    [Proto] Generating Terrain from a Cloud of Points
    46 Posts 21 Posters 4.9k Views 21 Watching
    • sdmitchS Offline
      sdmitch
      Fredo,
      These models have much more relief. They are bigger with many more points than you would normally use probably. But none of the projects I worked on were small.
      Sam
      MyDot03DTM.skp
      Dem Contours.skp
      http://sdmitch.blogspot.com/
      • BoxB Offline
        Fredo if you want, this is a text file of a pair of Scissor handles that I recently managed to import into SU using the above mentioned Points Cloud as a CSV file of over 250,000 points.
        It was very slow but worked and I was able to view the scissors in 3D as guide points. I didn't bother with triangulating the faces as it had actually taken several hours to import just the points.
        It is without doubt overkill in the terrain context but it is the type of file people will be wanting, if not expecting, to be able to click, copy and 3d print in the very near future. Feel free to ignore it as it was something I found on the web while looking to solve terrain and point cloud imports.
        Scissors_handle_points.zip
          roland joseph
          I think it will depend on it's capability for detail. I don't find getting the raw terrain down is very difficult. It is all the detail that has to be built into it...i.e. garden beds, curbs, sidewalks, ditches, medians, grass edge transitions,...etc. For every minute I spend creating the ground, I spend ten on the detail.
          • fredo6F Offline
            Sam,
            Thanks for the new models. There are a little big for the plugin, but I made some trials on a subset and it seems to be OK.
            Below with 101 source points, generating roughly 3900 triangles to render the cliffs in 23 seconds.
            • fredo6F Offline
              My feeling is that it is better to generate first the natural terrain and then superimpose the artificial 'details', like limits, fences, roads, building.
              Of course, these details may deserve some dedicated techniques (in particular roads and fences), but Sketchup has already a number of tools to handle many cases, with the Sandbox and with Projection and PushPull plugins.
              I don't think it's easy (and fast enough anyway) to have interpolation generate the terrain and all details in one shot.
                roland joseph
                "to have interpolation generate the terrain and all details" I agree that would be a trick. I use your wonderful tools-on-surface (and a couple other rubies) to build terrain. I can't guess how many square miles. I do believe your tools are the best. I am saying for me at least generating a terrain with cloud point is not very exciting. It would be selfish to say I would rather a talent like you work on other things. πŸ˜„
                • fredo6F Offline
                  LIDAR and other techniques generating dense cloud of points require very different techniques.
                  • First this is usually true 3D (not 2.5D like terrain).
                  • Second, there is no real need of interpolation, but triangulation with the nearest neighbours.
                  I imagine there exists dedicated applications written for this purpose, in C++ or so to be extremely scalable. Obviously, that won't be the case for Sketchup and Ruby!
                  • fredo6F Offline
                    I think that generation of terrain is an essential feature for Sketchup, not to say that making organic shapes from control points can be useful too.
                    Actually, this is not something simple to develop in Ruby, because of the lack of efficient algorithms and the variety of topological situation. So nothing straightforward in this plugin project.
                      roland joseph
                      You are saying this one has you absorbed. If your motivation is the challenge then for sure I understand. Just one last curious question. Is this a personal effort or has it been brought on by pressure from others?
                      • pbacotP Offline
                        Nice work Fredo! I think the generation of terrain is very important. I would offer some examples but I am not too connected on this end of things. Usually I am working from contours provided by others who have already developed them from points. I wouldn't know what the original data is like. You've made great contribution to this functionality in SketchUp that was pretty backwards just a short time ago, falling behind programs like Bonzai even. With ThomThom's, Tig's and ValiArchitect's tools, as well, things have changed radically for this sort of work. Thanks, Peter
                        • JClementsJ Offline
                          JClements
                          Fredo,
                          A fellow who works for my previous employer, Brown and Caldwell Environmental Engineers, suggested downloading 2006 LIDAR data for the state of Ohio here:
                          http://gis3.oit.ohio.gov/geodatadownload/osip.aspx
                          Hopefully, they aren't too big of datasets.
                          • fredo6F Offline
                            @jclements said:
                            Fredo,
                            John,
                            Thanks. The link does not seem to work however.
                            Anyway, the current prototype is not really adapted to LIDAR data in general, due to the density and volumes. I may come one of these days with something adpated to this cases.
                              rodman100
                              Here's some data to try out...a survey CAD drawing, both 3D and 2D, together with raw data (600 points, an interpolated 5m grid of the data and a visual of the terrain model as generated by the data.
                              Survey Data.zip
                              • fredo6F Offline
                                @rodman100
                                Thanks very much, very interesting model. I imported from the dwg and had to eliminate an aberrant point.
                                The results are in the attached SKP, based on different level of smoothing (best seems to be 25 deg.)
                                Rodman100 - survey.skp
                                Difficult for me however to say whether the terrain corresponds to the reality. Maybe you have some idea.
                                  rodman100
                                  Terrain Model c.jpgThat looks good Fredo from the gif, I'm still on SU V14 so can't see your posted model but the surface looks similar to my terrain model, which from memory looked like the actual terrain. The contours can differ slightly when generated solely from points (as in my attached terrain model) as this method does not take breaklines (distinct interruption in the slope of a surface, such as a ridge, road, or stream)into account. But that depends very much on the particular site.
                                    You say cloud of points, but seems it's very similar of a cloth falling on volumes ?
                                    Maybe a cloth algorithm will be more speedy ?
                                    • pbacotP Offline
                                      @rodman100 said:
                                      [attachment=0:aclpnu4d]<!-- ia0 -->Terrain Model c.jpg<!-- ia0 -->[/attachment:aclpnu4d]
                                      I want my models to look this nice. πŸ˜„
                                      • ArcA Offline
                                        Arc
                                        see this video
                                        http://youtu.be/TgFYucpBBKs
                                        • fredo6F Offline
                                          Here is the file in SU2014
                                          Rodman100 - survey - SU14.skp
                                          • fredo6F Offline
                                            @arc said:
                                            see this video
                                            That's what I said. There are specialized application to treat massive volumes of points and generate heightmaps. So handling it in Sketchup is really just a convenience for very simple cases.
                                            • 2 / 3
