    Animating Water Spray
    62 Posts 8 Posters 6.8k Views 8 Watching
      roland joseph
      This was posted this morning by a newcomer to the Lumion Forum.
      It was created with the latest release, Lumion Pro 5.
      This would have been an afternoon job not an epic.
      • ashscottA Offline
        ashscott
        This is not raytracing right? Its some other form of rendering?
        Just some stuff I do with Sketchup.
          roland joseph
          Yes...with a big No. What kind of an answer is that?
          Well it is complicated and best described by someone who is familiar with and uses the various algorithms for ray tracing. So I am going to give you the version best understood by someone like me...or any other assortment of children... πŸ˜„ In it's purest form rendering is about non-biased ray-tracing. So it is about what protons do when they are unleashed in an environment. That requires a lot of number crunching...can you imagine trying to chase one of those light balls around to see what it does...and then try to record all that data while you are doing it. So this is why there is an on-going discussion about render times and why the f*ck is this taking so long. Non-biased renders are the absolute best and the closest we are coming to physically correct but they take time. Hence "render farming"
          Now the "yes" part of this answer is that Lumion is like a video game. It is basically a game engine. Game engines are big pieces of software to but for a different reason. Lumion is an environment that has been inspired by ray-tracing to create a bunch of premade and pre-baked effects that simulate, to the best ability of the artist, a real world ambience. Instead of running the slow ray-tracing algorithm every time someone turns on a light, assumptions are made about what things should look like from the experience of creating them with real ray-tracing algorithms in the first place. Then suitable effects are applied to create a simulation. This increases the speed of the image creation by I'm sure close to a full order of magnitude.
          The ray-tracing business will eventually get a hardware boost that will make it possible to have a more real-time like experience.....so all bets are off for the future but for now I think the real-time engine guys are heading for the lead and will be able to more readily adopt the algorithms into their products as they become viable in terms of time overhead.
          OK so now if you are confused...so am I... πŸ˜‰ ...maybe someone else will help with a better and more technical explanation.
            roland joseph
            It is my opinion that no mater how you create your rendering the underlying modeling is what pushes it over the top. I see some recent Podium renders that will blow you away. I know the mesh is very advanced under the covers. The guy modeling knows his stuff. That is why you see so much cartoonish Lumion...because you don't have to be a modeller to make it work. But if you are a great (hard working) modeller you can make just about anything look good and real with Lumion or any other rendering software.
            I am an average modeller but Lumion and Sketchup make it possible for me to create interesting NPR images from rag tag resourses...i.e. this image/model was created from StreetViews only. At best the images where poor quality but came to life with a good model.
            There are lots of little errors in the render...backwards bumps..etc...but pretty good effects considering this has a 6 second render time. (most of the mistakes are in the modeling)
            • ashscottA Offline
              ashscott
              Great explanation - I hadn't fully reconciled why games looked so good yet ray tracing took so long. Are there any other biased renderers that are good (not necessarily on par with Lumion) that don't case more than a new laptop?
                roland joseph
                that don't cost more than a new laptop?
                I think you meant cost?
                I hear you but you should check the cost of your own time and then think about what it is you are trying to achieve. I think you will see Lumion as a bargain.
                Basically I need a finished image that my customers will pay for and I have that with Lumion. They are satisfied...interior/exterior/product...etc...no problem for the people I deal with. If I show them a rendering from a person that is a pro with a raytracer they will go "wow!!" no doubt but they don't see it as a significant difference in quality.....many can't afford it for still shots....forget about animation. (If that makes me a bottom feeder then so be it, I'm getting paid.)
                You will spend many hours trying to set-up and tweak your ray-tracer and thousands of hours reviewing and editing...literally thousands of iterations.
                In Lumion you spend most of your time on material creation and application, composition, design choices/versions, shot selection, proofing editing etc. and little time rendering.
                Of course there will be times you have to tie up your machine but that will be for massive models stretching for many kilometers.
                  roland joseph
                  Oh sorry...you wanted to know about other software you will find a list somewhere on the forum but I'm not going to say cause I'm spoiled, I'm afraid I can't be objective cause I have had many hours with Lumion and basically a handful with a few others. I didn't like any of the other I tried.
                  • ashscottA Offline
                    ashscott
                    If I end up buying Lumion I think they should pay you a commission
                      roland joseph
                      If you do join the forum you will see that I am like you. I can only afford to hold version 3.2.1. The current pro version is 5. I need to shell out another 1500 to get to 5. I will get there but for now I am still putting aside a fund. The newest release has many things I want including new sets of trees and plants that are just lushes...but no, they don't know that I am pushing their product here at all and there will be no commission.
                        roland joseph
                        Time has passed...did you get something together?
                        • ashscottA Offline
                          ashscott
                          I can't show you much because its under NDA but here is the first run with animated GIFs working in Twilight:
                          Thats on low animation settings and the GIF isn't working quite right
                            roland joseph
                            Good to see you giving it an effort. Not an easy task for sure.
                            Cheers!
                              roland joseph
                              To suggest 3 days is going to get you satisfactory results is not realistic.
                              I guess that was a pretty accurate statement. I don't expect you had much luck with this. I certainly wouldn't expect you to. I think it is a testimony to how difficult it is to find off the shelf animation that can do anything reasonable with water. It's doesn't seem to be available.
                              • 3 / 4
