    Cutting components leave holes after layers disabled
    5 Posts 3 Posters 2.4k Views 3 Watching
      masp
      I've actually noticed this bug for several years: if I create a surface inside a group, then cut a hole in that surface (inside the group) with a (cutting) component, and then put that component onto its own layer, and then finally turn off that layer, the component will disappear, but the hole that it cuts in the surface will remain. To get rid of the hole I have to select the surface inside the group. It's quite annoying, as I like to use component (on their own layers) to model potential locations for doors and windows, and use layers (via scenes) to switch between them. But as soon as I put the surface inside groups I get these annoying ghost holes left behind by each component that is no longer visible because its layer has been turned off.
      Steps to reproduce:
      1. create a surface
      2. create a group containing that surface
      3. click into that group
      4. cut a hole in the surface with a component
      5. assign the component to a new layer
      6. leave the group
      7. turn off the component's layer
      8. observe an annoying hole where the component used to be.
      9. click into the group again
      10. observe that the hole has disappeared.
      Note: this only happens when the surface being cut is within a group (or component) of its own.
      • cottyC Offline
        cotty
        I can reproduce this in both directions (hide and unhide), see this screencast and the attached example model...
        I would call this an unexpected behavior too.
        [screenr:1yzkq5k1]jTfN[/screenr:1yzkq5k1]
        holeingroup.zip
        my SketchUp gallery
        • JQLJ Offline
          JQL
          It's annoying but has been like that since I remember.
          www.casca.pt
          Visit us on facebook!
            masp
            I've verified that this bug was not present in Sketchup Free 7.1.6859 . I think it may have been introduced in Sketchup Free 8 (but haven't verified that). It's certainly been around for several years, surprisingly.
            Mike
            • JQLJ Offline
              JQL
              Never used 7 myself...
              www.casca.pt
