    Distance between two points / optimization
    14 Posts 6 Posters 1.5k Views 6 Watching
    • ppoublanP Offline
      ppoublan
      Dear all,
      I have an array of points.
      I would like to remove those that are at a distance from another point less than a minimum spacing.
      The following code seems to do it, but I would like to know if you think there is a faster/more efficient way to proceed (the distance comparison of all points, not the drawing part).
      Yours
      Pascal
      def test_distance
      	pts = []
      	max = 5000
      	maxdist = 1000
      	mindist = 50
      	for i in 0..max
      		pt = Geom;;Point3d.new(rand*maxdist,rand*maxdist,rand*maxdist)
      		pts << [pt, true]
      	start_time = Time.now.to_f
      	for i in 0..max
      		if pts[i][1] == true
      			for j in (i + 1)..max
      				if pts[j][1] == true
      					pt1 = pts[i][0]
      					pt2 = pts[j][0]
      					dist = pt1.distance pt2
      					if dist < mindist
      						pts[j][1] = false
      	end_time = Time.now.to_f
      	puts (end_time - start_time).to_s
      	Sketchup.active_model.start_operation("test",true,false,false)
      	for i in 0..max
      			Sketchup.active_model.entities.add_cpoint(pts[i][0])
      	Sketchup.active_model.commit_operation
      • jolranJ Offline
        jolran
        The distance method use Square root. So it's bound to be slow.
        You could do testing with "distance squared" method, although it won't give you the accurate distance.
        But maybe for sorting out some Points for a more detailed test.
        You could compute the 1 comparing distance from distance = (dist*dist) and compare with that perhaps.
        Distance Square uses 3 multiplications and 3 subtract. So I don't know if the Ruby version will be faster than the API "distance" method, though. ❓
        In a C-extension it is for sure.
        Point a and b
        x = a.x-b.x; y = a.y-b.y; z = a.z-b.z # Don't remember if one has to use .abs (?)
        dist_sq = xx + yy + z*z
        Distance = Math.sqrt( dist_sq )
        Regarding you code I'm not sure what you want to do with marking the Points with a boolean.
        It might be faster to append results to a new Array rather then store a lot of small arrays . And maybe even use a Hash.
        I can imagine some clever person have convoluted API way for comparing distances between points. This code will work in a C-extension though..
        • ppoublanP Offline
          ppoublan
          Thanks for your answer,
          I will make more tests with this method.
          Regarding this point
          The idea was NOT to compare all points, but as some are discarded, to be sure they are not compared in the loop with all others, to reduce the total number of comparisons.
          If I copy "valid" points in another array, I will have to compare all points, even those already found as "too close".
          Thanks again
          Pascal
          • jolranJ Offline
            jolran
            Ah I see. As long as you have a plan for it πŸ˜„
            I was thinking if one could reverse engieneer the distance to only do added subtraction tests.
            Probably NOT since 1 large dimension value can negate the others (?). But it wont hurt trying to see if you could find an algorithm for that.
              CAUL
              You could try to use a space hash. The code below generate the points well within 1s.
              ` module PointCloud
              def self.init(box_side, min_dist)
              @min_dist = min_dist
              @divs = (box_side / min_dist) - 1.0
              @dInv = 1.0 / (box_side / @divs)
              @hash = []
              (0..@divs - 1).each { |i| @hash << []
              (0..@divs - 1).each { |j| @hash[i] << []
              (0..@divs - 1).each { |k| @hash[i][j] << []
              @nBox = []
              [0, -1, 1].each { |i|
                [0, -1, 1].each { |j|
                  [0, -1, 1].each { |k|
                    @nBox << [i, j, k]
              def self.validBox?(xi, yi, zi)
              return xi >= 0 && yi >= 0 && zi >= 0 && xi < @divs && yi < @divs && zi < @divs
              def self.getBox(p)
              x = (p.x * @dInv).floor
              y = (p.y * @dInv).floor
              z = (p.z * @dInv).floor
              return nil unless validBox?(x, y, z)
              return [x, y, z]
              def self.validPoint?(p, ind)
              xi = yi = zi = 0
              @nBox.each { |offset|
              xi = ind[0] + offset[0]; yi = ind[1] + offset[1]; zi = ind[2] + offset[2]
              next unless validBox?(xi, yi, zi)
              box = @hash[xi][yi][zi]
              box.each { |p2| return false if p.distance(p2) < @min_dist }
              return true
              def self.add(p)
              ind = getBox(p)
              return false if ind == nil
              return false unless validPoint?(p, ind)
              @hash[ind[0]][ind[1]][ind[2]] << p
              return true
              def self.main
              mod = Sketchup.active_model
              ent = mod.entities
              res_g = ent.add_group
              box_side = 1000
              min_dist = 50
              no_of_points = 5000
              t0 = Time.now
              (1..no_of_points).each { |i|
                pt = Geom::Point3d.new(rand * box_side, rand * box_side, rand * box_side)
                res_g.entities.add_cpoint(pt) if add(pt)
              t1 = Time.now
              puts (t1 - t0).to_s
              main
              end`
              • jolranJ Offline
                jolran
                That looks nice! Did you get that from the Geometric Tools library ?
                Ive seen something similar like this before and can't remember where it was.
                Looks useful for other tests as well.
                Edit: the distance Square method gives 0.016 sec for 5000 Points btw...
                About twice as fast as pt.distance(pt)
                Scratch that. I forgot to mute the subtractions. About same as API distance method. So I would suggest trying CAULS method.
                There is probably Little to gain from using distance squared in Ruby vs API methods.
                • sdmitchS Offline
                  sdmitch
                  Here are my results with the two code options
                  8.400599956512451
                  0..5000
                  PointCloud.main
                  45.5006
                  nil
                  8.503999948501587
                  0..5000
                  PointCloud.main
                  46.4774
                  nil
                  8.392800092697144
                  0..5000
                  PointCloud.main
                  45.6526
                  nil
                  Pascal's averaged 8.4 versus 45.9 for Caul's
                  http://sdmitch.blogspot.com/
                  • jolranJ Offline
                    jolran
                    Heh, really ?? 8 seconds vs 45 for 5000 Points ?
                    edit:( My timings: Pascal ~ 10 sec, CAUL's module 1.11 sec )
                    Then CAUL's method add constructionpoints inside the timings, also.
                    I forgot to mention I tested under Su8. So maybe "distance squared" performs better under Ruby2 ? Might be worthwhile to do some profiling after all then.
                    (I don't know the accuracy of the test..)
                    	sel = mod.selection
                    	ents = mod.entities
                    	sel.clear
                    	cps = []
                    	saved = []
                    	maxdist = 1000
                    	mindist = 500
                    	minSQ = mindist*mindist
                    	tp = ents.add_cpoint( ORIGIN ) #testpoint Try offsets from 0,0,0 ?
                    	tp = tp.position
                    	for i in 0..5000
                    		cp = ents.add_cpoint( Geom;;Point3d.new(rand*maxdist,rand*maxdist,rand*maxdist) )
                    		cps << cp
                    	t = Time.now
                    	cps.each{|cp|
                    		pt = cp.position
                    		x = tp.x-pt.x
                    		y = tp.y-pt.y
                    		z = tp.z-pt.z
                    		#next unless pt.distance(tp) <= mindist
                    		next unless ( x*x + y*y + z*z ) <= minSQ
                    		saved << cp
                    	puts Time.now-t
                    	sel.add( saved )
                    	nil
                      CAUL
                      Well, no, it's a very primitive (just a plain 3D-array) standard space hash. It's surprisingly effective on average; memory intense though. I use variations of this quite often, here's another example.
                      @sdmitch said:
                      Here are my results with the two code options [Pascal's averaged 8.4 versus 45.9 for Caul's]
                      That's very strange, I've tested on two computers and my results are more like ~0.2s (vs 4.7s for Pascal's code). I wonder where the huge time penalty comes from in your tests, maybe it's the memory allocation in init()..?
                      • jolranJ Offline
                        jolran
                        Nice. Useful to know. Also good it doesent come from a library that has draconian licence policy πŸ˜‰
                        I might try it out a bit πŸ˜„
                        If I remember correctly(?), I think he is on a laptop. So memory consumtion might slow things down in his case.
                        edit: missread the topic..
                        Since I did not see the aim of this algorithm. I think it's a relevant question to pose
                        what are you going to do with these Points ?
                        It looks to me like the result in both methods are in an unorderly fashion.
                        Unless this algorithm takes care of the sorting you would have to dig through the set again.
                        edit2
                        Ah β˜€ , Pascal's maker of the Tree plugin. Now I can see the usage of pointcloud.
                        • tt_suT Offline
                          tt_su
                          So - I did this for Vertex Tools. Any implementation is Ruby was slow. I then wrote a tiny Ruby C extension and the performance was 100+ times faster than the fastest Ruby implementation I had.
                          There is simply so much overhead by Ruby itself that this kind of stuff is better passed off to C - Even with the overhead of converting the point set to C structures and back to Ruby at the end it just blows away pure Ruby computation.
                          And as it's been mentioned, you want to avoid square root. Since you want to filter point by a given distance, convert the distance to the power of it self and do the distance calculation without square root. Gives your calculation an extra boost.
                          • ppoublanP Offline
                            ppoublan
                            I'm working on a new way to create grass within Tree Maker (put a lot of plants on surfaces) that I would like to look more realistic with more or less dense zones. Now it works, but looking to improve and optimze it.
                            Really thanks to all of you for your very good ideas and feedbacks.
                            Now I have to implement this.
                            Pascal
                            • jolranJ Offline
                              jolran
                              I started to suspect you where doing something like that. No real precise need for ordered Points
                              then.
                              As a continuation of Thomthoms advice. Should you ever want to create a C-extension easily for distance between Points the code is already written and available πŸ˜„
                              https://bitbucket.org/thomthom/sketchup-ruby-c-extension/src/e2fe0f2e43e43ebae568535b6d7a98e160b4624c/src/Example%20-%20Basics/SXBasics.c?at=default
                                Note: That example is OLD! You can refer to it for how I resolve the distance calculation, but had I done that today I would have done it in C++ using Visual Studio and Xcode:
                                https://github.com/SketchUp/ruby-c-extension-examples
