gigantic working crane that can lift up to five kilos. 3Ders.org|
                          "projects just because they can. Remember this 3D printed replica of the Eiffel Tower"
                          • dukejazzD Offline
                            dukejazz
                            taulman 3D launches 3D printing polymer with 8100 PSI tensile strength. TCT Magazine|
                            "Alloy 910 is designed to meet as many high performance 3D printing applications as possible"
                            The World's First,Best 3D Printing Pen. OOKAWA Corp. - Overblog|
                            "as possible to gain access to knowledge to help them understand and remember useful information"
                            CubePro 3D printer For Sale. Cubify|
                            "CubePro comes with up to three cartridges of ABS plastic and the Cubify Invent soft"
                            Protoprint brings sustainably sourced recycled plastic to 3D printing. Sustainly|
                            "great deal of plastic. One sustainable idea is to harvest recycled plastic for 3D"
                            From discarded plastics to 3D printer ink. Bellevue Reporter|
                            "of building a sustainable method for creating filament or “ink” for 3D printers"
                            ColorFabb Launches New Carbon Fiber 3D Printing Filament. ENGINEERING.com|
                            "viscosity, good dimensional accuracy and stability, and stiffness without being brittle"
                            Genesis Duo,Uno 3D Printers to Launch on Kickstarter Starting at $249 Next. 3DPrint.com|
                            "weekly basis, all bringing something a little bit different to the playing field"
                            Global 3D printing material market that is all set to grow exponentially during the. WhaTech|
                            "a major driving force that is influencing the growth of the market"
                            Photos of the Day: 3D Objects Printed out of Liquid. Product Design,Development|
                            "(like smoothness), and it enables creation of a broad range of materials"
                            New 3D Printer Unboxings Coming Soon!. 3DPrinterOS|
                            "the pleasure of taking them out the box and checking out each beautiful printer individually"
                            Stepcraft 2: Universal Desktop CNC/3D Printer For Everyone. Kickstarter|
                            "Turn your ideas into reality - CNC milling, 3D Printing and much more"
                            3D Printing. CDW.com| Matches found across. All Categories>. Printers, Scanners, Print Supplies
                            Genesis Duo, new $349 dual extruder 3D printer to launch on Kickstarter next. 3Ders.org|
                            "Duo, a dual-extrusion, self-calibration and wireless 3D printer"
                            http://www.3ders.org/images2014/new-budget-dual-extruder-3d-printer-to-launch-8.jpg
                            Terminator inspires rise of a 3D printer. Independent Online|
                            "makes coveted 3D printers the likes of those sold by MakerBot look like child’s play"
                            Terminator-style 3d printer builds models in minutes. Modern notion|
                            "watching paint dry. At the TED conference in Vancouver last week"
                            Stepcraft 2 — an all-in-one 3d printer, cnc mill, hot wire cutter,, more — launches. 3Dprint.Com|
                            "2013 in Europe and now wish to expand on their success, with a new, much more capable machine"
                            Terminator-inspired 3d printer grows objects from liquid. The indian panorama|
                            "transforming manufacturing from cars, planes, and turbines to dental or surgical implants"
                            Adafruit 3d prints trophy for upcoming dronie awards using bronzefill filament. 3Ders.Org|
                            "both the talent and the technology that have made this new style of storytelling possible"
                            Dutch hobbyist 3d prints a slide scanner to digitize dozens of old family photos. 3Ders.Org|
                            "thereby destroying lots of data and even family archives, photos and other meaningful things"
                            It can print 30mm in height at a 50 micron resolution in just 6 minutesAustralian company. Slashdot|
                            "It can print 30mm in height at a 50 micron resolution in just 6 minutes"
                            • dukejazzD Offline
                              dukejazz
                              Makerbot and umass amherst team for 50-printer innovation center in library. 3Dprint.Com|
                              "offer it to students and communities free of charge, for the most part"
                              3D printing essentials and trends. Machine design|
                              "to be cost, build space, tolerance, and the materials it can handle"
                              A different kind of printer. Mason city globe gazette|
                              "Mason City Globe Gazette. Overcast. 36°. Overcast. Weekly Forecast"
                              Blokko launches to merge 3d printing and online storytelling. E27|
                              "3D printers, such an innovative solution could soon become a wide-scale reality"
                              3D printing from a pool of resin. Fubiz|
                              "rapide qui est 25 Ă  100 fois plus rapide que les mĂ©thodes d’impression 3D conventionnelles"
                              Apple rubber welcomes 3d printing. Apple rubber|
                              "at Apple Rubber were considering how 3D printing could be part of our company’s future"
                              Speedy 3d printing in minutes. Nature|
                              "to three-dimensional (3D) printing so that objects are produced in minutes instead of hours"
                              New super-fast 3d printer builds objects in 6 minutes. Gizmodo australia|
                              "moving before illuminating again, Gizmo 3D’s prototype does it all in one fluid process"
                              Autodesk's tinkerplay app: fun with 3d design and 3d printing. Engineering.Com|
                              "Autodesk also plans to make Ember’s CAD designs and material formulations publicly available"
                              3D printing's timely entry into watchmaking. Spark - autodesk|
                              "a intricate details required for watch-making, from the mechanics to the external design"
                              Tech tuesday: 3d pens at 70% off. Wwl|
                              "3D Stereoscopic Printing Pen is leading the way and is one of my favorite today"
                              Speedy 3d printing in minutes. Nature.Com|
                              "a dimensional (3D) printing so that objects are produced in minutes instead of hours"
                              Physicist sees laser beamlet 3d metal printer transforming speed, affordability. 3Dprint.Com|
                              "as he astutely points out is right now simply too slow for comprehensive manufacturing"
                              Tumaker launches the voladora v3 3d printer with unique print heads, the. 3Dprint.Com|
                              "a manufacturing and prototyping, they all want to grab a piece of the pie"
                              http://3dprint.com/wp-content/uploads/2015/03/tumaker3.jpg
                              This amazing 3d printed tool can drill holes in metal using nothing but human. 3Dprint.Com|
                              "was battery operated. Now, another company has 3D printed yet another dril"
                              Peter jansen unveils a solder paste extruder for 3d printing. 3Dprint.Com|
                              "a board design, fabrication, surface mount soldering, and large-scale project planning"
                              Gizmo 3d unveils super fast 3d printers!!. 3D printing forum 3d print board|
                              "everyone will be able to 3D print with the speed that Carbon3D unveiled last week"
                              Blazing fast 3d printer makes objects in just 6 minutes. Popular mechanics|
                              "a solutions he's in the process of patenting that enable the speed of the printing"
                              Maker builds a DIY SLA 3D printer for less than $30. Bits & Pieces from the Embedded Design World|
                              "with ingenuity in abundance—which they use to share new innovations with the world"
                              • dukejazzD Offline
                                dukejazz
                                voxeljet Teams Up with Altair, Click2Cast, & HBM nCode in New 3D Printed Mold. 3DPrint.com|
                                "3D printing certainly can improve upon that wheel"
                                voxeljet Partners for New Mold Making Technique Using 3D Printing. 3D Printing Forum|
                                "concept, which they say offers “solid potential for serial manufacturing and mass production"
                                Top 10 New 3D Printing Materials You Should Try. 3DP Unlimited|
                                "3D printing is another sector that is destined to grow exponentially in the coming years"
                                Taulman's Year-Long Development of Alloy 910. 3D Printer World|
                                "similarities and features we wanted in 910,"said Tom Martzall, Taulman 3D founder"
                                Airwolf 3D Offers 3D Printer Leasing Programs — Apply & Lease Within Hours. 3DPrint.com|
                                "in educational projects, as well as those starting out at the complete novice level"
                                Airwolf 3D to Lease 3D Printers - Ten Links. Full Coverage|
                                "Kapton, resulting in better part stick and less tears to the printing surface"
                                Airwolf Now Leasing Our their 3D Printers. 3D Printing Forum - 3D Print Board|
                                "choose from a number of options, and be approved within a matter of hours"
                                How Can Today's 3D Printed Designs Aid The Development Of 4D Printers?. Gazette Inquirer|
                                "yet – we run the risk of skipping over an important link in the middle"
                                The Weistek IdeaWerk 3D Printer. Fabbaloo|
                                "a device offering a simple, yet reliable solution to your 3D printing requirements"
                                http://static1.squarespace.com/static/509c281de4b0cd18c7335aab/t/550f30fae4b06e8da2f1c17c/1427058943715/?format=750w
                                The Printrbot Team Assembles 154 Simple Metal 3D Printers in Just 7 Hours. 3DPrint.com|
                                "has grown by leaps and bounds and nearly all of their products receive rave reviews"
                                BEST OF TED: What If 3D Printing Was 100x Faster?. Innovation Excellence (blog)|
                                "strong parts. Could it finally help to fulfill the tremendous promise of 3D printing"
                                Stepcraft 2 Universal Desktop CNC Machine And 3D Printer In One (video). Geeky Gadgets|
                                "cutter, plotter and more then the new Stepcraft 2 might be worth further investigation"
                                3DFormer Pen Launches on Kickstarter. 3DPrint.com|
                                "it features “easy-to-use, easy gripping, precision movement"
                                Meet the DaVinci Junior: a desktop 3D printer for under ÂŁ300. Shiny Shiny|
                                "you can customise to suit you, including pendants, phone cases, even glasses"
                                Maker creates SLA 3D printer using an old projector and $10 in parts. 3Ders.org|
                                "some borrowed parts, an Arduino Uno and less than $10 in supplies"
                                Ingenious 3D printed drill can drill holes in wood and metal. 3Ders.org|
                                "it shows us just what you can accomplish with a bit of innovative design ideas"
                                Vader molten metal 3d printer. 3D Printing|
                                "object can be made. It could be considered world’s first molten metal 3d printer"
                                Could a Laser Beamlet 3D Printer Transform the Industry?. 3D Printing Forum - 3D Print Board|
                                "with (because yes, we do want it all) affordability and great qualit"
                                Gizmo 3D Printers Develops Another Rapid Printing Process. Fabbaloo|
                                "came out and it’s true: Gizmo 3D has an alternate fast printing solution"
                                3D printers. Product chart| choose the right 3d-printer for you on this
                                "you want, whenever you want and as any times as you want in house"
                                • dukejazzD Offline
                                  dukejazz
                                  Formlabs form 1+ sla 3d printer review | trustedreviews. Trustedreviews|
                                  "to buy multiple tanks and have them each filled with a different colour of resin"
                                  Powerful brainboard 3d printer / cnc controller launches on indiegogo. 3Dprint.Com|
                                  "to add mechanical support to the electronics, all in a sleek and beautiful design"
                                  3D systems corporation: long-term prospects look bright. Valuewalk|
                                  "to integration of more than 50 acquisitions"
                                  3D systems announces 3d scanning laptops. Ten links|
                                  "to create printable 3DMe selfies watch a video highlighting this immersive shareable experience"
                                  Dentists will soon be able to 3d print you a new tooth in minutes. Quartz|
                                  "a impressive, but ultimately out of reach and arguably bearing little relevance in daily life"
                                  Creating 3d printed functional bronze scissors using the $1500 mini metal maker. 3Ders.Org|
                                  "normally be plastic 3D prints using the Fused Deposition Modeling method of 3D printing"
                                  Other 3d printers. Ic3d printers| $599.00 $599.00. The printrbot metal simple fully assembled 3d fused
                                  "PLA thermoplastic filament (sold separately). The Usually ships in 24 hours"
                                  Ted talk video: what if 3d printing was 100x faster?. Element14|
                                  "100x faster Liquid Terminator from T2 Inspired new 3D Printing Technique"
                                  County road 12: auburn's 3d printer. Wsfa|
                                  "melts the printer head moves back and forth slowly building a three-dimensional model"
                                  3D Printing and the Retail Trend – Can We 3D Print Some Customers?. Association of 3D Printing|
                                  "to bring more customers to their stores in order to see and experience 3D printing"
                                  FDM Extruder Hot Ends with Inductive Heating. 3D Printing|
                                  "well researched and cheap but it’s bulky and takes some time to reach desired temperature"
                                  http://3dprinting.com/wp-content/uploads/2015/03/3d-printer-hot-end-schmeatics.jpg
                                  Titan 1 with Red Ruby Cover. |. 3D Printing Industry|
                                  "the SF, ABS, Castable, and Spot-HT Resins, a build platform"
                                  Faster, more impressive 3D printing techniques in the works. Malay Mail Online|
                                  "planning to sell its innovative printers through Kickstarter later this year"
                                  JK Lasers to Attend Laser World of Photonics, June 22-25, Munich, Germany. |
                                  "for companies like JK Lasers to develop business relationships and generate valuable leads"
                                  3D Printing around the office. 3DPrinterOS|
                                  "through the power of 3D Printing, we now have a useable chair again"
                                  Dentists will soon be able to 3D print you a new tooth in minutes. Textually.org|
                                  "soon encounter a 3D printer in the most banal of everyday places: your dentist"
                                  3D Printing Materials - Zero Waste Box. TerraCycle Zero Waste Boxes|
                                  "when we receive your box, we'll safely recycle all of the collected material"
                                  3D printer renkforce rf1000 single extruder value.974113. Conrad.Com|
                                  "to create 3D objects, sets new standards when it comes to 3D model making"
                                  • dukejazzD Offline
                                    dukejazz
                                    Faster, more impressive 3D printers on the horizon. CTV News|
                                    "Gizmo 3D is planning to sell its innovative printers through Kickstarter later this year"
                                    Dreamworth 32ft/10 Meters 3D Pen ABS 1.75mm Fun Sampler Pack Quality Filament. Desktop 3DP|
                                    "Is there a filament you can't find! Do you need a replacement part?"
                                    Desktop recycler that turns pop bottles into 3D printer plastic. 3D Printing Progress|
                                    "Lego, and melt it into a filament that can be fed into 3D printers"
                                    Eastman Chemical expanding Tritan co-polyester capacity. European Plastics News|
                                    "now gives the firm almost 170 million pounds of annual Tritan capacity there."
                                    New Me Ducer 3D printer offers plug n' play 3D printing for less than $500. 3Ders.org|
                                    "a few years ago - particularly with Fused Deposition Modeling (FDM) 3D printers"
                                    videos. Reddit| As someone who just finished building two 3d printers from
                                    "many times must the linkage on the nozzle fall off before he secures it bette"
                                    How to prepare Hydroxyapatite for 3D printers? and how can I purchase Hydroxy. ResearchGate|
                                    "shrinkage might be so high that your parts will crack and delaminate post-sintering"
                                    3D printer owners. Etsy| I haven't been able to find an answer to this
                                    "insert a new spool, or is your project ruined"
                                    Chinese Company Unveils a Super Fast SLA 3D Printer – Can Print 2712 cm3 in . 3DPrint.com|
                                    "a crowdfunding campaigns only to close up shop before their campaigns even got off the ground"
                                    http://3dprint.com/wp-content/uploads/2015/03/prismlabfeatured.jpg
                                    Airwolf 3D Printers. 3Dprintler| Airwolf 3D Printer AW3D V.5 + 1 LB Filament Assembled
                                    "the tinkerer, serious engineer, mechanic, artist, student, hobbyist, inventor"
                                    Adam's tech: The CEL Robox 3D printer. Dailymotion| Watch the video «Adam's tech: The CEL Robox
                                    "to watch free or on-demand movies, series or creative and exclusive"
                                    County Road 12: Auburn's 3D Printer. WFXG.com|
                                    "a huge difference it's making at the Veterinary Teaching Hospital"
                                    3D Printers. GP3D.com| 3D printer that will excite and stimulate your mind! Learn
                                    "where we continue our focus on providing top quality products that are environmentally sound"
                                    Add 3D Printing plastics to materials. Autodesk Community|
                                    "watch?v=J8bPXk5od4I Basically its an optimisation algorythm for weak 3D printed parts"
                                    Bernis simple 3d printing bowden extruder.Thingiverse|
                                    "So that you don't loose steps try it with your own hardware equipment"
                                    Layerless 3d printing process unveiled. Makerflux|
                                    "their contribution to the 3D printing process, and it doesn’t involve layers of filament"
                                    Tiko unibody 3d printer launches on kickstarter starting at just $99. 3Dprint.Com|
                                    World's First Heated 3D Print Finishing Tool Launches on Kickstarter. PR Newswire|
                                    "variable heat settings and interchangeable tips designed specifically for finishing 3D prints"
                                    • dukejazzD Offline
                                      dukejazz
                                      Pasadena's New Matter to offer 3D printers for under $400. The San Gabriel Valley Tribune|
                                      "sophisticated gadgets in their home or office, much like a computer or smartphone"
                                      Faster, more impressive 3D printing techniques on the horizon. The Star Online|
                                      "Gizmo 3D's new system prints objects by layering liquid resin from the top down"
                                      Taulman Releases Nylon 680. 3D Printer World|
                                      "making the printing process as easy as printing many other polymers in use today"
                                      Pebble Time smashes all Kickstarter records: Smartwatch raises more than $20 . Daily Mail|
                                      "Pebble has surpassed all previous records"
                                      Zmorph 3D Scanner Now Available To Pre. Geeky Gadgets|
                                      "the new 3D scanner was unveiled during CeBit in Hannover, Germany earlier this month"
                                      http://www.geeky-gadgets.com/wp-content/uploads/2015/03/Zmorph-3D-Scanner-1.jpg
                                      The TIKO 3D Printer Launches on Kickstarter for $99. 3D Printing Industry|
                                      "past the halfway mark of its $100,000 goal"
                                      Leasing 3D Printers: Airwolf 3D Forms Alliance to Reduce Upfront Cash Payment. 3DP Industry|
                                      "thus reducing the pricey upfront cash payment for both the general public and businesses"
                                      Part 3D Printer, Part 1950's Table Saw. 3D Printing Forum - 3D Print Board|
                                      "components, and some higher-tech additions, Bridgewater created his working 3D printer"
                                      BoXZY all-in-one 3D printer, CNC mill, & laser engraver. Boing Boing|
                                      "can shape wood, plastics, and many metals using most commercial CAM programs"
                                      Affordable Desktop 3D Printer. Thunderclap| “The worlds first most affordable desktop 3D Printer
                                      "Printer because of its price and how complicated it can be to use it"
                                      3D printing just got faster, cheaper and more useful than ever.. Megafounder Blog|
                                      "a process of replacing old technologies by newer ones as become cheaper and broadly available"
                                      Get past3d - ep. 1 - 3D printing silicone (part 1). Structur3d printing|
                                      "hardware store with the Discov3ry Paste Extruder on a Felix 3.0 3D Printer"
                                      This 3D Printed Pen Can Do Anything
 Well Almost Anything!. 3DPrint.com|
                                      "innovation, as now everyone has the ability to bring their ideas to life"
                                      10 Reasons Why Multi-Material 3D Printing is Better for Your Product Design. Desktop Engineering|
                                      "choice of materials to combine when you prototyped a design. Wouldn’t that be cool"
                                      RoBo R1 3D Printer Becomes Independent Device with MatterControl Touch. 3DPrint.com|
                                      "back and forth between the 3D printer and your other devices—mainly a computer"
                                      World first 3D print finishing tool featuring heated interchangeable tips launches. 3Ders.org|
                                      "a mold or simply just as-is but in its most optimal finished state"
                                      China's Prismlab Unveils Super Fast SLA 3D Printers. Inside 3D Printing|
                                      "Gizmo 3D who had unveiled yet another incredibly fast SLA-based 3D printing process"
                                      Introducing the 3D Printed Multi-tool Pen. 3D Printing Forum - 3D Print Board|
                                      "a smartphone stand (two varieties} a hex key; a toy gun"
                                      The Rapide Lite 200XL 3D Printer. Fabbaloo|
                                      "Making this printer one of the most affordable large 3D printers available toda"
                                      3D Printer. Pinterest| Pins about 3D Printer hand-picked by Pinner Lexie
                                      "fun birthday gift ideas you can use for your friends or family. Bucket"
                                      • dukejazzD Offline
                                        dukejazz
                                        Friday:
                                        Company Prints First 3D PPE. EHS Today|
                                        "using a CAD (computer-aided design) file and a 3D modeling program"
                                        Tiko. Kickstarter| Tiko 3D is raising funds for Tiko - The Unibody
                                        "so the project captured over 80% of its initial goal from 600 backers"
                                        High-heat and impact PLA for 3D printing yields tight tolerances and less. plastemart.com|
                                        "eliminating certain property tradeoffs normally encountered with standard grades of this resin"
                                        The Diamond Hotend, for Multi-color & Multi-material 3D Printing Offer by Denmark s. 3DPrint.com|
                                        "what’s more, it could be ready for shipping as soon as June 2015"
                                        Retouch3D, A Heated Tool Designed Specifically For Retouching 3D-. Laughing Squid|
                                        "the pen’s interchangeable heads melt the imperfections in the final object back into place"
                                        X3D Launches Kickstarter Campaign for the Genesis 3D Printer — Starting at Just. 3DPrint.com|
                                        "on top of that, they added in a bit of a pleasant surprise"
                                        Air Products Unveils Website to Help in 3D Metal Printing. Zacks.com|
                                        "by offering various technical information, online tools and gas supply options, among others"
                                        ATSmake Announces Six New 3D Printers, Including the Jupiter 2. 3DPrint.com|
                                        "just announced a laundry list of new 3D printers they will soon be making available"
                                        http://3dprint.com/wp-content/uploads/2015/04/at2.png
                                        Air Products Unveils Website to Help in 3D Metal Printing - Analyst Blog. Nasdaq|
                                        "technical information, online tools and gas supply options, among others"
                                        World s most conductive 3D-printing filament now shipping. Plastics Today|
                                        "of circuit boards, flashlights, lighted wearables and more, according to the company"
                                        Titan 1 SLA 3D Printer Awesome Speed Demonstrated (video). Geeky Gadgets|
                                        "2 to 3 weeks and will be priced at $3,000 per system"
                                        Faster 3D Printing Support Removal of Wider Range of Materials. MCADCafe (press release)|
                                        "have been simplified and made easier to replace by the user or local support provide"
                                        Functionalize Breaks Another World Record for Electrically Conductive 3D. Press Release Rocket|
                                        "mechanical strength was better than its previous beta material, as well as virgin PLA"
                                        Optimizing the Filament Spool and Guide on MakerBot Replicator 2. 3D Printing Blog|
                                        "two small parts that will be used to guide the filament to the extruder. All in all you can do"
                                        The Retouch3D Finishing Tool. 3D Printer World|
                                        "print with acetone vapor or taking an X-Acto knife to supports and rafts"
                                        Cordless 3D Print Finishing Tool. Kickstarter|
                                        "attachments to remove 3D Print defects! Recharge from a USB port! Replaceable tips"
                                        MightyApes first-experience with our Da Vinci 1.0 3D Printer. 3D printers|
                                        "manual and it was all in there, very clearly written with pictures and arrow"
                                        3Dprinting. Reddit| They read temps differently from other printers. I usually print
                                        "clogged. What's your print temp? Material? Is the filament free from snags"
                                        Build Your Own 3D Printer. STEM Experience|
                                        "end of the week long campers gained confidence to operate and repair their own printer"
                                        3D Printer for Fabrics. Electroloom| Expanding the 3D printing paradigm. We ve developed a novel
                                        "print fabrics. Our vision of the future is one where fabric designs become digital"
                                        • dukejazzD Offline
                                          dukejazz
                                          Ingeo PLA filament in 3D printing. NatureWorks LLC|
                                          "independent company newly formed to supply Ingeo filament to the additive manufacturing market"
                                          Ultimaker 2 is the most popular 3D printer model. htxt.africa|
                                          "trend survey to illustrate the state of the 3D printing industry on a global scale"
                                          http://www.htxt.co.za/wp-content/uploads/2015/04/Ultimaker-2-658x370.jpg
                                          E3D Unveils Most Affordable 3D Printer Hotend Yet, The E3D Lite6 — Priced Under . 3DPrint.com|
                                          "released onto the build platform. A faulty hotend equates to terrible print results"
                                          backJoris Peels Christina Rebel Launch OBLIQUEA Curated Gallery for 3D Printed . 3DPrint.com|
                                          "helped co-found a 3D printing startup called Origo 3D printing a while back"
                                          The very best 3D printer-in-action video ever. Kentucky Post Pioneer|
                                          "may well be the future of how we make things, but there is a lot of waste, and it uses"
                                          Functionalize Now Shipping Conductive F-Electric 3D Printing Filament. 3DPrint.com|
                                          "process was finally over, Toutonghi looked to 3D printing to solve the tedious problem"
                                          WOLFBEND TPU Flexible Filament. Airwolf 3D|
                                          "a popular material found in cases of mobile electronic devices, such as mobile phones"
                                          Featured Videos. altem.com| How 3D Prnting works to FDM videos to 3D Printers
                                          "Rapid Prototyping with FDM and PolyJet-based Stratasys 3D Printers at Hyphen"
                                          Tiko is the $179 unibody 3D printer you've always wanted. Bits & Pieces Design World|
                                          "unibody chassis with pre-aligned beams on the inside of its frame"
                                          SEMA Garage Tour—3D Printing, Scanning, Photography Studio and More. Sema|
                                          "art tools and equipment are available, watch the video to the right"
                                          Direct Metal Laser Sintering (DMLS). ARRK Product Development Group|
                                          "established as a trusted and reliable 3D printing process for rapid prototyping"
                                          Affordable Fast Gizmo 3D Printer Coming to Kickstarter this Fall. 3D Printing Today|
                                          "Kobus du Troit about their upcoming Kickstarter campaign and their plans for the future"
                                          3D printing ceramics with Bussoga. 3Digital Cooks|
                                          "the awesome tiles that we have been using as dishes for the pasts few months"
                                          New Tool Helps With 3D Print Finishing. Castle Ink (blog)|
                                          "State University, Porras worked in the semiconductor industry creating parts for machines"
                                          Solderdoodle 3D Print Finishing Machine. 3D Printing Forum - 3D Print Board|
                                          "to a tool he calls the Solderdoodle, intended to remove defects from 3D prints"
                                          Soon, you will be able to product high-resolution 3D objects by just taking a snapshot . IBNLive|
                                          "minutes you have reproduced an accurate replica of the original object"
                                          Powder-based 3D Printing Method Developed. Jetson Green|
                                          "sheets of wet cement, as most other researchers in this field are approaching it"
                                          Only Rs 7 lakhs to boost print efficiency - The Noel D'Cunha Sunday Column. PrintWeek India|
                                          "were at a disadvantage because the heat and humidity damaged the quality of their work"
                                          Castro RadioShack Liquidating Supplies, To Close In Two Months. Hoodline|
                                          "corporate parent, and that the liquidation sale should last for the next two months"
                                          • dukejazzD Offline
                                            dukejazz
                                            Welcome to these current news listing on 😎 Monday, Wednesday and Friday:
                                            New 3d Machines Unveilings & Pens, Scanners, Elements Id ::
                                            3D Prints the designers foods for eating
                                            ➡ 3D Printing Stories via Colleges, Classrooms & software
                                            ➡ New 3d Machines Unveilings & Pens, Scanners, Elements Id
                                            Monday:
                                            3D Printing Stories via Colleges, Classrooms, Libraries and Software
                                            ( Highlight WEB title. line right click the mouse, click on search provider and go to the WEB page )
                                            Student Creates Fast Membrane Based 3D Printer – Prints 40 x 40 x 100. 3DPrint.com|
                                            "to be able to print 2,712.27 cm3 of material per hour"
                                            Flashforge USA Joins Forces with Simplify3D Software. 3DPrint.com|
                                            "spend less time on “cumbersome technology processes and more time creating stunning 3D prints"
                                            Sculpteo Blog. Sculpteo| Since 2009, we have been involved in the 3D printing
                                            "round proves our strong belief that 3D printing is an industrial revolution in the making"
                                            Australian scientists create software to print money on 3D printers. 3Ders.org|
                                            "everything from mochas at Starbucks to new sneakers from Nike may soon become a reality"
                                            Problem exporting model for 3D printing. Blender Artists|
                                            "shop to sell your own models. It’s like the Etsy of 3D printing"
                                            Adult 3D Printer Workshop. Central Piedmont Community College|
                                            "workshop, you will gain the skills needed to operate and repair your own printer"
                                            3D Printing in Education. AccuCode|
                                            "3D printing is a fad, you don’t understand the doors it opens to learning"
                                            WHAT IS 3D PRINTING. Triple 3D|
                                            "article will walk you through the definition, techniques and applications of this technology"
                                            Handmade 3D printers, open source at Netflix, and more. opensource.com|
                                            "printers, open source at Netflix, and David Both on Linux, and more"
                                            DreamFactory Unveils BuddyRacers – Fun, Educational, Functional 3D Printable . 3DPrint.com|
                                            "begun to see classrooms as young as kindergarten begin bringing this technology to students"
                                            North Somerset schools can apply for cash from WS Atkins for 3D printers. South West Business|
                                            " disabled people and those from disadvantaged backgrounds were underrepresented in science"
                                            Company news: Newland Center for Adult Learning and Literacy receives $25000 . Syracuse.com|
                                            "supports programs that educate and empower women to lead happier and more productive lives"
                                            Will.i.am Transforms a Community Through Education. Chase News & Stories|
                                            "a fancy event. It was a chance to help the children of Los Angeles"
                                            Sculpteo Raises 5 Million Euros for 3D-Printing Services. Inside 3D Printing|
                                            "expanding its industrial base, growing even further, and extending its global reach"
                                            Math Professors + 3D Printing = Real World Learning. Pearson|
                                            "held March 2015, was about 3D printing. The steering and program committees"
                                            http://www.pearsoned.com/wp-content/uploads/Pythagorean_theorem-770x370.jpg
                                            TechTown provides spring break learning for local students. WRCB-TV|
                                            "safely experiment with robotics and circuitry as well as filming and editing their creations"
                                            “Unconference” hosts students, parents and educators. Shore News Today|
                                            "each person’s voice to be heard so that we can all learn from one another"
                                            Garissa Universityxc
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 49
                                            • 50
                                            • 28 / 50
