    Two plugins needed to properly integrate VRAY with Sketchup
    13 Posts 6 Posters 2.9k Views 6 Watching
      Or add the people in post.
        AcesHigh
        they dont receive correct shadows, luminosity... nor cast correct shadows, etc. If they are behind glass or some transparent material, its also an added difficulty.
        • Chris FullmerC Offline
          The V-Ray plugin not correctly updating whats visible or not in their batch export seems like something that asgvis should implement, not ruby, right?
          • PixeroP Offline
            Pixero
            A long time ago I contacted ASGvis about a project where I had problem with face me components not working right in animation.
            They helped me with a modified version of my script JS_FrameStep but since the project was already finished I havent tested it so I'm unsure how well it works. 😳
            Thomtom, (or other scripter) PM me if you want to see the code. (I dont want to release it in its current state when I dont know if/how well it works.)
              Really? There is a workaround?
              PM ahoy!
                AcesHigh
                so have you guys exchanged the code for the workaround? 😄
                • PixeroP Offline
                  Pixero
                  Thomthom got it but I dont know if he has had time to look in to it.
                    Sorry, it ended up in the backburner. Haven't had much coding time.
                    • OgekuriO Offline
                      Ogekuri
                      There is any update about the JS_FrameStep and the possibility to render each scene in a batch process according his hidden/or not hidden objects?
                        guillaumepara
                        Thread has been inactive for a while, but the 'Faceme' component issue has been fixed with V-Ray 2.00 and Sketchup 2015. Either when rendering animations or batch rendering scenes.
                        I run through this issue with previous version of V-Ray. Works fine right now, and 'faceme' component shadows are now also taken in into account...
