    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.2k Views 41 Watching
    • eneroth3E
      eneroth3
      I've found a fix for the switch bug and will upload a new version as soon as another bug I'm working on now with track ends sometimes not updating when placing from library is solved.
      No vacation, just a lot of things to do in school.
      My website: http://julia-christina-eneroth.se/
      • eneroth3E
        eneroth3
        New version uploaded with a fix for the switch tool bug, a bug with tracks not connecting properly when drawn from library and a bug with saving rolling stocks' data on model save.
        Download
        Thanks for the bug report, Dean!
        • Y
          ying2014
          UI Changed a lot,can't use the language file ?
          • OxerO
            Oxer
            There are some problems with this update on OS X 10.10.2 & SU 2015:
            1. I can't select a different train to default in the Add Rolling Stock window, the icons and the input field Filter don't work.
            2. If I have selected a track, the Track Properties icon in the toolbar is off (I know that I have access by right click or Menu > Plugins > Railroad > Track Properties).
            3. No more support to translation to the other languages, for me and I think to the other people it's a good solution to have the plugins in their language. 😢 😢 😢 😢
            I understand that it's a hard work give support for translations but I can help you with this if you give me the rules to introduce the codes corresponding in the different files, this isn't problem for me. 😉
            Thanks for your efforts to make the plugin better!! 👍
            • eneroth3E
              eneroth3
              That's odd. Can you still place the already selected one? Is it possible to write in the filter or can't it be focused at all? Is anything written to the console when activating the add rolling stock tool?
              I removed the properties icon from the toolbar quite a long time ago since it got really big with all the new tools. However you should be able to right click the track directly and open the window from there.
              I think I can add the translation support to the new mode of the add track tool but wait with doing anything to the system for creating and editing custom tracks, signals etc since that part may be changed and perhaps isn't used by most people anyway.
              • OxerO
                Oxer
                It is not the best solution, close session on OS X, run bootcamp to use one plugin only in Sketchup 😲
                When I need Railroad plugin I'll use the last version of the plugin with translation support. 😐
                • eneroth3E
                  eneroth3
                  @deaneau said:
                  @Oxer
                  the fastest solution is bootcamp and a windows OS.
                  for windows users. bootcamp is a software to start windows system on mac
                  @ying2014
                  christina will drop the language features. could be that this is the reason for your problem.
                  in the downloaded plugin folder you can´t find the lang folder. this mean (i think), christina drop this feature in 0.1.19 and newer versions.
                  dean
                  The plugin is supposed to work on OSX too, I just can't test it myself sicne I don't have it.
                  The translations should so far still work for everything except the newly added features but the translation file has to be downloaded separately, there's both a German and Spanish one earlier in this thread.
                  • deaneauD
                    deaneau
                    @Oxer
                    @ying2014
                    @christina where can i find the turntable in the version 0.1 19
                    the circle track i missing,too. this version look a little bit like an older version.
                    dean
                    • OxerO
                      Oxer
                      Yes, I can place the stock selected, I can't write in the input field by click but I have discovered that you can access to it pressing Tab key, nothing in Ruby Console.
                      • eneroth3E
                        eneroth3
                        Sounds very similar to a bug with the style sheets I had really early when I published the plugin. For some reason Safari didn't understand the content of the window was supposed to be able to be clicked. Does the filter function as expected once you tab to it? I'll try to debug the dialog in safari outside Sketchup on my computer.
                        • OxerO
                          Oxer
                          I remember this bug happened a time ago, the images in Create tab aren't showing:
                          Placing the es.I10n file in the ene_railroad folder the plugin isn't translated because the lang.rb file isn't in the ene_railroad folder and your files haven't the S.tr text in the strings
                          • deaneauD
                            deaneau
                            oxer i have look at the date of the plugins inside (0.1.19 windows). all RB-files have a date from 2014 or older.
                            could be christina have upload the wrong version for this plugin.
                            • eneroth3E
                              eneroth3
                              Dean is right! 0.1.19 has been mixed up with an older version 😲 😲 😲 😲 but it's now corrected and the current version in the pluginstore should be the correct one.
                                driven
                                hi,
                                track.rb is saved with Central European (Windows Latin 2) encoding and causes invalid byte sequence in UTF-8 error [at least on a mac]
                                I haven't checked any others yet...
                                • deaneauD
                                  deaneau
                                  oh ok..
                                  • eneroth3E
                                    eneroth3
                                    @driven said:
                                    hi,
                                    Ooops, I had written an ä in a Swedish word in a comment since I didn't know the English term at the time. Now it's fixed and version 0.1.20 published.
                                      Ralle
                                      Hallo there...
                                      It´s a great plugin at all. Big thanks vor this. It saves a lot of work.
                                      But i have a question. I can not get the additional Streets working. I put them
                                      into the Tracksfolder. The only things i got are the leadinglines and SU2015 starts crashing. All the othes stuff works fine.
                                      Greetings
                                      Ralph
                                      • eneroth3E
                                        eneroth3
                                        @ralle said:
                                        Hallo there...
                                        Greetings
                                        Ralph
                                        Hi Ralph
                                        Those tracks are for an older version of the plugin but if you place their folders in "tracks/" directly in the template's folder (NOT "templates/tracks/"), open the ruby console and run "EneRailroad::Templates.convert_old" (without quotes) they should be converted to the new format.
                                        On what page did you find them? I could update them in case anyone else wants to download them.
                                          Ralle
                                          Hallo Eneroth.
                                          Now that I'm back from a bad cold the last weeks, i'm follow your instructions.
                                          But without a good result, with exeption, SU doesn't crash anymore after useing
                                          the streets. How ever, i don't have any primitves of the streets, only the leadinglines.
                                          Greetings ..
                                          Ralph
                                          • eneroth3E
                                            eneroth3
                                            Finally there's a new version published. Version 0.1.21 adds back the translation support. It also has a completely new feature for listing certain parts of structure (for now the pillars of the JPods structures) and lets users reposition them accurately. This feature is found under Extensions > Eneroth Plugin System > Structure Part Info. There's also a security notification added when models load if they contain potentially harmful executable code used by the balise feature. Finally there are some bugfixes regarding how missing templates are handled.
                                            Download
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 17 / 19
