    SketchyPhysics 3.5.6 (26 January 2015)
    208 Posts 49 Posters 297.9k Views 49 Watching
    • W Offline
      willeykj
      I shared emails with Chris the other day and he and I both agree its time to get the original source code for the libraries out into the community. (Chris really did all the work and created SP, I just did the port to OS X).
      Despite our best intentions, we will never pick up the threads and get SP going as fast as Anton and you (the rest of the passionate SP community) are doing.
      What is the preferred method you'd like for getting the source code into the hands of the community?
      For those that are confused by this - I'm not talking about the Ruby code. I'm referring to the C code in the extension libraries that hook the SP ruby code into the Newton physics library and other assorted Ruby C Extensions that access OS specific functionality and other libraries (like SDL, Midi support, etc...).
        deskpilot
        Thankyou very much Anton, it's all there now. I'll play with it a bit later (only just got up). As you been discussing, this needs to put out there for the wider community.
          Anton_S
          Very well!
          I think GitHub is the best way to share source to the community.
          • gillesG Offline
            gilles
            Is there a way to make control panel pop up elsewhere than in the middle of the screen?
            • BoxB Offline
              Could you look at changing the opening state of the toolbars.
              If you have it loaded they will always open on startup whether you closed them last time or not.
              @Gilles Might be different on the Mac, but I moved it aside and it now always opens where I moved it.
              • gillesG Offline
                gilles
                This does not work on my mac 😠
                  RTLMII
                  Any Idea when a Sketchup 2015 X64 Sketchyphysics version will be available?
                    Anton_S
                    It won't be available until people owning C++ source of SketchyPhysics decide to release 64bit compatible libraries that are used by SketchyPhysics.
                      TANER TAN
                      Hello! Very useful plugin! We expect the SketchUp 2015 64-bit compatible version. Thanks.
                      • N Offline
                        N Lindenthal
                        http://sketchucation.com/forums/download/file.php?id=126705
                        Please excuse me, if I did not lern my English very well.
                        SketchyPhysics gives wings.
                        Above is my sample file. My question is: How can I stabilize the joints so that they don't tremble so strong?
                        Maybe someone can set the parameters in the pattern file or give little hints.
                        Many greetings
                        Norbert Lindenthal
                          Anton_S
                          It says I'm not authorized to download the file. Looks like you have to upload the attachment the other way, in the Upload attachment tab when you post a reply.
                          Meanwhile, to reduce joint flexibility, both bodies the parent and child have to have an identical mass. That is easy to set.
                          1. Select parent body, open control panel, and enable the scripted checkbox.
                          2. In the scripted field write,
                          onStart {
                            this.setMass(1.0)
                          1. Do same for the child body.
                          You can change the 1.0 to any desired value. As long the values of parent and child bodies are not way off, the joint should remain strong.
                          Here is the video demonstration:
                          https://www.youtube.com/watch?v=qw2C9goxbNk%26amp;list=UUFRTk8PFA2D36yHxwYrulIw
                          Move timestep to 1:20 for visual instruction on how to set identical mass.
                            Anton_S
                            According to Newton Dynamics, it's impossible to make newton joints 100% stiff. So, your model might end up in such situation. However, you can increase joint damp parameter to 100. It will reduce angular speed.
                            Here is the fixed model:
                            Verschraenkt.skp
                            Edit: Sorry, I had to edit this like 5 times.
                              Anton_S
                              No problem πŸ˜„
                              Your right, you only had to increase damp of the servo joint.
                              • N Offline
                                N Lindenthal
                                @anton_s said:
                                … Edit: Sorry, I had to edit this like 5 times.
                                Dear Anton, thank you very much. I did try to increase damp, but not only at first joint with slider, but also the three joints more without slider.
                                Your file is only first joint with damp 100. And it runs well.
                                Thank you, that I could learn much.
                                SketchUp and SketchyPhysics are wonderfull tools!
                                • N Offline
                                  N Lindenthal
                                  In my model the parts are like in real life in millimeters. For example 11 x 100 x 2 mm.
                                  When I create the Physics joints, they are too big. They cover the view to the model.
                                  In this case I have 4 joints. The distance between two joints are about 18 millimeters.
                                  How can I adjust the size of Physics joints proper?
                                  Model in Millimeter, Physics Joints become too big
                                  • BoxB Offline
                                    They are components, so you can just scale them as normal.
                                    Use the corner handle and crtl to scale around center.
                                    You can type in a percentage or size if you want.
                                    And you can turn them on and off using layers, sometimes it's handy to have them big so you can see what you are doing.
                                    • N Offline
                                      N Lindenthal
                                      @box said:
                                      … Use the corner handle and crtl to scale around center. …
                                      Oh, thank you, I was missing the ctrl. key.
                                      Mac: alt key πŸ˜„
                                      • E Offline
                                        eball
                                        I am using SU2014 on a MAC
                                        How do I install SketchyPhysics?
                                        Downloaded it, went to preferences/extensions..... but cannot install.
                                        Seems like other have had this issue but i couldn't find an answer for MAC.
                                        Tried SU2013 as well but same problem.Please help!
                                        Eric
                                          gp4tom
                                          Hello, I installed Sketchy Physics via the auto-install into 2013 version SU. Problem I am having is when clicking the play button, SU crashes. I have removed the Sketchy Physics from the plugin folder application support/sketchup/plugins and re-downloaded the plugin. It still crashes when clicking the play button. Appreciate some help on this. I can provide the "crash report" that appears which offers an option to be forwarded on to APPLE (as if they really care) LOL.
                                          Tom
                                            gp4tom
                                            Greetings & Happy New Year,
                                            I have installed Sketchy Physics via the auto install feature and there was no problem. Opened SU 2013 and the tools were there. My problem is that upon clicking the play button, briefly the control panel appears,then SU crashes.Has anyone else had this issue? I can provide the crash log that appear on the screen if that would help.
                                            Tom
                                            • 11
                                            • 9 / 11
