    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 89.6k Views 41 Watching
    • eneroth3E Offline
      eneroth3
      @oxer said:
      There are some problems with this update on OS X 10.10.2 & SU 2015:
      1. I can't select a different train to default in the Add Rolling Stock window, the icons and the input field Filter don't work.
      That's odd. Can you still place the already selected one? Is it possible to write in the filter or can't it be focused at all? Is anything written to the console when activating the add rolling stock tool?
      @oxer said:
      2. If I have selected a track, the Track Properties icon in the toolbar is off (I know that I have access by right click or Menu > Plugins > Railroad > Track Properties).
      I removed the properties icon from the toolbar quite a long time ago since it got really big with all the new tools. However you should be able to right click the track directly and open the window from there.
      @oxer said:
      3. No more support to translation to the other languages, for me and I think to the other people it's a good solution to have the plugins in their language. 😢 😢 😢 😢
      I understand that it's a hard work give support for translations but I can help you with this if you give me the rules to introduce the codes corresponding in the different files, this isn't problem for me. 😉
      I think I can add the translation support to the new mode of the add track tool but wait with doing anything to the system for creating and editing custom tracks, signals etc since that part may be changed and perhaps isn't used by most people anyway.
      My website: http://julia-christina-eneroth.se/
      • OxerO Offline
        Oxer
        It is not the best solution, close session on OS X, run bootcamp to use one plugin only in Sketchup 😲
        When I need Railroad plugin I'll use the last version of the plugin with translation support. 😐
        • eneroth3E Offline
          eneroth3
          @deaneau said:
          @Oxer
          the fastest solution is bootcamp and a windows OS.
          for windows users. bootcamp is a software to start windows system on mac
          @ying2014
          christina will drop the language features. could be that this is the reason for your problem.
          in the downloaded plugin folder you can´t find the lang folder. this mean (i think), christina drop this feature in 0.1.19 and newer versions.
          dean
          The plugin is supposed to work on OSX too, I just can't test it myself sicne I don't have it.
          The translations should so far still work for everything except the newly added features but the translation file has to be downloaded separately, there's both a German and Spanish one earlier in this thread.
          • deaneauD Offline
            deaneau
            @Oxer
            @ying2014
            @christina where can i find the turntable in the version 0.1 19
            the circle track i missing,too. this version look a little bit like an older version.
            dean
            • OxerO Offline
              Oxer
              Yes, I can place the stock selected, I can't write in the input field by click but I have discovered that you can access to it pressing Tab key, nothing in Ruby Console.
              • eneroth3E Offline
                eneroth3
                Sounds very similar to a bug with the style sheets I had really early when I published the plugin. For some reason Safari didn't understand the content of the window was supposed to be able to be clicked. Does the filter function as expected once you tab to it? I'll try to debug the dialog in safari outside Sketchup on my computer.
                • OxerO Offline
                  Oxer
                  I remember this bug happened a time ago, the images in Create tab aren't showing:
                  Placing the es.I10n file in the ene_railroad folder the plugin isn't translated because the lang.rb file isn't in the ene_railroad folder and your files haven't the S.tr text in the strings
                  • deaneauD Offline
                    deaneau
                    oxer i have look at the date of the plugins inside (0.1.19 windows). all RB-files have a date from 2014 or older.
                    could be christina have upload the wrong version for this plugin.
                    • eneroth3E Offline
                      eneroth3
                      Dean is right! 0.1.19 has been mixed up with an older version 😲 😲 😲 😲 but it's now corrected and the current version in the pluginstore should be the correct one.
                        driven
                        hi,
                        track.rb is saved with Central European (Windows Latin 2) encoding and causes invalid byte sequence in UTF-8 error [at least on a mac]
                        I haven't checked any others yet...
                        • deaneauD Offline
                          deaneau
                          oh ok..
                          • eneroth3E Offline
                            eneroth3
                            @driven said:
                            hi,
                            Ooops, I had written an ä in a Swedish word in a comment since I didn't know the English term at the time. Now it's fixed and version 0.1.20 published.
                              Ralle
                              Hallo there...
                              It´s a great plugin at all. Big thanks vor this. It saves a lot of work.
                              But i have a question. I can not get the additional Streets working. I put them
                              into the Tracksfolder. The only things i got are the leadinglines and SU2015 starts crashing. All the othes stuff works fine.
                              Greetings
                              Ralph
                              • eneroth3E Offline
                                eneroth3
                                @ralle said:
                                Hallo there...
                                Greetings
                                Ralph
                                Hi Ralph
                                Those tracks are for an older version of the plugin but if you place their folders in "tracks/" directly in the template's folder (NOT "templates/tracks/"), open the ruby console and run "EneRailroad::Templates.convert_old" (without quotes) they should be converted to the new format.
                                On what page did you find them? I could update them in case anyone else wants to download them.
                                  Ralle
                                  Hallo Eneroth.
                                  Now that I'm back from a bad cold the last weeks, i'm follow your instructions.
                                  But without a good result, with exeption, SU doesn't crash anymore after useing
                                  the streets. How ever, i don't have any primitves of the streets, only the leadinglines.
                                  Greetings ..
                                  Ralph
                                  • eneroth3E Offline
                                    eneroth3
                                    Finally there's a new version published. Version 0.1.21 adds back the translation support. It also has a completely new feature for listing certain parts of structure (for now the pillars of the JPods structures) and lets users reposition them accurately. This feature is found under Extensions > Eneroth Plugin System > Structure Part Info. There's also a security notification added when models load if they contain potentially harmful executable code used by the balise feature. Finally there are some bugfixes regarding how missing templates are handled.
                                    Download
                                    • eneroth3E Offline
                                      eneroth3
                                      @ralle said:
                                      Hallo Eneroth.
                                      Greetings ..
                                      Ralph
                                      That's odd. Can you send me a zipped copy of the streets' track folders?
                                        Anton_S
                                        Thank you for an update, eneroth3 😄
                                        • deaneauD Offline
                                          deaneau
                                          0.1.21 crash some times if i layout tracks.
                                          steam locos jumps when i try to drive.
                                          Page Not Found
                                          Web word processing, presentations and spreadsheets
                                          (drive.google.com)
                                          sketchup make 2015
                                          • deaneauD Offline
                                            deaneau
                                            Is ths project dead?
                                            or is revit and rhino now your favorite? 😉
                                            dean aka yellowdoor/deaneau
                                            • 18
                                            • 19
                                            • 4 / 19
