    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
      Sl-m
      Hi There,
      Seems like a very powerful plugin, Well done and thanks for sharing!
      I have a question though:
      I'm using pro SKetchup pro 2015.
      When i have already created cut plans and select one of them, right click and "make realsection", nothing happens. I pressed "show real section" but doesn't make any difference.
      What M'I doing wrong ?
      Thank you
      Sl!m
      • P
        pgarmyn
        Hi There,
        Thank you
        Sl!m
        Realsection is another plugin. Mine is RichSection.
          Sl-m
          @pgarmyn said:
          Hi There,
          Thank you
          Sl!m
          Wow so sorry I got confused and completely missed that!
          I would rather erase my thread as it is not useful for other users.
          Merry Christmas!
          Sl!m
          • srxS
            srx
            I tried it and can now say that this is very useable and useful plugin. Thank you!
            www.saurus.rs
              Sl-m
              Hi there,
              Everything was working very well... Until yesterday when I played with the settings.
              After that the RichSection wouldn't cut through, just show the section line.
              I even loose the ability to activate the original Sketchup section tool and had to restart Sketchup.
              Any idea what's wrong ?
              http://www.postimg.org/image/itedoashd/
              Using sketchup 2015, windows7 ultimate 64.
              Thank you
              Sl!m
              • P
                pgarmyn
                Yes I had the same experiance. Sketchup stops cutting elements, and only showing the section lines, until restarting SU.
                I only had it with SU2015 on win 8.1. I suppose it is linked to that SU version (?)
                • P
                  pgarmyn
                  (deleted) answer sended twice
                    simsmt
                    This plugin is not working for me. I have Win7 SketchUp 2014 Pro. It will not create scenes but I can use exiting scenes to use the hatch but then it leaves the line when going to another scene.
                    • P
                      pgarmyn
                      I have it working on windows 7, SU Pro 2014 and 2015. Can you switch on logging to ruby console in the menu Plugins/Richsection/Setting and send me the errors, if there are?
                        arquitetopaulofil
                        Here is the mensage of ruby console
                        RS0.5.6|56.018|RichSection: Valid time-limited FULL WORKING license, until : 2015-02-28 21:00:00 -0300
                        RS0.5.6|0.078|optionsRShnew: new RS--sectionId150221-154208 : rs150221-154208
                        CAMBIADA
                        Error: #<NoMethodError: undefined method []' for nil:NilClass> c:/users/paulovisk/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:3607:in block in changeOptionsRSh'
                        c:/users/paulovisk/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:3606:in each_pair' c:/users/paulovisk/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:3606:in changeOptionsRSh'
                        C:/Users/PAULOVISK/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSpanel.rb:386:in block in create' C:/Users/PAULOVISK/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in call'
                        C:/Users/PAULOVISK/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in block in trigger_event' C:/Users/PAULOVISK/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in each'
                        C:/Users/PAULOVISK/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in trigger_event' C:/Users/PAULOVISK/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:364:in event_control_callback'
                        C:/Users/PAULOVISK/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:318:in callback_handler' C:/Users/PAULOVISK/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:276:in block in add_callback'
                        SketchUp:1:in `call'
                        • N
                          nmhai
                          error for me. i install: richsection and dibac(solid section).
                          win8.1 x64 sketchup 2015
                          • K
                            kylintz
                            The new plugin crash when I use rich section on sketchup without texture.
                            And it only create 1 scene for each section now, unlike the version before this where I got 2 scenes for each rich section. I tried to search on the rich section setting on the "scene created for each rich section", there's only one option available "scene, section plane visible, no camera aplies."
                            I tried to reset the setting with no results. I can't get 2 scenes for each rich section that I create. I missed that auto paralel camera and auto hide section plane visibility whenever I create rich section.
                              agmgpro
                              where can I find the older version (0.5.4)? In this latest version there's no option in "settings" to create 2 scenes...??? It's crashing a lot too. Installed on SKU2015 Pro. Version 0.5.4 was working just fine, and the option for creating 2 scenes (without camera + aligned to section), is very important for us! Please help! Appreciate your attention, Gabriel
                              • K
                                kylintz
                                I have the same problem like you agmgpro haha
                                • P
                                  pgarmyn
                                  You can create as much scenes as you want, but, after scene creation, you will have to switch the section layer on, set section plan visibility ... and update the scene. 2 Scenes (in the settings) will come back, but i can't make 0.5.4 available because the data structure (for richsection information) saved in your file has changed.
                                  About crashing : what other plugins are you using?
                                  • K
                                    kylintz
                                    I think the crashing is caused by the #default material. On a fresh sketchup file, if i create a scene without applying #default rich section material to random object first, the sketchup would crash after creating rich section.
                                    And about the 2 scenes, I couldn't get it work. I couldn't make the option to create 2 scenes automaticaly for each rich section to work. There's only one option available on rich section setting for "Scenes created for each richsection" : Scene, sectionplan visible, no camera applied.
                                    • P
                                      pgarmyn
                                      @kylintz:
                                      Maybee my answer was not clear : the option for creation of 2 scenes doesn't exist in the latest version (it will come back). You can create yourself extra scenes as described before.
                                      About problems with loading #default : is the plugin installed in the default folder?
                                      To be able to help you, i need :
                                      If you switch on the ruby console : are there errors ?
                                      Please fill in your profile : windows version, Sketchup version ...
                                      • E
                                        Esense3d
                                        Hello
                                        Itmakes sektions without Material ?
                                        Win 7 su 2015
                                        Thank you
                                        • P
                                          pgarmyn
                                          @esense3d:
                                          Did you tried without changing the parameters?
                                            agmgpro
                                            Thanks pgarmyn,
                                            waiting then for 2 scenes to come back!
                                            (it's possible for you to send me the older version via email??? If yes, my email is agmgpro@gmail.com)
                                            Thanks again!
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 18 / 20
