    Sketchup 8 faster than sketchup 13?
    29 Posts 8 Posters 5.3k Views 8 Watching
    • G
      glro
      @adamb said:
      glro: you seem very quick to judge things you perhaps do not understand.
      The purpose of having 2 locations, is that one is a global, shared repository, another is a per-user repository.
      i don't want to offend anybody
      and i am conscient of the limits of my programming skills
      i know the problem i have is not linked to ruby versions, and i have at least one example of trimble limiting on purpose the possibilities of sketchup plugins
      so i have a doubt
      that's it, no big deal
      • deaneauD
        deaneau
        @adamb said:
        SU8 and SU2013 were much of a muchness on speed. SU2014 is much faster.
        But Aerilius is correct that you need to compare apples to apples; check you have identical Observers attached in both versions before testing.
        however some plugins will crash SU2014 in SU2013 all be good.
        • G
          glro
          can you give an example?
          this might help to find an explanation
          • tt_suT
            tt_su
            Does anyone have examples to follow this discussion?
            • G
              glro
              Runs with 25 fps in Sketchup 8 and sucks with 5 fps in Sketchup 2014 ...
              • Dan RathbunD
                Dan Rathbun
                Comparison for SketchUp 2015 ?
                I'm not here much anymore.
                • tt_suT
                  tt_su
                  No code examples? Or anything we can run to test?
                  • G
                    Garry K
                    I tried my Stair Maker plugin with the last 5 versions of SU on Windows 7.
                    I asked it to build a 360 degree curved stair with housed stringers and 56 Risers, 50 progressive flare (forces 50 unique treads and 50 unique risers) Each tread flare inreased by 5 mm.
                    The stair had 2 of the most complex rails that I provide. So there are 392 curved and twised sections making up the 2 rails.
                    SU 7: 44 seconds
                    SU 8: 42.5 seconds
                    SU 2013: 34.3 seconds
                    SU 2014: 32.3 seconds
                    SU 2015 64 bit: 33.5 seconds
                    • G
                      Garry K
                      Here are the parameters of the stair.
                      You can see the progressive flare.
                      Stair Parameters
                      Stair
                      • G
                        glro
                        OK, now i understand the interest of a global repository: it doesn't need the session name
                        C:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Plugins
                        so it might be easier to find when installing a plugin
                        maybe ...
                        but still, if a plugin needs special components to be installed, it still has to be done in the program files folder; so it still needs administrator rights
                        the component folder should be outside the program files folder also
                          roland joseph
                          Shut down the external ruby pipeline and hire a bunch of ruby coders. Now that would be a diabolical means for Trimble to make money wouldn't it? 😲
                          • G
                            glro
                            @aerilius said:
                            What does the code do?
                            Apart from pure mathematical calculations, programming languages can also have side effects and interact with the environment (and such side effects make things hard to reproduce and bugs hard to discover).
                            Although the ruby version is maybe still the same, the SketchUp environment is changed and performance is affected by entity creation (which then can even call observers of other plugins) or interaction with the user interface.
                            from SU profiler result, the program mainly spends time in this type of operation
                            "Sketchup::Entities#each"
                            would you say that this includes these lines of code?
                            for e in entities
                                if e.is_a? Sketchup;;ComponentInstance
                                      status = selection.add e
                            end #for
                            • G
                              glro
                              @roland joseph said:
                              Shut down the external ruby pipeline ... 😲
                              do you suggest that some plugins (as mine ...) running slower would be the consequence of an intentional reduction of capacity for ruby programs to interact with sketchup?
                                Aerilius
                                The profiler (plugin!) requires quite some understanding of what it does, and how meaningful the result is — even for more advanced developers this profiler in its current state is not that much helpful. That it spends time in each doesn't tell much without decomposing what it does inside each.
                                There is no "external" ruby pipeline.
                                • G
                                  glro
                                  thank you for the answer
                                  so no clue from profiler plugin
                                  and no conspiracy theory
                                  and what about the incidence of the previous model opened? i did notice that the time necessary to proceed on the basis of fixed parameters, may vary according to the previous model opened
                                    roland joseph
                                    No. 😄
                                      roland joseph
                                      Phew, I was worried for a moment. 😕
                                      • 2 / 2
