    [Solved] Infuriating !!
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    8 Posts 4 Posters 8.4k Views 4 Watching
      sherwood111
      From the moment I enter Sketchucation and
      everytime I open and new page I am bombarded
      with pop-up ads that covers the page (every page !)
      I'm unable to see or do anything without closing
      the endless ads.
      Using Adblocker won't allow access to certain content
      like plugins, images etc.
      A wonderful way to bring in the new year . .
      Nothing short of counter-productive, to say the least.
      Any thoughts to remedy this ?
      (other than not using the site)
      [Solved]
      @Jim, Firefox is my browser
      1. Spent several hour investigating/searching folders and files
      2. Ended up using commercial scan software to find culprit and
        deleted it from the file system and registry.
      3. Culprit = PUP.optional.AceRace.A
      Have no idea where it came from.
      Hope this helps someone in a similar situation.
        Jim
        SketchUcation does not use pop-up ads. You probably have some crapware toolbar installed in your browser.
          Jim
          Which browser do you use?
          • FrederikF Offline
            Frederik
            I've never experienced any kinds of pop-up adds...
            I assume your computer is most likely infected with Malware or alike...
            Too bad for you, but don't blame SCF...
            Cheers
            Kim Frederik
              Great!
              • FrederikF Offline
                Frederik
                Great that you solved the issue...
                [Solved]
                1. Culprit = PUP.optional.AceRace.A
                Now that you've found the culprit - which obviously wasn't caused by SCF - don't you think an apology is in place here...? πŸ˜•
                Cheers
                Kim Frederik
                  I'm sorry Fred.
                  • FrederikF Offline
                    Frederik
                    @rich o brien said:
                    I'm sorry Fred.
                    πŸ˜†
                    Not you, Rich... πŸ˜›
                    It's just that sherwood111 starts this thread with sole accusations, but when it finally turns out to be something caused by something else, it would be appropriate if he expressed an apology... πŸ˜‰
                    Cheers
                    Kim Frederik
