    [Proto] Generating Terrain from a Cloud of Points
    46 Posts 21 Posters 6.1k Views 21 Watching
    • fredo6F Offline
      @jiminy-billy-bob said:
      I really recommend doing stuff in C++. Ruby was already pretty fast, but I've seen improvements up to 100 times faster. It's really worth it.
      Sure, that's a possibility to explore. With compilation it might be much faster, because the methods are pure calculation within a loop.
      But even before I take care of performance, I must first evaluate if the algorithms are relevant for real terrains, which is the reason for my post at this stage.
        Anton_S
        Will be a useful plugin for drawing terrains!
        Thank you, Fredo!
        • KrisidiousK Offline
          Krisidious
          would it not be simpler to make point clouds out of polyline topos and then compare the two?
          By: Kristoff Rand
          • fredo6F Offline
            Good idea and actually I did it and obtain similar shapes, but a little rounder with the triangulator.
            The probleme however is that using iso contour cloud points is already a strong guide to the skeleton of the terrain and therefore does not validate that with scarce points here and there you would obtain a similar skeleton.
            Toposhaper is based on a linear interpolation whereas Triangulator is based on a directional polynomial interpolation, in order to avoid that each point of the cloud becomes an isolated hill or basin.
            Anyway, I am not trying to demonstrate that an algorithm can find the good solution because this is anyway wrong mathematically. There are always many solutions.
            Instead, I am just trying to check if the plugin would be useful to users and landscapers on real cases.
            • fredo6F Offline
              @krisidious said:
              here's some files from when I worked at a survey company. some of them are probably point clouds. I'll have to research to find out which. maybe you'll know by looking.
              I would need something in SKP. I have no Tools to pre-process and I don't even know what are the files.
              Fred
              • sdmitchS Offline
                sdmitch
                Fred
                Attached is a skp file with both mass points and break lines that you can hopefully use for testing. I have hundreds of such models if you want or need more.
                Alaska_NW-DTM 129.skp
                http://sdmitch.blogspot.com/
                • fredo6F Offline
                  Sam,
                  Thanks very much, very useful.
                  Actually, I have tweaked the algorithm and got the tarrain below. So I think I may finally find heuristics to speed up the interpolation.
                  There are 1986 cloud points.
                  The terrain is generated with 3069 triangles. The calculation took 18.5 seconds on my machine.
                  It seems to be a quite large area and quite flat except a few hill and an overall gentle slope. I had to scale in Z a little bit however to make the relief more apparent.
                  sdmitch_ Alaska_NW-DTM 129 _ trg.skp
                  Indeed, if you are more samples, this is welcome
                  • sdmitchS Offline
                    sdmitch
                    Fredo,
                    These models have much more relief. They are bigger with many more points than you would normally use probably. But none of the projects I worked on were small.
                    Sam
                    MyDot03DTM.skp
                    Dem Contours.skp
                    • BoxB Offline
                      Fredo if you want, this is a text file of a pair of Scissor handles that I recently managed to import into SU using the above mentioned Points Cloud as a CSV file of over 250,000 points.
                      It was very slow but worked and I was able to view the scissors in 3D as guide points. I didn't bother with triangulating the faces as it had actually taken several hours to import just the points.
                      It is without doubt overkill in the terrain context but it is the type of file people will be wanting, if not expecting, to be able to click, copy and 3d print in the very near future. Feel free to ignore it as it was something I found on the web while looking to solve terrain and point cloud imports.
                      Scissors_handle_points.zip
                        roland joseph
                        I think it will depend on it's capability for detail. I don't find getting the raw terrain down is very difficult. It is all the detail that has to be built into it...i.e. garden beds, curbs, sidewalks, ditches, medians, grass edge transitions,...etc. For every minute I spend creating the ground, I spend ten on the detail.
                        • fredo6F Offline
                          Sam,
                          Thanks for the new models. There are a little big for the plugin, but I made some trials on a subset and it seems to be OK.
                          Below with 101 source points, generating roughly 3900 triangles to render the cliffs in 23 seconds.
                          • fredo6F Offline
                            My feeling is that it is better to generate first the natural terrain and then superimpose the artificial 'details', like limits, fences, roads, building.
                            Of course, these details may deserve some dedicated techniques (in particular roads and fences), but Sketchup has already a number of tools to handle many cases, with the Sandbox and with Projection and PushPull plugins.
                            I don't think it's easy (and fast enough anyway) to have interpolation generate the terrain and all details in one shot.
                              roland joseph
                              "to have interpolation generate the terrain and all details" I agree that would be a trick. I use your wonderful tools-on-surface (and a couple other rubies) to build terrain. I can't guess how many square miles. I do believe your tools are the best. I am saying for me at least generating a terrain with cloud point is not very exciting. It would be selfish to say I would rather a talent like you work on other things. πŸ˜„
                              • fredo6F Offline
                                LIDAR and other techniques generating dense cloud of points require very different techniques.
                                • First this is usually true 3D (not 2.5D like terrain).
                                • Second, there is no real need of interpolation, but triangulation with the nearest neighbours.
                                I imagine there exists dedicated applications written for this purpose, in C++ or so to be extremely scalable. Obviously, that won't be the case for Sketchup and Ruby!
                                • fredo6F Offline
                                  I think that generation of terrain is an essential feature for Sketchup, not to say that making organic shapes from control points can be useful too.
                                  Actually, this is not something simple to develop in Ruby, because of the lack of efficient algorithms and the variety of topological situation. So nothing straightforward in this plugin project.
                                    roland joseph
                                    You are saying this one has you absorbed. If your motivation is the challenge then for sure I understand. Just one last curious question. Is this a personal effort or has it been brought on by pressure from others?
                                    • pbacotP Offline
                                      Nice work Fredo! I think the generation of terrain is very important. I would offer some examples but I am not too connected on this end of things. Usually I am working from contours provided by others who have already developed them from points. I wouldn't know what the original data is like. You've made great contribution to this functionality in SketchUp that was pretty backwards just a short time ago, falling behind programs like Bonzai even. With ThomThom's, Tig's and ValiArchitect's tools, as well, things have changed radically for this sort of work. Thanks, Peter
                                      • JClementsJ Offline
                                        JClements
                                        Fredo,
                                        A fellow who works for my previous employer, Brown and Caldwell Environmental Engineers, suggested downloading 2006 LIDAR data for the state of Ohio here:
                                        http://gis3.oit.ohio.gov/geodatadownload/osip.aspx
                                        Hopefully, they aren't too big of datasets.
                                        • fredo6F Offline
                                          @jclements said:
                                          Fredo,
                                          John,
                                          Thanks. The link does not seem to work however.
                                          Anyway, the current prototype is not really adapted to LIDAR data in general, due to the density and volumes. I may come one of these days with something adpated to this cases.
                                            rodman100
                                            Here's some data to try out...a survey CAD drawing, both 3D and 2D, together with raw data (600 points, an interpolated 5m grid of the data and a visual of the terrain model as generated by the data.
                                            Survey Data.zip
                                            • 2 / 3
