    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 89.7k Views 41 Watching
    • OxerO Offline
      Oxer
      Yes, I can place the stock selected, I can't write in the input field by click but I have discovered that you can access to it pressing Tab key, nothing in Ruby Console.
      • eneroth3E Offline
        eneroth3
        Sounds very similar to a bug with the style sheets I had really early when I published the plugin. For some reason Safari didn't understand the content of the window was supposed to be able to be clicked. Does the filter function as expected once you tab to it? I'll try to debug the dialog in safari outside Sketchup on my computer.
        My website: http://julia-christina-eneroth.se/
        • OxerO Offline
          Oxer
          I remember this bug happened a time ago, the images in Create tab aren't showing:
          The translations should so far still work for everything except the newly added features but the translation file has to be downloaded separately, there's both a German and Spanish one earlier in this thread.
          Placing the es.I10n file in the ene_railroad folder the plugin isn't translated because the lang.rb file isn't in the ene_railroad folder and your files haven't the S.tr text in the strings
          • deaneauD Offline
            deaneau
            oxer i have look at the date of the plugins inside (0.1.19 windows). all RB-files have a date from 2014 or older.
            could be christina have upload the wrong version for this plugin.
            • eneroth3E Offline
              eneroth3
              Dean is right! 0.1.19 has been mixed up with an older version 😲 😲 😲 😲 but it's now corrected and the current version in the pluginstore should be the correct one.
                driven
                hi,
                track.rb is saved with Central European (Windows Latin 2) encoding and causes invalid byte sequence in UTF-8 error [at least on a mac]
                I haven't checked any others yet...
                • deaneauD Offline
                  deaneau
                  oh ok..
                  • eneroth3E Offline
                    eneroth3
                    @driven said:
                    hi,
                    Ooops, I had written an ä in a Swedish word in a comment since I didn't know the English term at the time. Now it's fixed and version 0.1.20 published.
                      Ralle
                      Hallo there...
                      It´s a great plugin at all. Big thanks vor this. It saves a lot of work.
                      But i have a question. I can not get the additional Streets working. I put them
                      into the Tracksfolder. The only things i got are the leadinglines and SU2015 starts crashing. All the othes stuff works fine.
                      Greetings
                      Ralph
                      • eneroth3E Offline
                        eneroth3
                        @ralle said:
                        Hallo there...
                        Greetings
                        Ralph
                        Hi Ralph
                        Those tracks are for an older version of the plugin but if you place their folders in "tracks/" directly in the template's folder (NOT "templates/tracks/"), open the ruby console and run "EneRailroad::Templates.convert_old" (without quotes) they should be converted to the new format.
                        On what page did you find them? I could update them in case anyone else wants to download them.
                          Ralle
                          Hallo Eneroth.
                          Now that I'm back from a bad cold the last weeks, i'm follow your instructions.
                          But without a good result, with exeption, SU doesn't crash anymore after useing
                          the streets. How ever, i don't have any primitves of the streets, only the leadinglines.
                          Greetings ..
                          Ralph
                          • eneroth3E Offline
                            eneroth3
                            Finally there's a new version published. Version 0.1.21 adds back the translation support. It also has a completely new feature for listing certain parts of structure (for now the pillars of the JPods structures) and lets users reposition them accurately. This feature is found under Extensions > Eneroth Plugin System > Structure Part Info. There's also a security notification added when models load if they contain potentially harmful executable code used by the balise feature. Finally there are some bugfixes regarding how missing templates are handled.
                            Download
                            • eneroth3E Offline
                              eneroth3
                              @ralle said:
                              Hallo Eneroth.
                              Greetings ..
                              Ralph
                              That's odd. Can you send me a zipped copy of the streets' track folders?
                                Anton_S
                                Thank you for an update, eneroth3 😄
                                • deaneauD Offline
                                  deaneau
                                  0.1.21 crash some times if i layout tracks.
                                  steam locos jumps when i try to drive.
                                  Page Not Found
                                  Web word processing, presentations and spreadsheets
                                  (drive.google.com)
                                  sketchup make 2015
                                  • deaneauD Offline
                                    deaneau
                                    Is ths project dead?
                                    or is revit and rhino now your favorite? 😉
                                    dean aka yellowdoor/deaneau
                                    • Lemoyne ArchitectL Offline
                                      Lemoyne Architect
                                      Simply incredible! Now I have to resist the urge to play with this instead of working on my clients’ projects today. 😄
                                        Like_Quo20
                                        Hi all!
                                        Can someone please explain to me where I can find and add roads to the plugin?
                                        I like it a lot, very useful!
                                        Best regards,
                                        Koen Schreurs
                                          Like_Quo20
                                          Can someone please explain me how to add trains or where to get them from?
                                          I have been trying to add a train with the option in the plugin but that doesn't work proparly.
                                          I hope someone can help 😄
                                          Best regards,
                                          Koen Schreurs
                                          • OxerO Offline
                                            Oxer
                                            The plugin includes the Documentation, go to Plugins>Eneroth Railroad System>Documentation
                                            • 11
                                            • 12
                                            • 18
                                            • 19
                                            • 10 / 19
