    Sketchup 8 faster than sketchup 13?
    29 Posts 8 Posters 4.9k Views 8 Watching
    • deaneauD Offline
      deaneau
      @adamb said:
      SU8 and SU2013 were much of a muchness on speed. SU2014 is much faster.
      But Aerilius is correct that you need to compare apples to apples; check you have identical Observers attached in both versions before testing.
      however some plugins will crash SU2014 in SU2013 all be good.
        glro
        can you give an example?
        this might help to find an explanation
        • tt_suT Offline
          tt_su
          Does anyone have examples to follow this discussion?
            glro
            Runs with 25 fps in Sketchup 8 and sucks with 5 fps in Sketchup 2014 ...
            • Dan RathbunD Offline
              Dan Rathbun
              Comparison for SketchUp 2015 ?
              I'm not here much anymore.
              • tt_suT Offline
                tt_su
                No code examples? Or anything we can run to test?
                  Garry K
                  I tried my Stair Maker plugin with the last 5 versions of SU on Windows 7.
                  I asked it to build a 360 degree curved stair with housed stringers and 56 Risers, 50 progressive flare (forces 50 unique treads and 50 unique risers) Each tread flare inreased by 5 mm.
                  The stair had 2 of the most complex rails that I provide. So there are 392 curved and twised sections making up the 2 rails.
                  SU 7: 44 seconds
                  SU 8: 42.5 seconds
                  SU 2013: 34.3 seconds
                  SU 2014: 32.3 seconds
                  SU 2015 64 bit: 33.5 seconds
                    Garry K
                    Here are the parameters of the stair.
                    You can see the progressive flare.
                    Stair Parameters
                    Stair
                      glro
                      @adamb said:
                      glro: you seem very quick to judge things you perhaps do not understand.
                      The purpose of having 2 locations, is that one is a global, shared repository, another is a per-user repository.
                      OK, now i understand the interest of a global repository: it doesn't need the session name
                      C:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Plugins
                      so it might be easier to find when installing a plugin
                      maybe ...
                      but still, if a plugin needs special components to be installed, it still has to be done in the program files folder; so it still needs administrator rights
                      the component folder should be outside the program files folder also
                        roland joseph
                        Shut down the external ruby pipeline and hire a bunch of ruby coders. Now that would be a diabolical means for Trimble to make money wouldn't it? 😲
                          glro
                          @aerilius said:
                          What does the code do?
                          Apart from pure mathematical calculations, programming languages can also have side effects and interact with the environment (and such side effects make things hard to reproduce and bugs hard to discover).
                          Although the ruby version is maybe still the same, the SketchUp environment is changed and performance is affected by entity creation (which then can even call observers of other plugins) or interaction with the user interface.
                          from SU profiler result, the program mainly spends time in this type of operation
                          "Sketchup::Entities#each"
                          would you say that this includes these lines of code?
                          for e in entities
                              if e.is_a? Sketchup;;ComponentInstance
                                    status = selection.add e
                          end #for
                            glro
                            @roland joseph said:
                            Shut down the external ruby pipeline ... 😲
                            do you suggest that some plugins (as mine ...) running slower would be the consequence of an intentional reduction of capacity for ruby programs to interact with sketchup?
                              Aerilius
                              The profiler (plugin!) requires quite some understanding of what it does, and how meaningful the result is — even for more advanced developers this profiler in its current state is not that much helpful. That it spends time in each doesn't tell much without decomposing what it does inside each.
                              There is no "external" ruby pipeline.
                                glro
                                thank you for the answer
                                so no clue from profiler plugin
                                and no conspiracy theory
                                and what about the incidence of the previous model opened? i did notice that the time necessary to proceed on the basis of fixed parameters, may vary according to the previous model opened
                                  roland joseph
                                  No. 😄
                                    roland joseph
                                    Phew, I was worried for a moment. 😕
                                    • 2 / 2
