    [Plugin] Material_Maintenance v2.2 - 2013-01-13
    155 Posts 19 Posters 79.9k Views 19 Watching
      matt.gordon320
      Hey everybody, just a head's up.
      I had just installed the Sefaira Concept Plugin (conceptual energy analysis in SU) on my system, and it completely broke Material Maintenance (both v2.2.0 & v2.1.1. I've tested it on several other machines and got the same result. When I try to load Material Maintenance, the screen and cursor flicker slightly as if it's trying to load, and then never do. It doesn't crash, it just can't load.
      Just fyi,
      Matt
        Hmm... this sounds like observers and/or overwritten API methods...
          matt.gordon320
          I thought it might be something like it not being encased in its own namespace (I've been reading your blog a lot πŸ˜„ ), but 1. it's a .rbs, 2. I don't know enough to be able to diagnose anything like that.
          • Bob JamesB
            Bob James
            I had occasion to use Material Maintenance again today: I don't know what I was doing wrong before, but got perfect results this time: a real jewel of a plug-in. πŸ‘ Many thanks for all your hard work.
              jpalm32
              Very helpfuls! Tahnks for this.
              Thanks ThomThom for pointing this Plugin out!
                matt.gordon320
                Thanks again for an amazing tool! One little suggestion for the next release if it isn't too much to ask: I'd find an "Invert Selection" for the check boxes to be a very helpful little tweak!
                • V
                  vtol
                  I had first this thread opened over at Sketchup
                  Site Not Found - Discourse
                  (forums.sketchup.com)
                  and there been advised that this plugin is not changing material in component instances but the definition and thus in this setting
                  http://forums.sketchup.com/uploads/default/2412/a55e9cdc24fbe294.png
                  all component instances are applied even if the instance is not selected. Which is not what I was hoping for - my aim is to change material setting in those 'selected' only.
                  Wondering whether the author would be interested to develop an such an option, which I believe would be an enhancement to this the great plugin.
                  • B
                    bsfranza
                    would be nice if someone could contact the author, on the homepage there is no info whatsoever? (if i didnt oversee anything)
                    • V
                      vtol
                      seems that things stopped in 2012. Even the forum at the homepage seems abandoned http://www.keepingmyhandin.com/forum.
                      • B
                        bsfranza
                        would be a shame - its a great plugin with awesome ui and im sure the maker could contribute big time πŸ˜ƒ
