    Testing Ruby VALUES in C-extension.
    69 Posts 6 Posters 9.1k Views 6 Watching
    • tt_suT
      tt_su
      It explains the important parts better than the Ruby C API readme:
      https://github.com/ruby/ruby/blob/trunk/README.EXT
      • jiminy-billy-bobJ
        jiminy-billy-bob
        I just came accross an issue you guys should know about (if you don't already) : We can't pass more than 15 arguments in a single function from ruby to C++.
        • G
          Garry K
          It looks like I'll have to use the visual studio compiler for c extensions in sketchup.
          There is an MS specific config file and no other counterparts for borland etc.
          ThirdParty\include\ruby\2.0\win32\i386-mswin32_100\ruby\config.h
          • tt_suT
            tt_su
            You actually hit that limit? 😲
            • tt_suT
              tt_su
              For the examples we provided projects only for Visual Studio on Windows and Xcode on OSX. If you want to compile with another compiler you are free to do so - but we don't provide examples for all compilers.
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Well... 😕 I try to limit the back-and-forth between ruby and C++, so I pass all the information in one go, and treat everything in C++.
                • tt_suT
                  tt_su
                  A Hash would be good to pass instead - much easier to manage whenever you change some of the data you pass. No need to worry about changing argument order etc.
                  • G
                    Garry K
                    I have a good start on SUEX_HelloWorld using C++Builder 6
                    I've added cbuilder folder at the same level as the i386-mswin32_100 folder. Then I added a ruby folder and copied over the config.h files. Then I've edited the config files. I'm happy to say that I didn't have to edit any other 3rd party file.
                    Then I ran implib.exe -a msvcrt-ruby200.lib msvcrt-ruby200.dll and created Borland's flavor of each lib file.
                    After that I set up a couple of include file paths and added msvcrt-ruby200.lib to the probject.
                    Turned off precompiled headers and unchecked use dynamic rtl
                    I now have it compiling - but currently just for the win32 flavor for SU 2014
                    Now for a bit of testing.
                    Hopefully I'm on the right path. I'm pretty sure I need to export the function as cdecl for this to work.
                    • G
                      Garry K
                      Turns out it's a stdcall which has no mangling.
                      I can debug the c extension in CBuilder. Very fast.
                      Now I need to experiment with arguments etc. That will be the acid test for stdcall
                      If anyone is interested I can post the files and the steps.
                      Once I get a real good handle on this I'll try it out with XE7 which is a compiler that compiles Win32, Win64 and OSX.
                      I will also test this on my lap top where Borland memory manager (a dll) doesn't exist. It will tell me if I need to include any of these files or not.
                      • 4 / 4
