    Rotating irregular shape 180 degrees
    5 Posts 4 Posters 608 Views 4 Watching
      MLUY
      Ok, Hello everybody here at Sketchcity this is my first post...completely a freshfish
      I Have been looking around on this site for a while after discovering Sketchup a few weeks ago.
      Again its deep in the night but still not managed to solve my problem...and about to give up
      I am trying to rotate a simple shape (exact) 180 degrees to get a special type of cone-shape (or "round head" for use in civil engineering application, rock breakwater) By using the follow me tool I thought that should be straightforward...but its not
      See attached, why doesn't sketchup complete the exact amount degrees I am telling it to do:
      From Step 3 you can see the angle is not exact 180 degrees. It supposed to be dead straight (as the circle is exactly 180 deg) I did notice that it helps a bit if I increase my circle segments but more than 150 does not matter any more
      Who can explain what the heck is going on? ❓ ❓ ❓
      Michiel
      • BoxB
        The profile for follow me needs to be perpendicular to the end segments of the path.
        If you use a full circle then remove half it will work.
        By the way, Please use meaningful thread titles.
        • S ShepherdS
          S Shepherd
          If your roundhead is just an end to a breakwater, you could try something like this:
          Shep
          • cottyC
            cotty
            Another example for Box answer:
            my SketchUp gallery
              MLUY
              What a simple solution!
              Thanks very much for your lightning fast response, sometimes you can stare yourself blind.
              Ehh...I have some more problems, but because I could not even solve the simplest puzzle I left those.
              So...some new challenges ahead, but no more mightnight oil burning for me.
              With help through this forum I should be able to prevent that
              Thanks again!!
