    Testing Ruby VALUES in C-extension.
    69 Posts 6 Posters 7.9k Views 6 Watching
    • tt_suT
      tt_su
      Also, you're using out C++ example? Then you don't have to declare all variables in advance. That's very old C syntax. Even newer C syntax allow you to declare variables when you need them.
      • jolranJ
        jolran
        I am doing a C++ extension, yes.
        rb_intern returns ID, not VALUE
        😮 Well that changes things. That could be it. Will test that in various combinations and report back.
        So would the syntaxrb_funcall(rb_intern("get_points")etc... be better then instead of storing it ?
        try to reproduce in a small standalone case.
        I have created a smallish testcase. Although I needed some classes for that.
        So the code become over 500 lines.
        I run that code in Alex ruby code editor while debug. Don't know if that can affect the scope of class or anything.
        And I have tested the data before sending in to c-extension, it's alright in Ruby.
        The C++ code may very well have logic errors I havent found yet. So I have to scan that through again. It looks like this is the main problem though, since I'm dependent of array length for next iterations. When all the arrays(curves) have same length code is working.
        I couldent tell whats proper syntax or not, yet. That does sound easier.
        Does that go for loops/iterators as well?
        • tt_suT
          tt_su
          Don't think it does any harm in Ruby 1.8 and 2.0 as both happen to be typedef of unsigned long - the compiler won't know the difference. So I don't think that is your issue here.
          But if the Ruby C API changes what types they map to you will get trouble.
          [/quote]
          Best practices usually states to declare variables right before you need them and scope them as appropriate.
          I'm not quite sure what you are asking for about loops and iterators though.
          • jolranJ
            jolran
            I meant hoisting variables before running loops. Speeding up the loops by not declaring them inside the loop.
            Changing to rb_funcall(curve, rb_intern("get_points"), 0); made no difference, so I will try that other macro you mentioned. Otherwise there must be some hole in my logic elsewhere..
            PS: I havent come to best practices part yet 😄
            Thanks for the help.
            • jolranJ
              jolran
              Well well. How dumb can one get seriously 👊
              Have been copying and pasting in code from Notepad++ to sketchup ruby code editor.
              Totally unfocused on that part..
              At some point I must have pushed ctrl v instead of ctrl c, so I not noingly had duplicate code. 😡
              Off course I wasent editing the first part that was sent in to Visual studio for step over.
              Hehum, thanks for the help Thomthom. All is not lost. You have provided some good information for the rest of us and I learned some new stuff 💚
              • tt_suT
                tt_su
                That's a Ruby world optimization - because creating Ruby objects are expensive.
                Not the same in C++.
                So now you're getting the correct array size?
                • jolranJ
                  jolran
                  Ok understood. It's quite wierd comming from Ruby to C++.
                  Yes. And the code work's as I wanted to 😄 So far anyway. Really fast.
                  I included your MACRO just to be safe. The code worked compiled in SU8.
                  I imagine I could even make it faster refactoring it. But.. Most importantly I want it to be proper, so I try to follow your advice and read up on best practices before I move on.
                  On another different subject while we are at it. Probably should start a new topic, but it doesent fell improper to ask here as well.
                  Can we use Windows forms or WXwidgets(not WX-rubyversion) or other GUI toolkit with c++ in Sketchup ?
                  I've seen discussion about it, but it was long time ago and relevant to only Ruby.
                  I've seen examples where they hook up MFC as resource to win32 projects. Also read here somewhere it can be problematic to hook that up to Sketchup window, since windialogs are under the desktop(?)
                  Anyway, not an substitute for webdialogs, just could be handy for some simpler dialogs using visual studio dialog editor.
                  • tt_suT
                    tt_su
                    I can't speak for WXwidgets, not familiar with it. Though I seem to recall some issues where they changed the order the window hierarchy - but maybe that was just the Ruby wrapper, I don't know.
                    But in general you can use whatever C/C++ lib you want. Native dialogs, knock yourself out. 😄 I haven't done so myself yet, but I wanted to try out a simple hello world window once.
                    I have done some code that calls the system folder picking dialogs though. Works very well.
                    • jolranJ
                      jolran
                      I think it was the Ruby wrapper that was causing problems.
                      The posts touching the subjects are very old, as mentioned..
                      ☀ I thought it was a no go on that! I'll peek around a little then.
                      Report back if I find something exiting.
                      • G
                        Garry K
                        I've just read all of this - very helpful and interesting.
                        Years ago I had a project that had to work with 3 compilers, CE, Visual C++ and C++Builder and I had a single code base.
                        I ended up learning new optimization procedures which when used right from the start created no extra work. For CE and risc processors you must design data structures that are memory aligned. This not only runs fine on cisc - it is automatically optimized. The key bit here is that if a 4 byte int crosses a memory boundary then cisc does 2 fetches and stitches it together, risc simply crashes.
                        I created a tList object that works with all 3 compilers. You can treat a tList as an array or a hash or a set. You can pass in objects and perform binary tree searches on any member of the object by simply passing it a function pointer to your own custom compare function. This is useful when you want many sort combinations on a single collection. This is a quicksort implementation.
                        How the tList works is it is essentially an array of pointers. The array is in contiguous memory. The array grows in a very specific way and is moved if you run out of free contiguous memory. When the tList object is first created you can provide an initial number of elements that you want thus avoiding repeated calls to malloc and avoiding moving memory. When sorting just the list of pointers sort - the collected objects stay where they are.
                        Here is a compare function that sorts on 2 fields. If first field is a tie then sort on second field
                        The void pointer is cast as the type of object that you collect in the tList.
                        fIndex is 1 or -1 which changes the sort from ascending to descending
                        int __fastcall CompareCabsCabinet( void * Item1, void * Item2 )
                        	int res;
                        	tCab *v1 = ( tCab *) Item1;
                        	tCab *v2 = ( tCab *) Item2;
                        	res = strcmp( v1->Description.c_str(), v2->Description.c_str() );
                        	if ( res == 0 )
                        		res = v1->CabNumber - v2->CabNumber;
                        	return fIndex * res;
                        When I wrote a GIS rendering engine I used a tList for all the points. I added a quad tree for static map data and an rtree for dynamic gps points.
                        I ended up with virtually instant renderings with a million points.
                        • tt_suT
                          tt_su
                          Came across this article today: http://silverhammermba.github.io/emberb/c/#exceptions
                          Nice little overview over the Ruby C API.
                          • G
                            Garry K
                            good article - it has already answered some of my questions.
                            • tt_suT
                              tt_su
                              It explains the important parts better than the Ruby C API readme:
                              https://github.com/ruby/ruby/blob/trunk/README.EXT
                              • jiminy-billy-bobJ
                                jiminy-billy-bob
                                I just came accross an issue you guys should know about (if you don't already) : We can't pass more than 15 arguments in a single function from ruby to C++.
                                • G
                                  Garry K
                                  It looks like I'll have to use the visual studio compiler for c extensions in sketchup.
                                  There is an MS specific config file and no other counterparts for borland etc.
                                  ThirdParty\include\ruby\2.0\win32\i386-mswin32_100\ruby\config.h
                                  • tt_suT
                                    tt_su
                                    You actually hit that limit? 😲
                                    • tt_suT
                                      tt_su
                                      For the examples we provided projects only for Visual Studio on Windows and Xcode on OSX. If you want to compile with another compiler you are free to do so - but we don't provide examples for all compilers.
                                      • jiminy-billy-bobJ
                                        jiminy-billy-bob
                                        Well... 😕 I try to limit the back-and-forth between ruby and C++, so I pass all the information in one go, and treat everything in C++.
                                        • tt_suT
                                          tt_su
                                          A Hash would be good to pass instead - much easier to manage whenever you change some of the data you pass. No need to worry about changing argument order etc.
                                          • G
                                            Garry K
                                            I have a good start on SUEX_HelloWorld using C++Builder 6
                                            I've added cbuilder folder at the same level as the i386-mswin32_100 folder. Then I added a ruby folder and copied over the config.h files. Then I've edited the config files. I'm happy to say that I didn't have to edit any other 3rd party file.
                                            Then I ran implib.exe -a msvcrt-ruby200.lib msvcrt-ruby200.dll and created Borland's flavor of each lib file.
                                            After that I set up a couple of include file paths and added msvcrt-ruby200.lib to the probject.
                                            Turned off precompiled headers and unchecked use dynamic rtl
                                            I now have it compiling - but currently just for the win32 flavor for SU 2014
                                            Now for a bit of testing.
                                            Hopefully I'm on the right path. I'm pretty sure I need to export the function as cdecl for this to work.
                                            • 3 / 4
