    SKUI — A GUI Framework for SketchUp
    75 Posts 21 Posters 16.2k Views 21 Watching
      So, I'm a bit unclear here - have you found issues with SKUI on OSX?
        pgarmyn
        Completly clear : Before i use it, i wanted to know..... So i don't have any experience yet with SKUI.
        Thanks for the info : tested on Mac
          pgarmyn
          @thomthom said:
          Yes, I have a mac I test it on.
          How come? You found issues?
          No I have Mac issues with the SU inputbox and was looking for an alternative...
          See : http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57642#p524309
            arunkumargonal
            Hi ThomThom,
            SKUI is helping me a lot in building some basic GUI.
            Need your help for the following scenario.
            I am adding controls to the window. I have kept a selection observer, when ever the selection changes, Need to remove all the controls in the window and add new ones.
            I am trying to use the remove_control method of control_manager which is not deleting all the controls. Please let me know if it is right to use the below code for removing all the controls of the window.
            window.controls.each do |control| window.remove_control(control) end
            Thank you,
            Arun.
              hm... haven't really done much for removing. I don't recall what that method was for. Though, performance wise I would think it would be faster to put them in a Groupbox - then hide/show the groupbox. ...saying that - maybe hide/show need to be added...
                No - Control.visible and Control.visible= is already implemented! 😄
                But I really should generate them docs.
                  arunkumargonal
                  Hey TT,
                  The remove_control works good. It indeed removes the control from the window.
                  The issue was with my code, I was using window.controls.each to call the remove_control in which, the control is deleted from the array.
                  My code:
                  @window.controls.each do |container| @window.remove_control(container) end
                  Code in remove_control
                  @controls.delete( control )
                  I commented the delete inside the remove_control function and used @windows.controls.clear in my function.
                  Thanks & Regards,
                  Arun
                  • tt_suT Offline
                    tt_su
                    Ah, you where removing elements from the collection you iterated - that will usually always cause problems with any collection. You want to make an array copy of the collection first and iterate that instead.
                    @window.controls.to_aeach
                    • brewskyB Offline
                      brewsky
                      Hi TT,
                      I want to try to add a progressbar control to SKUI.
                      It does not seem very different from the jQuery widget for "button"...
                      Do you have any tips on where to start? 😉
                      Another question, how did you disable the right-click / context menu in the webdialog?
                      Would be nice to temporarily enable "view source"...
                      Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
                      • jolranJ Offline
                        jolran
                        @brewsky
                        Don't want to be a bringer of bad news 😳 , but I have some negative experiences with that.
                        It can be problematic to do a progressbar to webdialog. Due to the "freeze" that happends when ruby calculates.
                        There where some early reports on that long ago. (Look in the first link at first post.)
                        Don't know if that is still a problem with 2015.
                        http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=54873%26amp;hilit=+webdialog+freeze
                          driven
                          jQuery UI blocks the right click menu...
                          on a mac you can either right click into an input box, or try and do it before the page loads...
                          BTW: you can easily view the time lags in a webdialog by simply adding a gif to a page, as SU works harder it will slow, stop, restart, it's even more noticeable if you use a css3 loader that runs a text animation...
                            Jim
                            The right click blocking is done explicitly in ui.js file.
                            • brewskyB Offline
                              brewsky
                              Thanks for pointing this out. Might be better to let this rest until I really need it 😉
                              One positive thing might be that the progressbar would be for while I wait for a server to process my model so I don't think ruby has to work hard in the background.
                              • brewskyB Offline
                                brewsky
                                Thanks! Found it 😄
                                • jolranJ Offline
                                  jolran
                                  Ah, you might be ok then if it's not coming from Ruby.
                                  And (se above Drivens post) I remember now. Indeed Driven has showed me some cure for a progressbar. So it's doable.
                                  Although a progressbar might not be the most important aspect of your plugin 😉 😄
                                    driven
                                    I think @jolran refers to this one?the dlg is request the draw and then the undo...
                                    I added in the spin just to show it wasn't blocking...
                                    you can draw as well, but that ruins the undo's in this demo...
                                      pgarmyn
                                      @driven said:
                                      I think @jolran refers to this one?[attachment=0:19ejklyu]<!-- ia0 -->wdlg_counter.gif<!-- ia0 -->[/attachment:19ejklyu]
                                      Does it also work in Windows?
                                      In my experience, this only works on mac.
                                        driven
                                        Did I send you this early 'type-matic' test?
                                        at first it was mac only...
                                        Jorlan added the meta tags and had it working on SU v8 on Windows...
                                        I then built a few different versions that added the cubes and that ran for him as well...
                                        The removal of geometry in the gif is untested on a PC, but should also work...
                                        The code could be better, but it just playing around...
                                        Try it, adjusting 'setTimeout' to allow time to draw/navigate while it continues running...
                                           type_this = " " + "This text should be typed one char at a time by ruby." + " "
                                           @type = type_this.scan(/./)
                                           @text = ""
                                           @dlg = UI;;WebDialog.new()
                                           @dlg.set_size(500,100)
                                           @dlg.show_modal
                                             @html =  %Q(
                                                <!DOCTYPE html>
                                                <html>
                                                <head>
                                                   <meta http-equiv="content-type" content="charset=UTF-8" />
                                                   <meta http-equiv="MSThemeCompatible" content="Yes" />
                                                   <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
                                                   <style>span {height;100%; width;10px; text-align;center;background-color;blue;color;white;}</style>
                                                </head>
                                                <body>
                                                   <script>
                                                         setTimeout(function(){window.location='skp;auto2ruby';}, 200)
                                                   </script>
                                                  </body>
                                                </html>
                                          def span(n)
                                            %Q[<span>#{n}</span>]
                                           def do_this
                                             if not (@text.length) >= (@type.length)
                                               n = @type[(@text.length+1)]
                                               n = n.sub(/\s/, "\u00A0" ) if n == /\s/
                                               @text << n.to_s
                                               @html << span(n)
                                               @dlg.set_html(@html) if not (@text.length) == (@type.length-1)
                                             else
                                               puts "shit happens"
                                           @dlg.add_action_callback("auto2ruby") {|d,params|
                                               do_this
                                          pgarmyn
                                          @john : interesting, i will do some testing this evening. thanks!
                                            pgarmyn
                                            @john
                                            For Windows '@dlg.show_modal' must become '@dlg.show',
                                            otherwise nothing will hapen : the script will stop execution until @dlg is closed.
                                            • 2 / 4
